Z4D works fine but crash on plugin onStop()
derrij
Post by derrij »
2025-10-31 16:55:14.453 Status: Domoticz V2025.2 (build 16839) (c)2012-2025 GizMoCuz
2025-10-31 16:55:14.453 Status: Build Hash: 03cef9ecf, Date: 2025-10-28 10:24:56
2025-10-31 16:55:23.463 Status: Zigbee: Initialized version 7.1, author 'pipiche38'
2025-10-31 16:55:24.426 Status: Zigbee: Z4D is starting transport Mode: 'ZigpyEZSP' Serial: 'null' IP: '192.168.1.55 'Port: '2022'
2025-10-31 16:32:57.344 Zigbee: Calling message handler 'onStop' on 'module' type object.
2025-10-31 16:32:57.344 Zigbee: onStop()
2025-10-31 16:32:57.700 Status: Zigbee: ++ Forwarder thread stopped. [1/3]
2025-10-31 16:33:25.704 Status: Zigbee: Coordinator backup is available: /opt/domoticz/userdata/plugins/Domoticz-Zigbee/Data/Coordinator-18.backup
2025-10-31 16:33:29.719 Status: Zigbee: Zigpy transport threads shutdown attempted
2025-10-31 16:33:38.073 Status: Zigbee: ++ WebUI shutdown completed [3/3]
2025-10-31 16:33:38.074 Zigbee: logging_thread - ended
2025-10-31 16:33:38.075 Zigbee: Logging Thread shutdown
2025-10-31 16:33:38.075 Zigbee: Remaining active threads: [('MainThread', 134707723372224, True), ('ZigpyForwarder_18', 134707511559872, True)]
2025-10-31 16:33:38.075 (Zigbee - Zigate Status 18) Updating device from 1:'Ready' to have values 4:'No Communication'.
2025-10-31 16:33:38.079 Zigbee: Warning: Plugin has 1 Python threads running.
2025-10-31 16:33:39.079 Zigbee: Warning: Plugin has 1 Python threads running.
2025-10-31 16:33:40.123 Zigbee: Warning: Plugin has 1 Python threads running.
2025-10-31 16:33:41.124 Zigbee: Warning: Plugin has 1 Python threads running.
2025-10-31 16:33:42.124 Zigbee: Warning: Plugin has 1 Python threads running.
2025-10-31 16:33:43.125 Zigbee: Warning: Plugin has 1 Python threads running.
2025-10-31 16:33:44.126 Zigbee: Warning: Plugin has 1 Python threads running.
2025-10-31 16:33:45.126 Zigbee: Warning: Plugin has 1 Python threads running.
2025-10-31 16:33:46.126 Zigbee: Warning: Plugin has 1 Python threads running.
2025-10-31 16:33:47.126 Zigbee: Warning: Plugin has 1 Python threads running.
2025-10-31 16:33:48.127 Zigbee: Warning: Plugin has 1 Python threads running.
2025-10-31 16:33:48.127 Zigbee: Abandoning wait for Plugin thread shutdown, hang or crash may result.
2025-10-31 16:34:05.055 Error: WebServer:8080 thread seems to have ended unexpectedly (last update 72.000000 seconds ago)
pipiche
Re: Z4D works fine but crash on plugin onStop()
Post by pipiche »
Don't know which version. of the plugin you are running.
kindly make sure that you are on the latest stable7 7.1.024
then from the plugin home directory do the following command
[code]
git pull
git checkout hotfix-join-never-completes
[/code]
then restart the Domoticz
pipiche
Post by pipiche »
The fix has been release on stable7 7.1.025
