Zigbee2Mqtt control panel not loading [solved] Topic is solved
edwin1234
- Domoticz version: 2021.1
Re: Zigbee2Mqtt control panel not loading
It doesnt help, still not loading , and devices not updating.
Zigbee2mqtt it self is working, so it is in the plugin
jf2020
Thanks a lot! It works!!claude2666 wrote: Sunday 31 October 2021 10:38 To make the Zigbee plugin menu work again, you need to set the api_transport device created in the devices menu to used.![]()
mgugu
In addition to enable api_transport device, to solve that problem I needed latest domoticz beta and the latest plugin update.edwin1234 wrote: Sunday 21 November 2021 5:58 It doesnt help, still not loading , and devices not updating.
But a much better option now is to forget the plugin and use the new mqtt autodiscovery feature available in recent betas.
Working like a charm for me.
sammyke007
- Domoticz version: 2022.1
Yeah, the only thing I don't like is that buttons create multiple devices (single, double, hold, release) with autodiscovery instead of 1 selector switch like the plugin does.mgugu wrote:In addition to enable api_transport device, to solve that problem I needed latest domoticz beta and the latest plugin update.edwin1234 wrote: Sunday 21 November 2021 5:58 It doesnt help, still not loading , and devices not updating.
Verstuurd vanaf mijn Oneplus 8 met Tapatalk
ronald1827
Bij mij werkt zigbee2mqtt maar de plugin die ik heb geinstalleerd vanuit de plugins manager wil niet worden geladen , zie dit in log file
021-12-18 21:35:26.933 Error: Zigbee2mqtt: (Zigbee2MQTT) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/zigbee2mqtt/:/usr/lib/python37.zip:/usr/lib/python3.7:/usr/lib/python3.7/lib-dynload:/usr/local/lib/python3.7/dist-packages:/usr/lib/python3/dist-packages:/usr/lib/python3.7/dist-packages'.
2021-12-18 21:35:26.933 Error: Zigbee2mqtt: (Zigbee2mqtt) Module Import failed, exception: 'ModuleNotFoundError'
2021-12-18 21:35:26.933 Error: Zigbee2mqtt: (Zigbee2mqtt) Module Import failed: ' Name: DomoticzEx'
2021-12-18 21:35:26.933 Error: Zigbee2mqtt: (Zigbee2mqtt) Error Line details not available.
Groet
Ronald.
Groet
Ronald.
ronald1827
ik ben er ook net achter gekomen dat ik niet naar de map:
cd domoticz/plugins/zigbee2mqtt mag gaan, permission denied.
ronald1827
werkt , ging lampje branden , verkeerde plugin , heb de stable version en nu werkt het wel.
ronald1827
Wat nog niet werkt is gui panel , netwerkmap en dat soort dingen
Heb een Sonoff SNZB-02 en die laat in 5 verschillende entiteiten de waardes zien maar de plugin werkt niet correct omdat de GUI leeg is.
ronald1827
verder geprobeerd, frontend van softwarepakket in linux zigbee2mqtt ingeschakeld en daar wel alles netwerk map e.d. temperatuur sensoren worden gezien (alles netjes in 1 panel) en deze link gevolgd
https://www.zigbee2mqtt.io/guide/config ... figuration
yaml file aanpassen , Pi reboot en dan port 8080 en dan is het zichtbaar.
de womoticz pluging kan dit niet laten zien dus zit een bug in , maar zo kan het ook.
- McMelloW
- Domoticz version: V2024.1
Port 8080 is usually used by Domoticz. Just use another port, like 9080. It works like a charm.ronald1827 wrote: Sunday 19 December 2021 12:56 verder geprobeerd, frontend van softwarepakket in linux zigbee2mqtt ingeschakeld en daar wel alles netwerk map e.d. temperatuur sensoren worden gezien (alles netjes in 1 panel) en deze link gevolgd
Greetings McMelloW
- Varazir
Thanks worked!claude2666 wrote: Sunday 31 October 2021 10:38 To make the Zigbee plugin menu work again, you need to set the api_transport device created in the devices menu to used.![]()
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
jpmd
Re: Zigbee2Mqtt control panel not loading [solved]
Does someone know why my Zigbee2Mqtt control panel does not loading?
I set the device "Zigbee 2MQTT API Transport" to used, but unfortunate the controlpanel stays in "loading" state
- Schermafbeelding 2025-10-03 110535.jpg (20.66 KiB) Viewed 4161 times
- gizmocuz
I Don''t think this is Zigbee2MQTT ?!
Maybe clear your browser cache
Also this is a very old topic
- Domoticz version: 2026.3
This is probably the zigbee2mqtt python plugin. You need to update the plugin as yours probably uses old API calls that have been deprecated in latest Domoticz stable.
jpmd
I'v updated the zigbee2mqtt python plugin with "git pull". Unfortunately the Zigbee2mqtt control form still stay in loading state
Perhaps do a browser cache deletion or try Domoticz in a private/incognito browser session to emulate this.
Also restart Domoticz or the plugin...
jpmd
Yeah...after deleting cookies and browserhistory. It's working ! Thanks a lot!
tonbor
but my pair button does not work anymore
2025-10-19 15:11:42.751 Error: Zigbee2MQTT: Call to function 'onMessage' failed, exception details:
2025-10-19 15:11:42.838 Error: Zigbee2MQTT: Traceback (most recent call last):
2025-10-19 15:11:42.838 Error: Zigbee2MQTT: File "/home/pi/domoticz/plugins/zigbee2mqtt/plugin.py", line 299, in onMessage
2025-10-19 15:11:42.838 Error: Zigbee2MQTT: _plugin.onMessage(Connection, Data)
2025-10-19 15:11:42.838 Error: Zigbee2MQTT: ~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^
2025-10-19 15:11:42.838 Error: Zigbee2MQTT: File "/home/pi/domoticz/plugins/zigbee2mqtt/plugin.py", line 137, in onMessage
2025-10-19 15:11:42.838 Error: Zigbee2MQTT: self.mqttClient.onMessage(Connection, Data)
2025-10-19 15:11:42.838 Error: Zigbee2MQTT: ~~~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^
2025-10-19 15:11:42.838 Error: Zigbee2MQTT: File "/home/pi/domoticz/plugins/zigbee2mqtt/mqtt.py", line 167, in onMessage
2025-10-19 15:11:42.838 Error: Zigbee2MQTT: self.on_mqtt_message_cb(topic, message)
2025-10-19 15:11:42.838 Error: Zigbee2MQTT: ~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^
2025-10-19 15:11:42.838 Error: Zigbee2MQTT: File "/home/pi/domoticz/plugins/zigbee2mqtt/plugin.py", line 155, in onMQTTPublish
2025-10-19 15:11:42.838 Error: Zigbee2MQTT: self.api.handle_mqtt_message(topic, message)
2025-10-19 15:11:42.838 Error: Zigbee2MQTT: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^
2025-10-19 15:11:42.838 Error: Zigbee2MQTT: File "/home/pi/domoticz/plugins/zigbee2mqtt/api/api.py", line 36, in handle_mqtt_message
2025-10-19 15:11:42.838 Error: Zigbee2MQTT: command.handle_mqtt_message(topic, message)
2025-10-19 15:11:42.838 Error: Zigbee2MQTT: ~~~~~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^
2025-10-19 15:11:42.838 Error: Zigbee2MQTT: File "/home/pi/domoticz/plugins/zigbee2mqtt/api/bridge.py", line 18, in handle_mqtt_message
2025-10-19 15:11:42.838 Error: Zigbee2MQTT: self.send_response(message['data']['value'])
2025-10-19 15:11:42.838 Error: Zigbee2MQTT: ~~~~~~~~~~~~~~~^^^^^^^^^
2025-10-19 15:11:42.838 Error: Zigbee2MQTT: KeyError: 'value'
