SolarEdge production throttling from Domoticz
1kke
Re: SolarEdge production throttling from Domoticz
Post by 1kke »
gizmocuz wrote: Wednesday 13 August 2025 12:39 This is quite odd as there is no reference to 3.11 in the Dockerfile... 3.13 should be installed
This is what I find in the container (:beta):
sh-5.2# cd /usr/lib
sh-5.2# ls
apt dpkg git-core init locale lsb mime os-release python3.11 sasl2 ssl systemd terminfo tmpfiles.d udev x86_64-linux-gnu+
gizmocuz
Post by gizmocuz »
Could you try the new docker version? Went back to Python 3.11-slim image
eddieb
Post by eddieb »
It works again with the new image
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / Marstek Venus / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
1kke
Post by 1kke »
yes, pulled the :beta again (Version: 2025.1 (build 16758)
Build Hash: 79e16c172) and it's working for me also.
gizmocuz
Post by gizmocuz »
Thanks for the feedback! Aldo I am happy about this... It is strange that when using the Docker image python:slim (which uses python 3.13) it does not work...
eddieb
Post by eddieb »
tnx for fixing this @gizmocuz
1kke
Post by 1kke »
Weird thing is, I've build the image locally:
git clone https://github.com/domoticz/domoticz-docker.git
cd domoticz-docker
changed the Dockerfile:
FROM python:slim
and libpython3.9-dev to libpython3.13-dev
docker build -t domoticz:local .
and everything is running fine:
# ls /usr/local/bin
docker-entrypoint.sh  idle3	normalizer  pip3     pydoc   pydoc3.13	       pymodbus.server	   pyserial-miniterm  python	     python3	     python3.13
idle		      idle3.13	pip	    pip3.13  pydoc3  pymodbus.console  pymodbus.simulator  pyserial-ports     python-config  python3-config  python3.13-config
eddieb
Post by eddieb »
jvdz wrote: Sunday 22 June 2025 10:28 Just have a look at my first post in this thread which is updated with the latest Status.
I don't know if you can run multiple instances of the plugin on your setup, but i couldn't and had to add any extra docker container that performs the role of modbus proxy after which i can run multiple.
For each change you will have to Perform the pip command to update the docker with the requirement.txt content.
I have added the required command to customstart.sh :
  pip3 install -r /opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin/requirements.txt
so it is done with each creation of the domoticz container.
I am hoping that somebody with an battery installation can give me some feedback on the MetersDev branch whether or not those Selector switched work and are usefull.
I just today bumped on the 2 pollers to 1 modbus...
Can you share the docker compose yml for docker proxy ? The stuff I found does not work
jvdz
Domoticz version: 4.107
Post by jvdz »
Think it was pretty strait forward to get it to work for me.
This is what I use currently:
IPaddresses:
SolarEdge                 : 192.168.0.10
Host Docker Domoticz&proxy: 192.168.0.20
Docker modbusproxyYAML
services:
  modbusproxy:
    image: modbus-proxy:latest
    container_name: modbusproxy
    restart: unless-stopped
    ports:
      - 5020:502
    volumes:
      - /data/docker/modbusproxy/modbus-proxy.yml:/config/modbus-proxy.yml
File: /data/docker/modbusproxy/modbus-proxy.yml
devices:
- modbus:
    url: 192.168.0.10:502
  listen:
    bind: 0:502
Domoticz SOLAREDGEMODBUS PLUGIN setting:
Inverter IP Address:192.168.0.20
Inverter Port Number: 5020
eddieb
Post by eddieb »
needed to modify the compose.yaml a bit to run in dockge on my rpi5
services:
  modbusproxy:
    build: https://github.com/tiagocoutinho/modbus-proxy.git
    ports:
      - 1502:1502
    volumes:
      - /opt/stacks/modbusproxy/:/config/
networks: {}
seems to run, going to test now
michealabroy
Post by michealabroy »
You can monitor SolarEdge production in Domoticz, but throttling (limiting output) usually isn't supported directly. It depends on your inverter and API access.
eddieb
Post by eddieb »
the above compose.yaml for dockge works on rpi5
I am using the modbus-proxy.yml below to test
devices:
- modbus:
    url: 192.168.0.10:1502
  listen:
    bind: 0:1502
logging:
  version: 1
  formatters:
    standard:
      format: "%(asctime)s %(levelname)8s %(name)s: %(message)s"
  handlers:
    console:
      class: logging.StreamHandler
      formatter: standard
  root:
    handlers: ['console']
    level: DEBUG
jvdz
Post by jvdz »
michealabroy wrote: Friday 05 September 2025 7:50 You can monitor SolarEdge production in Domoticz, but throttling (limiting output) usually isn't supported directly. It depends on your inverter and API access.
It should work with this version of the plugin or are you having issues? It is not using the local web/api but the modbus interface of the solaredge inverter.
hjzwiers
Post by hjzwiers »
I replaced the old version 'domoticz-solaredge-modbustcp-plugin.2.0.4' with the new version 'domoticz-solaredge-modbustcp-plugin-MetersDev' ran the requirements file but now I think I have new versions of the devices in the overview, how do I recognize the old version so I can delete them?
I have an 3 phase inverter with 23 kw batteries and was seeing some errors concerning the metering, so I though why run the newer version.
Anyone have this problem?
Domoticz version: 2025.1
The ones not being updated anymore are the old ones. Should be noticable on the last seen date being old.
hjzwiers
Post by hjzwiers »
I deleted them all and add to the devices through a restart and the hardware switch.
hjzwiers
Post by hjzwiers »
I still get errors with the meters, its once a day. I have no idea where it is coming from:
2025-10-12 20:51:25.902 Error: SolarEdge ModbusTCP: Call to function 'onHeartbeat' failed, exception details:
2025-10-12 20:51:25.903 Error: SolarEdge ModbusTCP: Traceback (most recent call last):
2025-10-12 20:51:25.903 Error: SolarEdge ModbusTCP: File "/opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin-MetersDev/plugin.py", line 928, in onHeartbeat
2025-10-12 20:51:25.903 Error: SolarEdge ModbusTCP: _plugin.onHeartbeat()
2025-10-12 20:51:25.903 Error: SolarEdge ModbusTCP: File "/opt/domoticz/userdata/plugins/domoticz-solaredge-modbustcp-plugin-MetersDev/plugin.py", line 258, in onHeartbeat
2025-10-12 20:51:25.903 Error: SolarEdge ModbusTCP: meter = self.inverter.meters()[device_name]
2025-10-12 20:51:25.903 Error: SolarEdge ModbusTCP: ~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^
2025-10-12 20:51:25.903 Error: SolarEdge ModbusTCP: KeyError: 'Meter1'
2025-10-12 21:52:50.270 Error: Getting error 'Transport endpoint is not connected' while getting remote_endpoint in connection::start
After the error the system just goes on as usual
jvdz
Post by jvdz »
I will have a look tomorrow to see what it could be. Assume you have a battery as it is trying to work with the meters info?
hjzwiers
Post by hjzwiers »
Yes i have a SE10K inverter with 5 battery units and a SolarEdge meter in the electrical cabinet, I appreciate the help. i am running: domoticz-solaredge-modbustcp-plugin-MetersDev, and requirements.txt is run from within docker (and in the customstart.sh).
I just ran this version due to the newer files for the meters, which functionality does it have which is newer?
jannl
Domoticz version: 2025.5.x
Post by jannl »
I think I have a similar issue with the 'original' plugin. I realized it can have something to do with the timing settings in the hardware tab.
Not tested yet
