Node red flow
FireWizard
Re: Node red flow
Post by FireWizard »
@edwin1234,
Now i got some value perhaps i have to wait till it runs for a day or so to see the kwh
I do not own a Tuya device, but of course, the update frequency is dependent on the publishing frequency
of the Tuya device (your refrigerator).
But I see another strange thing in your picture.
The consumed energy for today shows "nan kWh".
Did you change the setting for "Energy read" to "Computed"?
Is the value (93.7 Watt) an expected value for the consumption of the refrigerator?
Let wait and see, if that changes tomorrow
edwin1234
Domoticz version: 2021.1
Re: Node red flow
Post by edwin1234 »
Yes i have it on computed and now a few minutes later i have a nan watt value, very strange.
with the inject node i got 101.2 watt and nan kwh
Also an error in the domoticz log:
Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 1463, sValue: 'nan', sUsage: 'nan', dType: 243, sType: 29)
I will wait and see what value there tomorow will be.
FireWizard
Re: Node red flow
Hi @edwin1234,
Can you tell me, what you see in "debug 10", both with my Inject node and with the Tuya device?
edwin1234
Re: Node red flow
Post by edwin1234 »
First one with inject node:Image
Second one with tuya node:Image
And still errors in the log:
2025-10-15 19:10:01.023 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 1463, sValue: 'nan', sUsage: '0', dType: 243, sType: 29)
2025-10-15 19:15:00.200 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 1463, sValue: 'nan', sUsage: 'nan', dType: 243, sType: 29)
2025-10-15 19:20:00.333 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 1463, sValue: 'nan', sUsage: 'nan', dType: 243, sType: 29)
2025-10-15 19:25:00.469 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 1463, sValue: 'nan', sUsage: 'nan', dType: 243, sType: 29)
2025-10-15 19:30:00.597 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 1463, sValue: 'nan', sUsage: 'nan', dType: 243, sType: 29)
2025-10-15 19:35:00.718 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 1463, sValue: 'nan', sUsage: 'nan', dType: 243, sType: 29)
2025-10-15 19:40:00.833 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 1463, sValue: 'nan', sUsage: 'nan', dType: 243, sType: 29)
2025-10-15 19:45:00.976 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 1463, sValue: 'nan', sUsage: 'nan', dType: 243, sType: 29)
2025-10-15 19:50:00.153 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 1463, sValue: 'nan', sUsage: 'nan', dType: 243, sType: 29)
2025-10-15 19:55:00.303 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 1463, sValue: 'nan', sUsage: '978', dType: 243, sType: 29)
2025-10-15 20:00:00.454 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 1463, sValue: 'nan', sUsage: '978', dType: 243, sType: 29)
2025-10-15 20:05:00.596 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 1463, sValue: 'nan', sUsage: 'nan', dType: 243, sType: 29)
2025-10-15 20:10:00.721 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 1463, sValue: 'nan', sUsage: '1012', dType: 243, sType: 29)
2025-10-15 20:15:00.860 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 1463, sValue: 'nan', sUsage: '921', dType: 243, sType: 29)
2025-10-15 20:20:00.983 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 1463, sValue: 'nan', sUsage: '921', dType: 243, sType: 29)
FireWizard
Re: Node red flow
Hello @edwin1234,
I am puzzled. There is no difference between the real Tuya device and the simulation. The values and the formatting of the Object is correct.
Just a question. What is the device type for idx 1463?
edwin1234
Re: Node red flow
Post by edwin1234 »
Hi firewizard,
I use this:
type Electric (Usage + Counter)
Domoticz version: 2026.3
Re: Node red flow
Both values in svalues should be integers so "101;0"
habahabahaba
Domoticz version: 2024.4
Re: Node red flow
Post by habahabahaba »
waltervl wrote: Thursday 16 October 2025 8:18 Both values in svalues should be integers so "101;0"
https://wiki.domoticz.com/Domoticz_API/ ... d_counter) - Only Energy should be integer.
@edwin1234, Just try from browser
http://<domoticz_ip>:8080/json.htm?type=command&param=udevice&idx=1463&nvalue=0&svalue=92.1;0
If NaN will disappear then the problem is in NodeRed or Mqtt, if not - then may be in Domoticz.
FireWizard
Re: Node red flow
Thank you both @waltervl and @habahabahaba for your responses.
I don't think that is correct for several reasons.
1. At https://piandmore.wordpress.com/2019/02 ... -domoticz/ you can find:
The electric sensor will show the current usage of electricity in Watt and the cumulative usage in kWh. You can add digits after the decimal if needed.
{"command":"udevice", "idx":1234, "svalue":"us;cu"}
where us is usage in Watt and cu is cumulative usage in Wh (even though it is displayed in kWh)
2. In the Wiki, you cannot find any restriction. So I agree with @habahabahaba.
3. I have a similar device in my production system, that functions for years
4. In my test system, where I built the simulation for @edwin1234's project, I don't discover any issues.
See the screenshots.
I would also suggest to test with http instead of mqtt, but I do not expect to find the solution.
There is something else, cheating us, but what?
FireWizard
Re: Node red flow
I studied the issue in more detail,
I found a similar error message: https://github.com/domoticz/domoticz/issues/5626
This has been solved in version 15132, more than 2 years ago. I don't think it has returned.
@edwin1234.
What Domoticz version do you run. My test system runs 2025.1 Stable
In the error messages in the log, I see, beside a number of "nan" (Not a Number) for sUsage, also valid numerical values.
Could you check in the debug nodes, debug 9 and 10, that you always get a number for DataPoint 19 and also in "svalue".
I suspect the Tuya node, that it does not frequently send the correct data every 5 minutes.
So that Domoticz is correct as NR may send garbage.
Re: Node red flow
habahabahaba wrote: Thursday 16 October 2025 9:58
And the perhaps also try with an integer as value to see if that is working (i suspect so).
http://<domoticz_ip>:8080/json.htm?type=command&param=udevice&idx=1463&nvalue=0&svalue=92;0
It could well be that Domoticz has been more strict on values. it is a little bit strange to show watts in digit numbers from history perspective. I dont think that for example a P1 meter is showing watts on digits, only integers.
And that it is not mentioned in the wiki is because it was never mentioned before.
Re: Node red flow
FireWizard wrote: Thursday 16 October 2025 16:19
And those valid ones are all integers and not digits.....
edwin1234
Re: Node red flow
Post by edwin1234 »
With http i get the same error:
2025-10-16 17:30:00.362 Error: UpdateMeter: Error converting sValue/sUsage! (IDX: 1463, sValue: 'nan', sUsage: '974', dType: 243, sType: 29)
I have an older version of domoticz 2021 its old i know but i am afraid that a lot of old stuff and scripts dont work otherwise.
Re: Node red flow
edwin1234 wrote: Thursday 16 October 2025 17:34 With http i get the same error:
Important to know you are on 2021.1...
But what was the http command you sent????
edwin1234
Re: Node red flow
Post by edwin1234 »
Domoticz version 2021.1
The command i send was :
habahabahaba
Re: Node red flow
edwin1234 wrote: Thursday 16 October 2025 17:48 http://<domoticz_ip>:8080/json.htm?type=command&param=udevice&idx=1463&nvalue=0&svalue=92;0
That is only for 2023.2 and later... The API was changed...
FireWizard
Re: Node red flow
Hello @waltervl,
You said:
FireWizard wrote: 16 Oct 2025, 16:19
I agree, it are integers and no digits, but this does not explain, why I can send floats, with 1 or 2 digits, without any error message.
See the screenshot of the widget
It is good that this is clear for everyone. Adapting the flow, to send only integers, is an easy job.
edwin1234
Re: Node red flow
Post by edwin1234 »
If you know how? ;)
FireWizard
Re: Node red flow
@edwin1234,
You asked:
If you know how? ;)
Yes, I know how, but I think you wanted it to know?
Okay
In the "Function" node change the line:
msg.payload = { "command": "udevice", "idx": 14, "nvalue" : 0, "svalue": (msg.payload.dps["19"]/10).toString() + ";0"};
into
msg.payload = { "command": "udevice", "idx": 14, "nvalue" : 0, "svalue": parseInt(msg.payload.dps["19"]/10).toString() + ";0"};
Only added the function parseInt. Ignore the idx number and take your own idx number
Try it and let us know.
edwin1234
Re: Node red flow
Post by edwin1234 »
I have value on watt now but nan kwh
Should i wait a few hours to see if there comes a value on the kwh?
I have no error in the log now.
