Python Plugin: MqttMapper
FlyingDomotic
Re: Python Plugin: MqttMapper
Post by FlyingDomotic »
So, if I correctly understood, value loaded into device "MQTT mapper - T_Outside" is correct. right?
Is there another help we may provide to you?
hjzwiers
Post by hjzwiers »
Yes, it is correct!
I only wonder how to convert this value to a valid temperature, including if the value is different as I had observed earlier.
FlyingDomotic
First of all, you have to check that virtual device plug-in is loaded into Domoticz:
  • goto "Setup/Hardware" tab
  • check if a line with type "Dummy (Does nothing, use for virtual switches only)" exists
  • if not, create one by going into lower part of screen, setting "name" to "Virtual devices", choosing "type" = "Dummy (Does nothing, use for virtual switches only)", and clicking on "Add"
Then click on "Create virtual sensors" just after ""Dummy (Does nothing, use for virtual switches only)" text
In the popup windows, give a device name (like "Outside temperature") and set "Sensor type" to "Temperature", then click on "Ok"
Congrats, you've just created a brand new virtual temperature sensor!
Now, goto "Setup/More options/Events", click on "+/LUA/device".
In the script windows, you'll see something like:
-- Domoticz passes information to scripts through a number of global tables
-- device changed contains state and svalues for the device that changed.
--   devicechanged['yourdevicename'] = state
--   devicechanged['svalues'] = svalues string
-- otherdevices, otherdevices_lastupdate and otherdevices_svalues are arrays for all devices:
--   otherdevices['yourotherdevicename'] = "On"
--   otherdevices_lastupdate['yourotherdevicename'] = "2015-12-27 14:26:40"
--   otherdevices_svalues['yourotherthermometer'] = string of svalues
-- uservariables and uservariables_lastupdate are arrays for all user variables:
--   uservariables['yourvariablename'] = 'Test Value'
--   uservariables_lastupdate['yourvariablename'] = '2015-12-27 11:19:22'
-- other useful details are contained in the timeofday table
--   timeofday['Nighttime'] = true or false
--   timeofday['SunriseInMinutes'] = number
--   timeofday['Daytime'] = true or false
--   timeofday['SunsetInMinutes'] = number
--   globalvariables['Security'] = 'Disarmed', 'Armed Home' or 'Armed Away'
-- To see examples of commands see: http://www.domoticz.com/wiki/LUA_commands#General
-- To get a list of available values see: http://www.domoticz.com/wiki/LUA_commands#Function_to_dump_all_variables_supplied_to_the_script
-- Based on your logic, fill the commandArray with device commands. Device name is case sensitive.
-- loop through all the changed devices
for deviceName,deviceValue in pairs(devicechanged) do
    print ("Device based event fired on '"..deviceName.."', value '"..tostring(deviceValue).."'");
--    if (deviceName=='myDevice') then
--        if deviceValue == "On" then
--            print("Device is On")
--        elseif deviceValue == "Off" then
--            commandArray['a device name'] = "On"
--            commandArray['another device name'] = "Off AFTER 10"
--            commandArray['Scene:MyScene'] = "Off"
--            commandArray['Group:My Group'] = "Off AFTER 30"
--        end
--    end
Select everything and replace text by:
    if (deviceName=='MQTT mapper - T_Outside') then
        temperature = string.match(deviceValue, '[0-9%.]+')
        print("Outside temperature "..temperature)
        commandArray[#commandArray + 1] = {['UpdateDevice']= otherdevices_idx["Outside temperature"]..'||'..temperature}
You may change script name from "Script #1" to something like "Outside temperature".
To save the script, click on "Save".
You can then test that any change made in "MQTT mapper - T_Outside" is properly extracted and reflected into "Outside temperature".
FYI, string.match will return every "0" to "9" and "." characters from "MQTT mapper - T_Outside" data, and commandArray syntax will load this extracted data into "Outside temperature" device.
Don't hesitate to ask questions, should you need more details.
hjzwiers
Post by hjzwiers »
I have a lot of experience with domoticz by now, but this was a perfect guideline.
Built a script for the Room temperature and Outside temperature within 15 minutes.
Right now its in the version without the parathesis, but when it changes I'll check if it still works.
Thanks a lot for your help!!
vco1
Post by vco1 »
First of all, thanks for this great plugin. It's a Swiss army knife.
I'm trying to implement a bluetooth (BLE) tracker as a presence tracker in Domoticz with the TheengsGateway as the intermediary. These trackers don't provide an on/off value, but instead just the rssi value. If the rssi element in the json contains a value, the tracker is present (On). If rssi is missing from the message, the tracker is not present (Off).
I'm struggling how to implement this in MQTTMapper. As far as I understood, there is no way to check for the presence of an element in the json.
In pseudocode I'm looking for something like this (which is actually in the payload for Homeassistant auto disovery):
if value_json.get('rssi') -%}home{%- else -%}not_home{%- endif %}
Domoticz version: 2026.3
vco1 wrote: Thursday 26 June 2025 9:47 First of all, thanks for this great plugin. It's a Swiss army knife.
the TheengsGateway supports the Homeassistant autodiscover protocol that Domoticz also supports. It just could create some sensor automatically. Did you already try that? Although funky value templates with if then else are not supported.
https://wiki.domoticz.com/MQTT#Add_hard ... Gateway%22
vco1
Post by vco1 »
waltervl wrote: Thursday 26 June 2025 14:43 the TheengsGateway supports the Homeassistant autodiscover protocol that Domoticz also supports. It just could create some sensor automatically. Did you already try that? Although funky value templates with if then else are not supported.
Yes, I did try the autodiscover protocol. That's what I'm using for other sensors (MiPlant). However, DOmoticz doesn't seem to support trackers, like Tile or NUT. So for that I'm using MQTTMapper.
The code is from the HAS Autodiscover payload. I only included that as a reference for the logic I'd like to add to MQTTMapper.
Clear, lets wait for FlyingDomoticz if he nows a rule for
FlyingDomotic
You may use "select" or "reject" to get/ignore certain (list of) value(s) but there's no "any" nor "defined" existing.
As of now, easiest way is to do as specified in previous post, that is copy the whole message into a text variable and write a small LUA/dzVents scritp that analyze message content and define a virtual device into Domoticz.
I may help if needed.
vco1
Post by vco1 »
I got it working by creating a (hidden) text device with the full payload, a virtual device for the status and a dzVents script to tie it all together. In the end the biggest hurdle was the fact that I didn't get any logging from the dzVents script and thus had to do it by trial and error.
FlyingDomotic
"print" function or domoticz_LOGxxx may help to debug dzVents...
vco1
Post by vco1 »
I had several log statements in my script. Nothing got logged though. And yes, I did check all the settings. Even set the log level on the commandline tot debug and restarted domoticz. To no avail.
Perhaps better do discuss this in a new topic. But dzvents logging should work. For test you can use the logging template script that is available when creating a new dzvents script from the event script editor. See also for example viewtopic.php?p=325700#p325700
WBeulink
Domoticz version: 2024.7
Post by WBeulink »
Is there a way to let the plugin use Encryption in the connection to the MQTT-server?
Willem
RP5 - Bookworm - Domoticz 2025.1 and Latest Beta - Z-Wave JS UI. On Docker
Willem
FlyingDomotic
As of now, the answer is no.
I guess you want to use a certificate to connect to MQTT?
WBeulink
Post by WBeulink »
FlyingDomotic wrote: Tuesday 01 July 2025 18:16 As of now, the answer is no.
Yes. Would be nice in case of connecting to remote servers with that extra bit of security.
Willem
FlyingDomotic
When using a Domoticz python plug-in, the only options we have is to use MQTTS (meaning MQTT over TLS), but, as far I know, now way to specify any certificate.
I didn't test yet using PahoMQTT (which allow certificates) instead of Domoticz MQTT, but I'll try it. Not so sure it 'll work ...
Stay tuned!
FlyingDomotic
After first set of tests, it seems possible to use "standard" Paho MQTT library in a Domoticz Python plugin.
However, Ii still need rewriting part of logic, as this library does automatic reconnection (while Domoticz doesn't), and to test main failure scenario in order to ensure this will work smoothly for you.
After this, I need to add support of certificates in MqttMapper.
I put this in my ToDo list, you should get a new version in some weeks.
RNEE
Domoticz version: 2026.1
Post by RNEE »
@flyingdomotic
can you help me with creating a json description for my Homebattery ?
I have posted my finding here :
viewtopic.php?p=327097#p327097
Thank you !
Domoticz (since 2016) on Docker on Raspberry PI 5 with 500 Gb NVMe|Milight|KaKu + RFXCOM|Goodwe|Smartstuff P1 meter|Buienradar|Afval kalender|Tuya-wifi|Zigbee + deCONZ Conbee II|Marstek Homebattery 5,12Kwh via Modbus on Pusr-dr134|MQTTMapper|Quatt v2|
FlyingDomotic
I did answer (but the way definition is done is not supported).
