Time based Lua script
cjnicholl
Domoticz version: 2564
Post by cjnicholl »
I have a time based Lua script that is working fine BUT I don't need it to update every minute, every 30 or 60 minutes would be fine.
Is it possible to change how often a time based Lua script will run?
Mince Inside
Re: Time based Lua script
Post by Mince Inside »
Can you not change it to a shell script with JSON and stick it in cron?
Domoticz V2.2259
Raspberry Pi (B) with PiFace
RFXtrx433 USB
LighwaveRF relays, dimmer bulbs and light switches
Siemens On/Off 13A adaptors
Marmitek MS13E Motion (and Dusk) sensors
cjnicholl
Post by cjnicholl »
Well I'd never written a script at all before an hour ago so anything's possible :)
Is it simple to convert one to another?
Mince Inside
Can you post the lua script here?
Domoticz V2.2259
RFXtrx433 USB
cjnicholl
Post by cjnicholl »
Here you go:
time = os.date("*t")
if (timeofday['Sunrise']) then
        commandArray['Variable:Time-Variable']='Morning'
        print("Time set to Morning")
if (time.hour >= 12) then
        commandArray['Variable:Time-Variable']='Afternoon'
        print("Time set to Afternoon")
if (timeofday['Sunset']) then
        commandArray['Variable:Time-Variable']='Evening'
        print("Time set to Evening")
if (time.hour >= 22) then
        commandArray['Variable:Time-Variable']='Night'
        print("Time set to Night")
cjnicholl
Post by cjnicholl »
Nuts - The script isn't working.
Just checked the log and it hasn't set the Time-Variable to "Evening"
I assume this is because time.hour >= 12 is still true??
jannl
Domoticz version: 2025.5.x
Post by jannl »
Time >=12 is true between noon and midnight.
cjnicholl
Post by cjnicholl »
I tried Time = 12 and the script threw a wobbly. The only way I could get it to work was using Time >=12
What I am trying to achieve is:
Sunrise - Set Time-Variable to "Morning"
12.00 - Set Time-Variable to "Afternoon"
Sunset - Set Time-Variable to "Evening"
22.00 - Set Time-Variable to "Night"
jannl
Post by jannl »
I think your script should work, as far as I can recall the last setting to commandArray is used.
Do you see the print statements in the logging?
May be you should use else if's (please check the syntax of else if, not sure and not behind my home system)
cjnicholl
Post by cjnicholl »
The print statements work (I log everything so I can see what is or isn't working).
The only two actions that are working are the change to afternoon at 12.00 and the change to night at 22.00 so it could be the sunrise/sunset syntax.
jannl
Post by jannl »
It's timeofday['Nighttime'] and timeofday['Daytime'], not sunset/sunrise
See the wIKI
cjnicholl
Post by cjnicholl »
Ah - Ok.
Using daytime and nighttime has solved the original problem :D
Thanks!!
So far I have:
if (timeofday['Daytime']) then
if (timeofday['Nighttime']) then
New problem is that the variable changes twice each time because (of course) both "if" statements are true 8-)
D'rMorris
Post by D'rMorris »
That's where the elseif statement comes in ;), which exits at the first condition that is true. When using only IF's, then you can have indeed multiple true outcomes.
What you would want to use is:
IF
THEN
ELSEIF
THEN
END
I rewrote your code a bit, see below. Please note: you'll still have an issue for the time between 00:00 and the daytime the next day.
Now, this time falls in category "evening" (because it is nighttime and before 22:00). Your "time.hour >= 22" is only valid until 00:00, after that a new day starts and then the condition "nighttime" becomes true and that sets your variable to "evening". That should be fixed with the last elseif.
if (timeofday['Daytime']) and (time.hour < 12)
then
elseif (timeofday['Daytime']) and (time.hour >= 12)
then
elseif (timeofday['Nighttime']) and (time.hour < 22)
then
elseif (timeofday['Nighttime']) and (time.hour >= 22)
then
then
cjnicholl
Post by cjnicholl »
That's great - Thanks very much :)
I haven't found any reference to "ELSEIF" in the various Wikis...
What would happen if you just replaced:
elseif (timeofday['Nighttime']) and (time.hour >= 22) then
With:
elseif (timeofday['Nighttime']) then
Does it need both?
D'rMorris
Post by D'rMorris »
Well, that depends on what you want to do. timeofday['Nighttime'] and timeofday['Daytime'] are system-filled variables and they depend on the cosmos.
So, "nighttime" starts earlier during wintertime and later during summertime. The opposite goes for daytime of course.
In the summer, sometimes the "nighttime" only starts around 22:15 CET. This would render this statement useless (simply because it will never be true):
then
So indeed, you could replace the last 2 ones with just 1. However, in the summer it might be the case that it switches from afternoon to night, simply because "nighttime" can start later than 22:00 during summer.
New script:
then
then
then
then
jannl
Post by jannl »
Slimste is om allebei te controleren. Of goed checken of op jou locatie ook de 22;00 gehaald wordt.
Als ik goed zoek, wordt het in Geleen bijvoorbeeld net niet 22:00 voor wat betreft zonsondergang, ligt een beetje eraan hoe Domoticz dat doet.
Gebruikte site: http://www.zonsondergang-tijden.nl/
cjnicholl
Post by cjnicholl »
The idea was for "Morning" & "Evening" to be flexible based on sunrise & sunset times (the variables are going to form the backbone for some automated outdoor lighting).
In the UK sunset doesn't get any later than about 21:20 in the summer so the "Evening" setting would still work, however briefly :)
I had this working in Blockly but decided it was high time I learned some basic scripting.
Thanks for all your help.
D'rMorris
Post by D'rMorris »
jan_nl wrote:Slimste is om allebei te controleren. Of goed checken of op jou locatie ook de 22;00 gehaald wordt.
Just an example. In Sittard (hi, neighbor ;)) I have the same cosmos times as you, but in other countries (we have users in Sweden for example), the times may be different.
By the way, I think I had some sunsets later than 22:00, but I'm not sure. Never mind, if you are sure that it'll never be later than 22:00, you're safe when using 22:00 as a hard deadline.
Is the script the way it is now OK for you? LUA is indeed the better option when you want to do more advanced processing. Blockly is very nice for the simple if-then-else statements, but complexer stuff resides better in LUA.
Tip: use Sublime Text 3 (or another editor) so that you can quickly check your code. Like this:
cjnicholl
Post by cjnicholl »
From what I can see the script is working fine (morning changed to afternoon as expected) :D
I will definitely have a look at Sublime Text, at the moment I'm using a text editor in a linux terminal!
D'rMorris
Post by D'rMorris »
Did that as well before, but typing in an editor that gives you visual feedback and even maybe syntax checks works so much better!
After you're done, simply copy paste to terminal and check Domoticz logs. If there are errors, it gives you the line number which you can then check in your editor.
