Carefully reviewing your conf file, you're using the same MQTT server for both client and slave. It's possible to set Domoticz up like this BUT you have to differentiate both instances, for example naming one domoticz-master and the other domoticz-slave (giving domoticz-master/out and domoticz-slave/out). This way, you don't intermix things that are by essence different, and avoid some amazing side effect...
Or, you may have better to declare one MQTT broker on master and one other on slave. This way, they can have the same topics, as they are fully separated. In addition, having a local instance on slave helps when master crashes.
Using MQTT for comm between Domoticz instances
FlyingDomotic
- Domoticz version: 2020.2
- Domoticz version: 2026.3
Re: Using MQTT for comm between Domoticz instances
Having 2 mqtt servers in your network seems a little bit strange... Better have them to write to different topics (like the examples you have given domoticz-master/out and domoticz-slave/out)
FlyingDomotic
Not so strange: I have one for production, one for tests, and sometimes one other to do specific things. Having them separated helps (and probably avoid some catastrophes).waltervl wrote: Monday 14 July 2025 16:32 Having 2 mqtt servers in your network seems a little bit strange... Better have them to write to different topics (like the examples you have given domoticz-master/out and domoticz-slave/out)
In addition, as I have multiples machines, I do prefer having a local instance, to help having a good availability when network or remote serverhas an issue.
I understand for test purposes but for syncing production data you normally use 1 MQTT server in your network to connect to.
For communication between Domoticz instances in your network it is even easier is to use the out-of-the-box device sharing without MQTT....
willemd
I was just following installation guidelines ....FlyingDomotic wrote: Monday 14 July 2025 16:09 Carefully reviewing your conf file, you're using the same MQTT server for both client and slave. It's possible to set Domoticz up like this BUT you have to differentiate both instances, for example naming one domoticz-master and the other domoticz-slave (giving domoticz-master/out and domoticz-slave/out). This way, you don't intermix things that are by essence different, and avoid some amazing side effect...
Anyway it is clear to me know and maybe others in future can benefit from this thread and the issues encountered/solved. Thanks.
FlyingDomotic
Doc is probably not so clear. I'll add a paragraph to avoid misadventure you had.
