New theme (LittleTheme)
TiXav
Post by TiXav »
I created a new theme, I hope that somoene will enjoy it (I saw device with 3 buttons in css but I do not have it so I was not able to see the rendering)
I tested it on Computer, tablet and mobile phone
On phone, You will notice that the dimmer is not visible in switches sheet (not very usefull on little screen, and there is popup in case of)
COMPUTER
0 screenshot_dashboard.png (186.18 KiB) Viewed 3729 times
1 screenshot_switches.png (218.19 KiB) Viewed 3729 times
TABLET
2 tablet dashboard.png (304.71 KiB) Viewed 3729 times
https://github.com/Tixav/LittleTheme.git
Last edited by TiXav on Wednesday 19 November 2025 13:18, edited 2 times in total.
TiXav
Re: New theme (LittleTheme)
Post by TiXav »
Mobile
5 mobile dashbord.jpg (148.19 KiB) Viewed 3728 times
4 mobile.jpg (246.99 KiB) Viewed 3728 times
TiXav
Post by TiXav »
HEre the zip file to detatch and unzip in the domoticzFolder/www/styles/LittleTheme/images
LittleTheme.zip
(234.27 KiB) Downloaded 130 times
Place an image of your choice in the domoticzFolder/www/styles/LittleTheme/images and name it "av4.jpg" (sorry my picture is too big I can't upload it)
a view of switches sheet (mobile)
6 mobile switches.jpg (241.28 KiB) Viewed 3723 times
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
Great job.
We try it soon
MYXOMOP
Post by MYXOMOP »
Good job.
But we don't need that!
TiXav
Post by TiXav »
I did it for myself first, and after a lot of year of using/learning due to dz, it seems obvious to me to share a little bit for the community
to move things forward. Strange attitude ?,
Domoticz version: 2026.3
Thanks! If you want to test the 3 button devices just create a dummy device, see the wiki how to do that.
You can delete the devices after you have tested them.
https://wiki.domoticz.com/Dummy_for_virtual_Switches
rron
Post by rron »
Thank you for the effort. I will try this.
TiXav
Post by TiXav »
I finished (I think) with the device with 3 icons
@ the same time I add a little script in custom.js to replace the text options (edit,log,schedule...) by integrated "Font Awesome"
and solve some little object location
0 3icons block in dasboard.png (60.67 KiB) Viewed 3656 times
1 3icons block in switches tab.png (49.93 KiB) Viewed 3656 times
LittleTheme.zip
(238.52 KiB) Downloaded 122 times
madpatrick
Maybe making it available via Git?
Easier for updates
TiXav
Post by TiXav »
You're right, but I am not an expert on Git, I will try and come back with al link
TiXav
Post by TiXav »
I created the repository here
TiXav
Post by TiXav »
Last version does not need custom.js any more
TiXav
Post by TiXav »
I found some missing code in domoticz/www/views/temperature_widget.html that avoids to replace option's text by icons
data-i18n="Log" is missing line 43
data-i18n="Forecast" line 49/50
certainly that also cause translation issue
I will report this in domoticz github issue
TiXav
Post by TiXav »
Problem fixed by gizmocuz. Now its working
