what about portsettings etc. in docker?
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
BartSr
Domoticz version: V2024.7
Post by BartSr »
Hi, making domoticz run in container.
I am looking for docu about portsettings etc for rfxcom and other usb devices
Maybe more, but trying.
MQTT broker is running but how to check domoticz is connected via mqtt?
Anyone who helps me out?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Domoticz version: 2025.1
Re: what about portsettings etc. in docker?
See the wiki: https://wiki.domoticz.com/Docker
To check Domoticz is connected to MQTT check the log (the same as Domoticz without Docker...)
BartSr
Post by BartSr »
After spending far over a day I still get stuck. It seems there's something wrong with volumes in the docker-compose.yaml
It happens that after running the container there's an empty database. I understood that just if container is running you see the database with two files being 'part' of the database. But I just see domoticz.db only.
In contradiction to the wiki setup for zigbee2mqtt which shows a complete docker-compose.yaml this is missing in the wiki for docker.
What's best way to get out of this labyrinth?
As the docker setup failed I tried bare installation which proceeded well until an error stopped unpackking the files while almost done.
Any advices are welcome.
Mosquitto and z2m went very easy with usecof docker.
Thanks for helping me out.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
BartSr
Post by BartSr »
This regards hardware HPthinclientT630 with Ubuntu 24
services:
  domoticz:
    image: domoticz/domoticz:latest
    container_name: domoticz
    restart: unless-stopped
    ports:
      - "8080:8080"   # Web interface
      - "1443:1443"   # HTTPS (optioneel)
      - "6144:6144/udp" # Domoticz UDP (voor sommige ap>
    volumes:
#      - ./home/bart/Domoticz:/home/bart/Domoticz
      - /home/bart/domoticz/config:/config
#      - /home/bart/domoticz/config:/opt/domoticz
      - /home/bart/domoticz/scripts:/opt/domoticz/scrip>
      - /home/bart/domoticz/plugins:/opt/domoticz/plugi>
      - /home/bart/domoticz/log:/opt/domoticz/log
      - /home/bart/domoticz/backup:/opt/domoticz/backups
      - /home/bart/domoticz/data:/opt/domoticz/data
    environment:
#      - PUID=1000       # Pas aan naar de gebruiker op>
#      - PGID=1000       # Pas aan naar de groep op je >
      - TZ=Europe/Amsterdam  # Pas aan naar jouw tijdzo>
    devices:
      - "/dev/serial/by-id/usb-RFXCOM_RFXtrx433_A1BFAMG>
The file might be bit messy but this is me latest try
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Did you check https://hub.docker.com/r/domoticz/domoticz ?
And especially this section;
Usage with docker-compose
mkdir /opt/domoticz
cd /opt/domoticz
Inside this folder create a file (docker-compose.yml) with the following contents
docker-compose.yml
Then after starting the container the database should popup in /opt/domoticz/config
But you can choose any folder on your system where to store the docker-compose.yml as that is the root for the volume from the outside.
Inside the container it is always /opt/domoticz/userdata
On my Ubuntu system I had no write acces as normal user in folder /opt so I created the docker compose in /home/<user>/domoticz-docker
BartSr
Post by BartSr »
Oops, overlooked the link to that docker page.
Just a few seconds and it was done.
Thanks again Walter.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
You are welcome.
In your case I would not use tag latest but stable, eg
image: domoticz/domoticz:stable
When using latest you will get all beta's en all stables, whatever is created latest.
