Python Plugin: GoodWe solar inverter via SEMS API
JanJaap
Domoticz version: Dev
Re: Python Plugin: GoodWe solar inverter via SEMS API
Post by JanJaap »
Good news!
when you precede a command with sudo it is execute as admin.
What I normally do is:
cd domoticz
sudo chown pi "goodwe panelen.log" (fill in correct filename, "" needed due to space in filename)
After that you can either access it through notepad++ with FTP or using winscp transfer to windows PC
RPi 3, Domoticz dev version, Aeon ZWave stick (with a whole bunch of slaves), Zigbee using Zigbee2MQTT, Nest thermo, P1 smart meter on RPi Zero
Zeil
Domoticz version: 2023.2
Post by Zeil »
Het is zeker goed nieuws!
I can see in Domoticz that it got its data from Sems portal, i guess it's working.
Also thanks for the little course on how to get admin om my Goodwe logfile in Domoticz,
and got it copied to my windows pc. (there is a lot of data in that file..)
Now beside my solarpanel Inverter, and Zigbee2MQTT (with some powermonitoring) data,
My smart home adventure needs only one thing more, and that is putting my
Mitsubitshi Heavy Industries Airco's in Domoticz, but that seems a hell of a job.
got the Mitsubishi Heatpump MQTT interface Plugin installed but cannot pull data from it..
(but this is another topic)
evb28
Post by evb28 »
hello folks
I'm trying to setup the plugin to monitor my newly installed GoodWe inverter, but I'm getting the same error message right after posting data into the plugin's configuration:
2024-04-05 14:57:47,288 - INFO - plugin.py - starting plugin version 4.0.1
2024-04-05 14:57:47,288 - INFO - plugin.py - Starting version: 4.0.1
2024-04-05 14:57:47,288 - DEBUG - plugin.py - checking versions: current '4.0.1', config '4.0.1'
2024-04-05 14:57:47,289 - DEBUG - plugin.py - startDeviceUpdate, token availability: 'False'
2024-04-05 14:57:47,289 - DEBUG - GoodWe.py - build tokenRequest with UN: '[email protected]', pwd: 'xxx'
2024-04-05 14:57:47,289 - DEBUG - GoodWe.py - build apiRequestHeaders with token: '{"client": "web", "version": "v3.1", "language": "en-GB"}'
2024-04-05 14:57:47,290 - ERROR - GoodWe.py - TokenRequestException: Failed to parse: https://www.semsportal.com/api/v2/Common/CrossLogin
The activated debug option doesn't help here since no extra data is available.
Can you please help and push me in the right direction when troubleshooting?
Domoticz version: 2026.3
Do you have strange characters in your email or password? As that sometimes get parsed wrongly... (not knowing if this really is the case).
JanJaap
Post by JanJaap »
This could be the case indeed with special characters in the password. Can you give it a try with only alphanumeric characters in your password?
evb28
Post by evb28 »
yep, I've just changed the password to letters-and-numbers only (it was the case before, but it's more simplified now) and the error message is the same
2024-04-07 23:32:26,190 - INFO - plugin.py - starting plugin version 4.0.1
2024-04-07 23:32:26,190 - INFO - plugin.py - Starting version: 4.0.1
2024-04-07 23:32:26,207 - ERROR - GoodWe.py - TokenRequestException: Failed to parse: https://www.semsportal.com/api/v2/Common/CrossLogin
JanJaap
Post by JanJaap »
Hey,
When looking at the first error you will see that changing the loglevel did indeed create additional loglines marked DEBUG which do help to find out where the exception is created (as this error is created in more than 1 place).
Now I did a couple of tests with entering an incorrect password which contained some special characters like !@%& and this was no issue: it correctly reported that I entered a wrong pwd.
Now I did see some (old.....) remarks on stackoverflow about requests lib and its base urllib3 being incompatible, so need some more info:
- what OS + version are you on?
- which python version? is shown in Domoticz log at startup or in the 'about' screen
- which version of requests?
- which version of urllib3?
I'm running python 3.9.2, requests 2.31.0 and urllib3 1.26.5
evb28
Post by evb28 »
JanJaap wrote: Monday 08 April 2024 22:42 Hey,
Hey, this is my setup
Debian 11.9
python3.9/oldstable,now 3.9.2-1 amd64 [installed,automatic]
python3-requests/oldstable,now 2.25.1+dfsg-2 all [installed,automatic]
python3-urllib3/oldstable,now 1.26.5-1~exp1 all [installed,automatic]
I see that the difference is only in the requests version (2.25.1 vs 2.31.0).
So after upgrading to Debian 12 - the issue has been resolved and the plugin works now.
Thanks for the hint!
azonneveld
Domoticz version: 2024.4
Post by azonneveld »
I noticed that the log file grows very large, about 1 MB per day (in my case: goodwe Goodwe.log).
domo V2024.7
plugin 4.0.1
Raspbian Bookworm (32 bit)
RPI4
What is wrong?
Here's a snippet of the file
2025-01-26 17:15:15,657 - INFO     - GoodWe.py          - PowerStation created: 'b1193c2f-ad19-419c-bb41-xxxx'
2025-01-26 17:15:15,658 - INFO     - plugin.py          - creating units for device with serial number: 53000DSNxxxx
2025-01-26 17:15:15,659 - INFO     - plugin.py          - finished creating devices, current count: 18
2025-01-26 17:15:15,659 - INFO     - plugin.py          - Status of GoodWe inverter (SN: 53000DSNxxxx): '1 generating'
2025-01-26 17:16:11,430 - INFO     - GoodWe.py          - PowerStation created: 'b1193c2f-ad19-419c-bb41-xxxx'
2025-01-26 17:16:11,431 - INFO     - plugin.py          - creating units for device with serial number: 53000DSNxxxx
2025-01-26 17:16:11,431 - INFO     - plugin.py          - finished creating devices, current count: 18
2025-01-26 17:16:11,432 - INFO     - plugin.py          - Status of GoodWe inverter (SN: 53000DSNxxxx): '1 generating'
2025-01-26 17:17:11,868 - INFO     - GoodWe.py          - PowerStation created: 'b1193c2f-ad19-419c-bb41-xxxx'
2025-01-26 17:17:11,869 - INFO     - plugin.py          - creating units for device with serial number: 53000DSNxxxx
2025-01-26 17:17:11,870 - INFO     - plugin.py          - finished creating devices, current count: 18
2025-01-26 17:17:11,870 - INFO     - plugin.py          - Status of GoodWe inverter (SN: 53000DSNxxxx): '1 generating'
2025-01-26 17:18:10,488 - INFO     - GoodWe.py          - PowerStation created: 'b1193c2f-ad19-419c-bb41-xxxx'
2025-01-26 17:18:10,488 - INFO     - plugin.py          - creating units for device with serial number: 53000DSNxxxx
2025-01-26 17:18:10,488 - INFO     - plugin.py          - finished creating devices, current count: 18
2025-01-26 17:18:10,489 - INFO     - plugin.py          - Status of GoodWe inverter (SN: 53000DSNxxxx): '1 generating'
2025-01-26 17:19:11,109 - INFO     - GoodWe.py          - PowerStation created: 'b1193c2f-ad19-419c-bb41-xxxx'
2025-01-26 17:19:11,110 - INFO     - plugin.py          - creating units for device with serial number: 53000DSNxxxx
2025-01-26 17:19:11,111 - INFO     - plugin.py          - finished creating devices, current count: 18
2025-01-26 17:19:11,112 - INFO     - plugin.py          - Status of GoodWe inverter (SN: 53000DSNxxxx): '1 generating'
2025-01-26 17:20:10,793 - INFO     - GoodWe.py          - PowerStation created: 'b1193c2f-ad19-419c-bb41-xxxx'
2025-01-26 17:20:10,795 - INFO     - plugin.py          - creating units for device with serial number: 53000DSNxxxx
2025-01-26 17:20:10,795 - INFO     - plugin.py          - finished creating devices, current count: 18
2025-01-26 17:20:10,796 - INFO     - plugin.py          - Status of GoodWe inverter (SN: 53000DSNxxxx): '1 generating'
2025-01-26 17:21:11,103 - INFO     - GoodWe.py          - PowerStation created: 'b1193c2f-ad19-419c-bb41-xxxx'
2025-01-26 17:21:11,104 - INFO     - plugin.py          - creating units for device with serial number: 53000DSNxxxx
2025-01-26 17:21:11,105 - INFO     - plugin.py          - finished creating devices, current count: 18
2025-01-26 17:21:11,105 - INFO     - plugin.py          - Status of GoodWe inverter (SN: 53000DSNxxxx): '1 generating'
2025-01-26 17:22:10,479 - INFO     - GoodWe.py          - PowerStation created: 'b1193c2f-ad19-419c-bb41-xxxx'
2025-01-26 17:22:10,480 - INFO     - plugin.py          - creating units for device with serial number: 53000DSNxxxx
2025-01-26 17:22:10,480 - INFO     - plugin.py          - finished creating devices, current count: 18
2025-01-26 17:22:10,481 - INFO     - plugin.py          - Status of GoodWe inverter (SN: 53000DSNxxxx): '1 generating'
2025-01-26 17:23:11,192 - INFO     - GoodWe.py          - PowerStation created: 'b1193c2f-ad19-419c-bb41-xxxx'
2025-01-26 17:23:11,193 - INFO     - plugin.py          - creating units for device with serial number: 53000DSNxxxx
2025-01-26 17:23:11,194 - INFO     - plugin.py          - finished creating devices, current count: 18
2025-01-26 17:23:11,194 - INFO     - plugin.py          - Status of GoodWe inverter (SN: 53000DSNxxxx): '1 generating'
2025-01-26 17:24:10,626 - INFO     - GoodWe.py          - PowerStation created: 'b1193c2f-ad19-419c-bb41-xxxx'
2025-01-26 17:24:10,627 - INFO     - plugin.py          - creating units for device with serial number: 53000DSNxxxx
2025-01-26 17:24:10,627 - INFO     - plugin.py          - finished creating devices, current count: 18
2025-01-26 17:24:10,628 - INFO     - plugin.py          - Status of GoodWe inverter (SN: 53000DSNxxxx): '1 generating'
2025-01-26 17:25:10,908 - INFO     - GoodWe.py          - PowerStation created: 'b1193c2f-ad19-419c-bb41-xxxx'
2025-01-26 17:25:10,909 - INFO     - plugin.py          - creating units for device with serial number: 53000DSNxxxx
2025-01-26 17:25:10,909 - INFO     - plugin.py          - finished creating devices, current count: 18
2025-01-26 17:25:10,910 - INFO     - plugin.py          - Status of GoodWe inverter (SN: 53000DSNxxxx): '1 generating'
rpi4 - zigbee2mqtt - roborock - espeasy - rfxcom - homewizard p1 - otgw - homebridge - surveillance station - egardia - goodwe (sems&modbus) - open weather map - wol - BBQ detection - rsync backup - zendure
JanJaap
Post by JanJaap »
Well nothing changed. But my own file is also immense...... So I just pushed a change to log only 1 line per update as the other 3 didn't make much sense....
azonneveld
JanJaap wrote: Sunday 26 January 2025 19:36 So I just pushed a change to log only 1 line per update as the other 3 didn't make much sense....
That already saves 66%, thanks!
Is there a way to disable the logging for 'info' status?
Disable the info logging for an hardware gateway (like a python plugin) is done in the hardware gateway settings. There are 3 setting switches available for showing info, status and/or error logging per gateway.
JanJaap
Post by JanJaap »
Well it aint that simple Walter as I'm using the logging package to write to a dedicated logfile ;) But I guess I can move that last one to debug too as that is when it makes most sense anyway
Any body else connection errors with the plugin?
I get errors from Goodwe.py in TokenRequest with incorrect API call. It seems not to be able to login anymore. It worked fine earlier this week.
The SEMS app is working normally so from my network I can access SEMS.
If nobody has this issue I have to look at my own domoticz plugin installation.....
hbennis
Post by hbennis »
rensbr
Post by rensbr »
waltervl wrote: Thursday 11 December 2025 10:52 Any body else connection errors with the plugin?
Yes, see above link. I have the same problem.
hbennis wrote: Thursday 11 December 2025 12:29 https://github.com/JanJaapKo/domoticz-G ... /issues/30
Ah, thanks, I missed that one when I looked yesterday evening. Solutions seems to be on its way.
JanJaap
Post by JanJaap »
Problem solved
JanJaap wrote: Friday 12 December 2025 14:57 Problem solved
Yes, thanks!
Jeweettoch13
Domoticz version: 2026.4
Goodwe SEMS error troubleshooting
Post by Jeweettoch13 »
Hello fellow members.
For some reason i got some errors today when requesting the data from the Goodwe SEMS plugin. Do you guys know what this means?
Goodwe SEMS error.jpg (174.7 KiB) Viewed 4283 times
Edit Waltervl: moved to Goodwe SEMS plugin topic
