How to start Domoticz with --no-cache in docker compose? Topic is solved
BarryT
- Domoticz version: 2024.3
i do not want to use the cache function of domoticz at all, but i can't find a way to disable this.
I'm using domoticz from docker compose (portainer).
thanks!
thanks!
- jvdz
- Domoticz version: 4.107
Re: How to start Domoticz with --no-cache in docker compose?
You mean the parameters you can define for env variable EXTRA_CMD_ARG? Just check the docker wiki page.
BarryT
Nice answer, i'll Check. Thanks!jvdz wrote: Thursday 20 November 2025 20:23 You mean the parameters you can define for env variable EXTRA_CMD_ARG? Just check the docker wiki page.
Its for Docker, not Docker compose?
- jvdz
Docker/docker compose is the same thing, just a different way to configure the stack/Container, like you do with portainer.
BarryT
I was hoping it was that easy, but:jvdz wrote: Thursday 20 November 2025 21:12 Docker/docker compose is the same thing, just a different way to configure the stack/Container, like you do with portainer.![]()
environment:
- TZ=Europe/Amsterdam
- WWW_PORT=80
- SSL_PORT=0
- loglevel=error
- EXTRA_CMD_ARG=--no-cache
- jvdz
It is, but is the "-no-cache" a valid parameter? This is what the wiki states: https://wiki.domoticz.com/Command_line_parameters.
Isn't the "-no-cache" a parameter for your browser on your the computer?
BarryT
No, Domoticz has an no-cache command line parameter, and all these commands are working correctly inside docker compose, but the no-cache is not working. I tried -nocache, --nocache, -no-cache, but nothing works.jvdz wrote: Friday 21 November 2025 8:51It is, but is the "-no-cache" a valid parameter? This is what the wiki states: https://wiki.domoticz.com/Command_line_parameters.
Our Docker is respecting all the parameters, except the nocache.:
environment:
- TZ=Europe/Amsterdam #WORKS
- WWW_PORT=80 #WORKS
- SSL_PORT=0 #WORKS
- loglevel=error #WORKS
- nocache #NOT WORKING
- no-cache #NOT WORKING
- --nocache #NOT WORKING
- --no-cache #NOT WORKING
- nocache=true #NOT WORKING-
BarryT
Ah, now its working with this environment:jvdz wrote: Friday 21 November 2025 8:51It is, but is the "-no-cache" a valid parameter? This is what the wiki states: https://wiki.domoticz.com/Command_line_parameters.
- EXTRA_CMD_ARG=-nocache- waltervl
- Domoticz version: 2026.3
And the nocache option was added in the code in 2023 but not documented in the wiki, now it is....
BarryT
Great! Thats why i couldnt find..waltervl wrote: Friday 21 November 2025 18:42 And the nocache option was added in the code in 2023 but not documented in the wiki, now it is....
Thanks both, have a good weekend
