HELP Domoticz stopt working after update
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Fredom
Domoticz version: 2026.3
Post by Fredom »
I tried updating Domoticz to 2025.2 today. Unfortunately, it went terribly wrong because I hadn't noticed this update was for Bookworm with OpenSSL 3.0, which I don't have.
Now Domoticz won't start anymore. Does anyone know if this can be fixed? My backup has an error in it and isn't working either.
Yours sincerely,
Fred
Rasberry Pi 3B+ - Debian Trixie - Domoticz 2026.3
RFLink - RFXCom - Z4D 9.1 (CC2652rb)
P1 Smart Meter - KaKu
HansieNL
Re: HELP Domoticz stopt working after update
Post by HansieNL »
Maybe this info can help you...
To update your OS from bullseye to bookwork you can use this guide:
https://www.cyberciti.biz/faq/update-up ... -bookworm/
Blah blah blah
Fredom
Post by Fredom »
HansieNL wrote: Thursday 23 October 2025 21:25 Maybe this info can help you...
Thanks for your reply, I'll look into it.
Yours sincerely,
Fred
Fredom wrote: Thursday 23 October 2025 19:18 Hello,
The update script also made a FULL Domoticz backup, did that have an error? https://wiki.domoticz.com/Raspberry_Pi# ... ect_update
Fredom
Post by Fredom »
I've tried your suggestion in several ways. Unfortunately, I only get error messages, which means it won't work. I made a backup from a few months ago, and that works for everything except ZigBee. None of my backups include ZigBee devices, which I don't understand. The backups I always make are of the entire SD card—an image, that is. I'm currently restoring all 21 ZigBee devices. Once this is done, I'm considering doing everything again with a clean install, not with Bookworm.
Yours sincerely,
Fred
Fredom
Post by Fredom »
waltervl wrote: Friday 24 October 2025 13:15
I didn't know that about those backups. I'm already restoring everything from a backup I made a few months ago (on a different SD card). I can still try your suggestion, and I definitely will. I've learned something new.
Yours sincerely,
Fred
