Easiest way to play a mp3 audio file on Raspi with Dzvents?
paul402
I have a warning script when the bathroom roof window is open for more than 30 minutes and when the outside temperature is less than 17C it sends a Telegram message. I have an amp and speaker attached to the Raspi but haven't worked out yet how to play an audio file with Dzvents. The file works fine in a terminal and from Thonny.
I couldn't see anything in the Dzvents help files. Did I miss it?
Would appreciate a link or tip to get this working.
Cheers
Cheers
- habahabahaba
- Domoticz version: 2024.4
Re: Easiest way to play a mp3 audio file on Raspi with Dzvents?
If I understood you correctly you need
domoticz.executeShellCommand(YOUR COMMAND )
- Domoticz version: 2025.1
And make sure the command has an absolute path so some like /home/pi/scripts/yourbash.sh
You can also test it by running the command with sudo as that is what Domoticz is doing
paul402
Thanks for that. It's so easy when you know!
paul402
Well it didn't end up being easy!
This audio file in the /scripts directory
sh01CheckFridgeDoor.mp3
This python file in /scripts with all permissions
Plays perfect in Thonny.
CMD Box
Runs without error but no sound
Create a Domoticz script to run every minute.
Runs perfect without Domoticz errors but no sound.
I'm obviously doing something wrong but what?
It's driving me crazy.
#!/usr/bin/python3
import sys
sys.path.append('/home/pi/domoticz/scripts/python')
# to check path is updated
print (sys.path)
### File name here
af='/home/pi/domoticz/scripts/python/sh01CheckFridgeDoor.mp3'
import pygame
pygame.mixer.init()
pygame.mixer.music.load(af)
pygame.mixer.music.play()
CMD Box
sudo/without sudo python/python3 /home/pi/domoticz/scripts/python/01pythonPlayAudioCheckFridgeDoor.py
- habahabahaba
And what is your Dzvents script?
paul402
active = true,
logging = {
level = domoticz.LOG_DEBUG,
marker = 'audio output'
timer = {'Every minute'}
execute = function(domoticz)
local cde = "home/pi/Documents/01pythonPlayAudioCheckFridgeDoor.py"
domoticz.executeShellCommand({
command = cde,
callback = "myTrigger",
timeout = 2,
- habahabahaba
If you are using "callback" so you have to use
"on = {
shellCommandResponses = { 'mycallbackstring' }"
Just try without callback and timeout - simple string.
"on = {
- habahabahaba
paul402
I guess you mean this format domoticz.executeShellCommand('some shell command')
So I should use
domoticz.executeShellCommand('home/pi/Documents/01pythonPlayAudioCheckFridgeDoor.py')
which executes without error but without sound. I think that it's time for bed. Enough for tonight.
So I should use
- habahabahaba
Slash befor the "home..."?
paul402
I eventually found a solution on stackexchange....
So you need to add this after the play() command then it works from the cli and Domoticz.
Who knows why!.... but I've wasted a lot of time on this.
I'm falling out of love with Raspis and its OS and dependencies. Designed by sadists for masochists...
while pygame.mixer.music.get_busy() == True:
pass
- gizmocuz
Raspbian is based on Debian which is a great OS.
Your issue was in a Python script, so there is no need to shout on Debian
Sure there are other ways to play this MP3 file.
Could be that dzVents/Domoticz now has to wait until the MP3 is played... which is not desired, better to play this in the background
You can also use mpg123 and play it in the background
import subprocess
subprocess.Popen(["mpg123", "music.mp3"])
print("Started in background.")Quality outlives Quantity!
domoticz.executeShellCommand is running the started proces/python script in async. So why in the Python script a subprocess?gizmocuz wrote: Tuesday 25 November 2025 8:48...
import subprocess subprocess.Popen(["mpg123", "music.mp3"]) print("Started in background.")
paul402
Well blow me down! That worked on both my Domoticz Pi3 and Pi4 installations. Thank you.
I only had to add the Python exit() command to the script.
What worked? What solution did you end up with?paul402 wrote: Sunday 30 November 2025 11:14 Well blow me down! That worked on both my Domoticz Pi3 and Pi4 installations. Thank you.
- habahabahaba
Yes, show both full scripts please
