Text devices make database grow
Tukker
Domoticz version: 2023.2
Post by Tukker »
I like using text devices because these can contain a lot of information and I don't like pages filled op with a lot of devices which contain information from one sensor.
The back side of this is that my database grows steadily.
Here is a script to cleanup your text devices clutter in the database.
#!/bin/bash
# cleanup_text_devices.sh
# Nu inclusief automatische mail bij fouten
LOG_FILE="/var/log/domoticz_text_cleanup.log"
DB_PATH="/home/pi/domoticz/domoticz.db"
SERVICE_NAME="domoticz.service"
RETENTION_DAYS=7
log() {
    echo "$(date '+%Y-%m-%d %H:%M:%S') - $1" | tee -a "$LOG_FILE"
mail_error() {
    local SUBJECT="$1"
    local BODY="$2"
    echo -e "Subject: $SUBJECT\n\n$BODY" | msmtp "$MAIL_TO"
log "Start Domoticz cleanup procedure"
# Stop Domoticz service
if systemctl is-active --quiet "$SERVICE_NAME"; then
    log "Stopping Domoticz service"
    if ! sudo systemctl stop "$SERVICE_NAME"; then
        log "ERROR: Failed to stop $SERVICE_NAME"
        mail_error "Domoticz cleanup FOUT: service stop" "Kon $SERVICE_NAME niet stoppen op $(hostname) om $(date)"
        exit 1
    fi
    sleep 10
    log "Service $SERVICE_NAME was not running"
fi
# Backup
BACKUP_PATH="${DB_PATH}.backup.$(date +%Y%m%d_%H%M%S)"
log "Creating database backup: $BACKUP_PATH"
if cp "$DB_PATH" "$BACKUP_PATH"; then
    log "Backup completed successfully"
    log "ERROR: Backup failed!"
    mail_error "Domoticz cleanup FOUT: backup failed" "Kon backup $BACKUP_PATH niet maken op $(hostname) om $(date)"
    sudo systemctl start "$SERVICE_NAME"
    exit 1
fi
# Database size before
SIZE_BEFORE=$(du -h "$DB_PATH" | cut -f1)
# Cleanup in transaction
log "Removing text device history older than $RETENTION_DAYS days"
CHANGES=$(sqlite3 "$DB_PATH" <<EOF
BEGIN TRANSACTION;
DELETE FROM LightingLog
 WHERE DeviceRowID IN (
     SELECT ID FROM DeviceStatus
      WHERE Type = 243 AND SubType = 19
 AND Date < datetime('now','localtime','-${RETENTION_DAYS} days');
SELECT changes();
COMMIT;
EOF
if [ $? -eq 0 ]; then
    log "$CHANGES records verwijderd"
    log "ERROR: Database cleanup failed!"
    mail_error "Domoticz cleanup FOUT: database cleanup" "Er is een fout opgetreden tijdens de database cleanup op $(hostname) om $(date). Backup wordt hersteld."
    mv "$BACKUP_PATH" "$DB_PATH"   # herstel backup
    exit 1
fi
# Optimize database
log "Starting database VACUUM"
if sqlite3 "$DB_PATH" "VACUUM;" 2>>"$LOG_FILE"; then
    log "Database VACUUM completed"
    log "WARNING: VACUUM failed"
    mail_error "Domoticz cleanup WAARSCHUWING: VACUUM" "VACUUM van de database is mislukt op $(hostname) om $(date)"
fi
# Database size after
SIZE_AFTER=$(du -h "$DB_PATH" | cut -f1)
# Start service
log "Starting Domoticz service"
if sudo systemctl start "$SERVICE_NAME"; then
    sleep 10
        log "Domoticz service successfully restarted"
        log "WARNING: Domoticz service could not be started"
        mail_error "Domoticz cleanup WAARSCHUWING: service start" "Domoticz service kon niet worden gestart op $(hostname) om $(date)"
    fi
    log "ERROR: Failed to start Domoticz service"
    mail_error "Domoticz cleanup FOUT: service start" "Kon Domoticz service niet starten op $(hostname) om $(date)"
fi
# Samenvatting
SUMMARY_TIME=$(date)
echo "======================================="
echo "CLEANUP VOLTOOID:"
echo "Tijd: $SUMMARY_TIME"
echo "Database grootte: $SIZE_BEFORE → $SIZE_AFTER"
echo "Records verwijderd: $CHANGES"
} | tee -a "$LOG_FILE"
log "Cleanup procedure completed"
Make the script executable with chmod +x /home/pi/scripts/cleanup_domoticz_text_devices.sh
Execute the cleanup once a week.
For testing an watching what happens: sh -x /home/pi/scripts/cleanup_domoticz_text_devices.sh
Edit crontab: crontab -e
# Voeg deze regel toe (elke zondag om 03:03)
3 3 * * 0 /path/to/cleanup_domoticz_text_devices.sh
This way you will end up with a cleaner database plus a weekly backup of your domoticz setup.
Example when using the script for the first time in my experimental domoticz setup:
-rw-r----- 1 pi pi 56864768 Sep 17 13:57 domoticz.db
-rw-r----- 1 pi pi 599420928 Sep 17 13:56 domoticz.db.backup.20250917_135552
Old database: 599.420.928 bytes = ≈ 571 MB
New database: 56.864.768 bytes = ≈ 54 MB (90% reduction)
In the production version:
6139904 17 sep 14:40 domoticz.db
9105408 17 sep 14:31 domoticz.db.backup.20250917_143127
33% reduction
To complete the swiping actions I have a RPI cleanup script.
#!/bin/bash
# system_cleanup_compact.sh - compacte en veilige systeemopschoning
LOG_FILE="/var/log/system_cleanup_compact.log"
echo "=== Compacte systeemopschoning gestart ==="
echo "Datum: $(date)"
# Schijfruimte vóór opschoning
before=$(df / | awk 'NR==2 {print $3}')
echo "📊 Schijfruimte vóór opschoning:"
df -h / | awk 'NR==1 || NR==2 {print}'
# Journal logs opschonen
sudo journalctl --vacuum-time=14d
sudo journalctl --vacuum-size=200M
# APT opschonen (apt-get gebruikt voor stabiele CLI)
sudo apt-get clean
sudo apt-get autoclean -y
sudo apt-get autoremove -y --purge
# Oude kernels verwijderen
sudo apt-get autoremove --purge -y
# Pi-hole onderhoud (veilig)
if command -v pihole &> /dev/null && [ -f "/etc/pihole/pihole-FTL.db" ]; then
    echo "🕳️ Pi-hole onderhoud..."
    sudo service pihole-FTL stop
    # Alleen echte tabel opschonen als die bestaat
    if sqlite3 /etc/pihole/pihole-FTL.db "SELECT name FROM sqlite_master WHERE type='table' AND name='FTL-queries';" | grep -q 'FTL-queries'; then
        echo "📋 Oude Pi-hole queries verwijderen (>30 dagen)..."
        sudo sqlite3 /etc/pihole/pihole-FTL.db "DELETE FROM 'FTL-queries' WHERE timestamp < strftime('%s','now','-30 days');"
        sudo sqlite3 /etc/pihole/pihole-FTL.db "VACUUM;"
        echo "ℹ️ Geen echte queries-tabel gevonden, overslaan"
    fi
    sudo service pihole-FTL start
fi
# Tijdelijke bestanden verwijderen
sudo find /tmp /var/tmp -type f -atime +7 -delete 2>/dev/null
# Oude logbestanden opschonen
sudo find /var/log -name "*.log.*" -type f -mtime +30 -delete 2>/dev/null
sudo find /var/log -name "*.gz" -type f -mtime +30 -delete 2>/dev/null
sudo find /var/log -name "*.old" -type f -mtime +30 -delete 2>/dev/null
# Schijfruimte na opschoning
after=$(df / | awk 'NR==2 {print $3}')
echo "📊 Schijfruimte ná opschoning:"
# Vrijgekomen ruimte berekenen
freed=$((before - after))
if [ $freed -gt 0 ]; then
    echo "💾 Vrijgemaakt: ${freed} KB (≈$((freed/1024)) MB)"
    echo "💾 Geen extra ruimte vrijgemaakt"
fi
echo "✅ Opschoning voltooid!"
echo "======================================"
In crontab: 4 4 * * 0 /home/pi/scripts/system_cleanup.sh
Now your RPI will be Spic & Span again.
Bugs bug me.
habahabahaba
Domoticz version: 2024.4
Re: Text devices make database grow
Post by habahabahaba »
And what to do people who r using windows? :)
More simple way to use API call from daVents script - /json.htm?type=command&param=clearlightlog&idx=<idx>
Domoticz version: 2026.3
Or set the Light/Switches Log history to the required retention days (default 30) through the settings page.
https://wiki.domoticz.com/Application_S ... og_History
Tukker
Post by Tukker »
habahabahaba wrote: Thursday 18 September 2025 9:05 More simple way to use API call from daVents script - /json.htm?type=command&param=clearlightlog&idx=<idx>
Where is that documented?
My problem is/was Dummy devices type TEXT which can grow rapidly.
Other devices are handled nicely by Domoticz itself without interference from the user as explained by Walter.
waltervl wrote: Thursday 18 September 2025 10:00 Or set the Light/Switches Log history to the required retention days (default 30) through the settings page.
Bugs bug me.
habahabahaba
HvdW wrote: Thursday 18 September 2025 23:07 Where is that documented?
Here
Tukker
Post by Tukker »
Thanks for the link.
Nice, but has functionality for display, not for shrinking the domoticz.db
Bugs bug me.
Did you test it?
It says clearlightlog so it deletes the log entries from the database for a specific IDX. Question is does it delete the complete log or just to the set retention time (default 30 days)?
habahabahaba
I've tested it.
Yes, It delets all entries from the DB for a specific IDX and text device displays the last got text
Tukker
Post by Tukker »
habahabahaba wrote: Friday 19 September 2025 13:09 I've tested it.
Show how to please.
Bugs bug me.
habahabahaba
HvdW wrote: Friday 19 September 2025 15:08 Show how to please.
How? :)
I have a Dummy Text sensor with idx 40.
Anj just put the link
http://<domoticz_ip_adress>/json.htm?type=command&param=clearlightlog&idx=40
into browser and thats all :) I have clear history log device displaying one last record
Tukker
Post by Tukker »
I had been looking in the dzvents wiki, not the JSON wiki
https://wiki.domoticz.com/Domoticz_API/ ... tory_log_2
Thanks for pointing it out.
Time to tune in on json.
Bugs bug me.
