Error on a dummy General kWh meter
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Kedi
Post by Kedi »
I got this error:
2025-11-30 10:15:00.527 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 1973, sValue: 'nan', sUsage: '55210', dType: 243, sType: 29)
Any idea how to resolve the 'nan' error?
FireWizard
Re: Error on a dummy General kWh meter
Post by FireWizard »
Hello @Kedi,
'nan' means Not a Number. Your dummy kWh meter expects a number value, written as a string, e.g. "123" and obviously receives something else. I don't know how you populatie your variable, but check your source.
Kedi
Post by Kedi »
I use node-red to populate the values.
I now made some provisions in node-red to catch the 'nan' so the domoticz database does not get the 'nan's anymore.
I had to go into deleting and editing records directly into the Domoticz database, so it is working again.
But Domoticz should be self-healing for those errors if data after the nan is correct, but it does not.
FireWizard
Hello @Kedi,
The General kWh sensor requires two values:
1. The power usage in W(att)
2. The cumulative energy in Wh (but will be shown in kWh)
These two values are separated by a semicolon (;) and send as a svalue. So as a string.
How could Domoticz restore or repair an invalid value, send by an external application, even if the other value is valid?
I.m.o it is the responsibility of the transmitting party to check that valid data will be sent.
Kedi
Post by Kedi »
Node-red had some time sending 'nan' as a value.
That is transfered to Domoticz, hence the errors.
I fixed the 'nan' transfer to nothing being send to Domoticz.
I also fixed the source of the nan's so Node-red is sending valid values again.
But Domoticz still would refuse to take the valid values as valid, because the 'nan' was still in the database
and was not overwritten by the valid values Node-red was already sending.
With 'self-healing' I ment that Domoticz should accept the valid values again, which it did not.
I had to go into the Domoticz database and fix it there.
FireWizard
Hello @Kedi.
I do not know, if Domoticz checks for NaN and, if so, how Domoticz checks.
Keep in mind, that (as said earlier) in JavaScript, NaN is short for "Not-a-Number", but in JavaScript, NaN is a number that is not a legal number.
This is quite confusing and so be careful on how to check for NaN.
You cannot use the typeof operator in JavaScript to check for NaN, but you have to use the isNaN() method.
The isNaN() method returns true if a value is NaN.
For more info: https://www.w3schools.com/jsref/jsref_isnan.asp
habahabahaba
Domoticz version: 2024.4
Post by habahabahaba »
We discussed such problem HERE
@Kedi, may be your version of Domoticz is older than 2024 ?
Kedi
Post by Kedi »
My version is: Version: 2025.1 (build 16657) So a little over half a year old, so should be fine.
I now use this to catch a NaN or the string 'nan' (because 'nan' was in the database).
if (isNaN(msg.payload) || msg.payload == 'nan') {
    node.warn(msg.payload);
    return;
} else {.....
Data is comming from a P1P2 device from a Daikin heatpump. I never had the NaN's before, watched the node.warn for a while but it never came back. I had this issue twice now, hopefully no more.
