change the sensor type and subtype without losing the history?
keesberg
Domoticz version: 2022.2
Post by keesberg »
I previously created virtual sensors for my Omnik inverter.
(Type: General, Subtype: Custom Sensor) Because these values are incorrect, I can't correctly record the Omnik values in my Energy Dashboard.
How I can change the sensor type and subtype without losing the history?
Domoticz version: 2026.3
Re: change the sensor type and subtype without losing the history?
Create a new correct virtual sensor, update your scripts and start from there.... Do not remove the old one yet.
See how things work out for a couple of days.
Then you probably need some manual database manipulation to copy the old data into the new device meter_calender table. The normal replace device function will not work as the devices are different.
keesberg
Post by keesberg »
OK thanks for this solution.
