Z4D has error after install Topic is solved
jandoedel
- Domoticz version: 2025.1
On a Raspberry 3+ i have install Bookworm
Installed Domoticz Working well
Version: 2025.1 (build 16782)
Build Hash: 3ed178aa4
Compile Date: 2025-09-12 08:38:25
dzVents Version: 3.1.8
Python Version: 3.11.2 (main, Apr 28 2025, 14:11:48) [GCC 12.2.0]
I try to install Z4D then i got errors
What do i wrong?
What do i wrong?
- error Zigbee.txt
- (6.92 KiB) Downloaded 196 times
- Domoticz version: 2026.3
Re: Z4D has error after install
So below it the issue: Error while starting Radio with bad marshal data (invalid reference).
Did you use the correct settings for your Dongle?
Edit: see alo https://zigbeefordomoticz.github.io/wik ... ot-working
2025-09-19 20:22:52.650 Error: Zigbee: Error while starting Radio: znp on port /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_3ea0a70bf3bded1188de6b2e38a92db5-if00-port0 with bad marshal data (invalid reference)
2025-09-19 20:22:52.669 Error: Zigbee: Traceback (most recent call last):
2025-09-19 20:22:52.669 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/zigpyThread.py", line 222, in radio_start
2025-09-19 20:22:52.669 import zigpy_znp.config as radio_specific_conf
2025-09-19 20:22:52.669 File "/usr/local/lib/python3.11/dist-packages/zigpy_znp/config.py", line 23, in <module>
2025-09-19 20:22:52.669 from zigpy_znp.commands.util import LEDMode
2025-09-19 20:22:52.669 File "/usr/local/lib/python3.11/dist-packages/zigpy_znp/commands/__init__.py", line 4, in <module>Edit: see alo https://zigbeefordomoticz.github.io/wik ... ot-working
jandoedel
the settings are correct.
i have put my bullseye image back en check it.
Z4D is goed working there.
For Bookworm you need to make use of the Python Virtual environment as explained on the Z4D wiki: https://zigbeefordomoticz.github.io/wik ... alEnv.html
Rik60
Yes, this is an important step to do. Otherwise Z4D won't work. I upgrated last week from Bullseye to Bookworm, with these steps Z4D wil work. Another tip, if you have a Z4D backup, copy the data and conf to the new installed plugin. You don't have to learn/train the zigbee devices again, this worked for me. See the wiki.waltervl wrote: Saturday 20 September 2025 13:03 For Bookworm you need to make use of the Python Virtual environment as explained on the Z4D wiki: https://zigbeefordomoticz.github.io/wik ... alEnv.html
jandoedel
Oke it is working.
Thanks everyone
Thanks everyone
jandoedel
Zigbee is working good.
But there are errors in the log.
But i don't no where to look.
Plugin: 7.1.023 [6.476]
2025-09-28 21:28:03.596 Error: Zigbee: forwarder_thread - Error while receiving a Coordinator command
2025-09-28 21:28:03.638 Error: Zigbee: Issue in request 0180020032ff000104070201010226d202000018fe0a0000250700000000004203, dumping stack: Traceback (most recent call last):
2025-09-28 21:28:03.638 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/forwarderThread.py", line 49, in forwarder_thread
2025-09-28 21:28:03.638 forward_message(self, message)
2025-09-28 21:28:03.638 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/instrumentation.py", line 38, in f_out
2025-09-28 21:28:03.638 result = f_in(self, message)
2025-09-28 21:28:03.638 ^^^^^^^^^^^^^^^^^^^
2025-09-28 21:28:03.638 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Classes/ZigpyTransport/forwarderThread.py", line 65, in forward_message
2025-09-28 21:28:03.638 self.F_out(message)
2025-09-28 21:28:03.638 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/plugin.py", line 801, in processFrame
2025-09-28 21:28:03.638 zigbee_receive_message(self, Devices, Data)
2025-09-28 21:28:03.638 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/input.py", line 165, in zigbee_receive_message
2025-09-28 21:28:03.638 _decode_message(self, MsgType, Devices, Data, MsgData, MsgLQI)
2025-09-28 21:28:03.638 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/input.py", line 172, in _decode_message
2025-09-28 21:28:03.638 decoding_method(self, Devices, MsgData, MsgLQI)
2025-09-28 21:28:03.638 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Z4D_decoders/z4d_decoder_Read_Report_Attribute_Rsp.py", line 52, in Decode8102
2025-09-28 21:28:03.638 scan_attribute_reponse(self, Devices, MsgSQN, i_sqn, MsgSrcAddr, MsgSrcEp, MsgClusterId, MsgData, '8102')
2025-09-28 21:28:03.638 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Z4D_decoders/z4d_decoder_Read_Report_Attribute_Rsp.py", line 88, in scan_attribute_reponse
2025-09-28 21:28:03.638 read_report_attributes( self, Devices, msgtype, MsgSQN, MsgSrcAddr, MsgSrcEp, MsgClusterId, MsgAttrID, MsgAttStatus, MsgAttType, MsgAttSize, MsgClusterData, )
2025-09-28 21:28:03.638 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Z4D_decoders/z4d_decoder_Read_Report_Attribute_Rsp.py", line 121, in read_report_attributes
2025-09-28 21:28:03.638 ReadCluster( self, Devices, MsgType, MsgSQN, MsgSrcAddr, MsgSrcEp, MsgClusterId, MsgAttrID, MsgAttStatus, MsgAttType, MsgAttSize, MsgClusterData, Source=MsgType, )
2025-09-28 21:28:03.638 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/readClusters.py", line 174, in ReadCluster
2025-09-28 21:28:03.638 process_cluster_attribute_response( self, Devices, MsgSQN, MsgSrcAddr, MsgSrcEp, MsgClusterId, MsgAttrID, MsgAttType, MsgAttSize, MsgClusterData, Source, )
2025-09-28 21:28:03.638 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/readZclClusters.py", line 132, in process_cluster_attribute_response
2025-09-28 21:28:03.638 value = compute_attribute_value( self, MsgSrcAddr, MsgSrcEp, MsgClusterId, MsgAttrID, value, _eval_inputs, _eval_formula, _function)
2025-09-28 21:28:03.638 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2025-09-28 21:28:03.638 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/readZclClusters.py", line 471, in compute_attribute_value
2025-09-28 21:28:03.638 return func( self, nwkid, ep, cluster, attribut, value )
2025-09-28 21:28:03.638 File "/home/pi/domoticz/plugins/Domoticz-Zigbee/Modules/zclClusterHelpers.py", line 452, in compute_metering_conso
2025-09-28 21:28:03.638 conso = round((conso * multiplier) / divisor, 3)
2025-09-28 21:28:03.638 ~~~~~~~~~~~~~~~~~~~^~~~~~~~~~~
2025-09-28 21:28:03.638 ZeroDivisionError: division by zero
Strange error, but for sure there is a lack of protection in the code.
This is fixed in the next release 7.1.024
you can have the release candidate by doing a
[code]
git pull
git checkout rc-stable7.1.024
[/code]
Do not the restart the plugin yet, but use WebUI -> Admin -> Plugin -> Plugin Update (to ensure all is correctly updated)
and then restart the plugin
[code]
git pull
[/code]
jandoedel
What to do?
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ git checkout rc-stable7.1.024
error: Your local changes to the following files would be overwritten by checkout:
Classes/PluginConf.py
Classes/WebServer/WebServer.py
Classes/WebServer/dispatcher.py
DevicesModules/custom_Chameleon.py
Modules/domoMaj.py
Modules/linky.py
Modules/readAttributes.py
plugin.py
www/z4d/index.html
Please commit your changes or stash them before you switch branches.
Aborting
jandoedel
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ sudo git switch rc-stable7.1.024
Already on 'rc-stable7.1.024'
Your branch is up to date with 'origin/rc-stable7.1.024'.
Rik60
Same here.jandoedel wrote: Wednesday 01 October 2025 17:56Why is Domoticz-Zigbee not seeing this Branch?Code: Select all
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigbee $ sudo git switch rc-stable7.1.024 Already on 'rc-stable7.1.024' Your branch is up to date with 'origin/rc-stable7.1.024'.
Version is not updated in the software?
Plugin is running without problems
Edit:
After some time doing nothing, there is an error, see attachment
- Z4D_rc-stable_7_1_024_error.jpg (113.26 KiB) Viewed 5310 times
- Z4D_rc-stable_7_1_024.jpg (19.16 KiB) Viewed 5312 times
- Z4D_rc-stable_7_1_023.jpg (9.79 KiB) Viewed 5312 times
jandoedel
what can i do to let it work?
Rik60
I switched back to version stable 7.1.023. Rc stable 7.1.024 was besides the error working. Hopefully Pipiche has a solution for this.
Btw, i am using a Sonoff zigbee 3.0 usb dongle.
I still see some changes in RC 7.1.024 this weekend https://github.com/zigbeefordomoticz/Do ... le7.1.024/
jandoedel
how let you Rc stable 7.1.024 working.
I stuck with switching to Rc stable 7.1.024
what commands do jou used?
Rik60
I switched to the rc again (following Pipiche):jandoedel wrote: Sunday 05 October 2025 17:00 how let you Rc stable 7.1.024 working.
git pull
After the git checkout rc-stable 7.1.024 i did a plugin update using the WebUI (WebUI version is still 7.1.023) but checkout is 7.1.024
This version of the plugin is now running without problems
- Z4D_rc-stable_7_1_024_ok.jpg (172.22 KiB) Viewed 5261 times
jandoedel
after yesterday's update: sudo git checkout rc-stable7.1.024
there are now no more errors in the log.
Thanks everybody
Thanks everybody
