Meteoserver sun radiation
Tukker
Domoticz version: 2023.2
Post by Tukker »
It is a challenge to optimize the percentage direct use from the PV panels.
One way is to know when the sun shines and how much the global radiation intensity is in Watt per m2
At Meteoserver the data can be obtained like
https://data.meteoserver.nl/api/solar.php?locatie=Utrecht&key=abcd1234
using your own (free) key.
The API allows 500 free calls per month, like one call per 2 hours.
My suggestion
Can you build a Meteoserver sun radiation hardware addon like the Enever addon
PS
I can build something python or something dzVents but I don't know how and cannot find how I can create a sensor like the Enever one with bar charts.
PPS
Here is a dzVents script that fills a text Sensor
You can edit the name of the textSensor, the API key and the local threshold = 400 -- Minimal 400 W/m² to be "Sunny" gelden
        timer = {'every 2 hours'},
        httpResponses = {'meteoserver_api_call'}
    data = {
        lastUpdate = { initial = '' }
        local api_url = "https://data.meteoserver.nl/api/solar.php?locatie=Utrecht&key=abcd1234"
        -- Functie om tijdvakken met hoge straling te vinden
        local function findSunnyPeriods(forecastData)
            local threshold = 400 -- Minimaal 400 W/m² om als "zonnig" te gelden
            local sunnyHours = {}
            -- Identificeer alle uren boven de drempelwaarde
            for _, hour in ipairs(forecastData) do
                if tonumber(hour.gr_w) >= threshold then
                    table.insert(sunnyHours, {
                        time = hour.time,
                        cet = hour.cet,
                        gr_w = hour.gr_w
            -- Groepeer aaneengesloten uren
            local periods = {}
            if #sunnyHours > 0 then
                local startTime = sunnyHours[1].time
                local endTime = startTime
                local currentGr = sunnyHours[1].gr_w
                for i = 2, #sunnyHours do
                    if sunnyHours[i].time - sunnyHours[i-1].time <= 3600 then -- Max 1 uur verschil
                        endTime = sunnyHours[i].time
                        currentGr = currentGr + sunnyHours[i].gr_w
                        table.insert(periods, {
                            start = os.date("%H:%M", startTime),
                            eind = os.date("%H:%M", endTime),
                            straling = math.floor(currentGr / ((endTime - startTime)/3600 + 1)) -- Gemiddelde W/m²
                        startTime = sunnyHours[i].time
                        endTime = startTime
                        currentGr = sunnyHours[i].gr_w
                -- Voeg laatste periode toe
            -- Sorteer periodes op stralingsintensiteit (hoog naar laag)
            table.sort(periods, function(a, b) return a.straling > b.straling end)
            return periods
        -- API-aanvraag bij timer-event
        if (item.isTimer) then
            domoticz.openURL({
                url = api_url,
                method = 'GET',
                callback = 'meteoserver_api_call'
        -- Verwerk API-respons
        elseif (item.isHTTPResponse and item.ok) then
            local json = item.json
            if (json and json.current and json.current[1]) then
                local current = json.current[1]
                local now = os.date("%H:%M")
                -- Bouw basisbericht
                local sensor_text = "🌡️ Nu: " .. current.temp .. "°C | "
                sensor_text = sensor_text .. "☁️ " .. current.tc .. "% | "
                sensor_text = sensor_text .. "☀️ " .. current.gr_w .. " W/m²\n\n"
                -- Voeg komende 3 uur toe (vandaag)
                sensor_text = sensor_text .. "⏳ Komende uren:\n"
                local hours_added = 0
                for _, hour in ipairs(json.forecast) do
                    if os.date("%Y-%m-%d", hour.time) == os.date("%Y-%m-%d") then
                        sensor_text = sensor_text .. os.date("%H:%M", hour.time) .. ": " .. hour.gr_w .. " W/m²\n"
                        hours_added = hours_added + 1
                        if hours_added >= 3 then break end
                -- Analyseer morgen
                local tomorrow_forecast = {}
                    if os.date("%Y-%m-%d", hour.time) == os.date("%Y-%m-%d", os.time() + 86400) then
                        table.insert(tomorrow_forecast, hour)
                local sunny_periods = findSunnyPeriods(tomorrow_forecast)
                -- Voeg beste zonperiodes toe
                sensor_text = sensor_text .. "\n🔆 Morgen optimaal:\n"
                if #sunny_periods > 0 then
                    for i, period in ipairs(sunny_periods) do
                        if i <= 3 then -- Toon max 3 beste periodes
                            sensor_text = sensor_text .. period.start .. "-" .. period.eind .. ": " .. period.straling .. " W/m² gem.\n"
                    sensor_text = sensor_text .. "Geen sterke zonneschijn verwacht\n"
                -- Update sensor
                domoticz.devices("Zonnestraling").updateText(sensor_text)
                domoticz.log("Zonnestraling bijgewerkt om " .. now, domoticz.LOG_INFO)
Bugs bug me.
Domoticz version: 2026.3
Re: Meteoserver sun radiation
If you are in the Netherlands you can use the Buienradar integration. https://wiki.domoticz.com/Buienradar
It has a sun power sensor.
Tukker
Post by Tukker »
waltervl wrote: Sunday 08 June 2025 13:07 If you are in the Netherlands you can use the Buienradar integration. https://wiki.domoticz.com/Buienradar
Thanks Walter, didn't know that.
However it doesn't include a sunpower prediction.
The prediction is what I am looking for to be able to switch on washing machine, dishwasher and other devices at the optimal hours.
The EV is already automated to charge whenever there is a surplus of energy. (except when full or not connected)
Bugs bug me.
Tukker
Post by Tukker »
I updated the Sunpower script.
        timer = {
            'every 3 hours'
        httpResponses = {
            'solar_data'
    execute = function(domoticz, trigger)
        -- Configuratie
        local powerThreshold = 50  -- Drempelwaarde voor weergave (W/m²)
        local daysToShow = 3      -- Aantal dagen om weer te geven (inclusief vandaag)
        local maxDays = 6         -- Maximum aantal dagen dat kan worden weergegeven
        -- Beperk het aantal dagen tot het maximum
        daysToShow = math.min(daysToShow, maxDays)
        -- Helper functie voor spaties
        local function spaces(count)
            return ("&nbsp;"):rep(count)
        -- Bereken gecorrigeerde zoninstraling
        local function calculateAdjustedIrradiance(hourData)
            local gr_w = tonumber(hourData.gr_w) or 0
            local lc = tonumber(hourData.lc) or 0
            local mc = tonumber(hourData.mc) or 0
            local hc = tonumber(hourData.hc) or 0
            local lowCloudFactor = 0.85
            local midCloudFactor = 0.60
            local highCloudFactor = 0.30
            local cloudAttenuation = (lc*lowCloudFactor + mc*midCloudFactor + hc*highCloudFactor) / 100
            cloudAttenuation = math.min(cloudAttenuation, 0.9)
            return math.floor(gr_w * (1 - cloudAttenuation) + 0.5)
        local function generateBar(value)
            local adjustedValue = value or 0
            local symbol = adjustedValue >= 100 and "■" or "|"
            local coloredSymbol = "<span style='color:#FFA500'>"..symbol.."</span>"
            -- Bepaal aantal symbolen (1 voor 50-99, meer voor hogere waarden)
            local count = adjustedValue >= 100 and math.floor(adjustedValue/100) or 1
            -- Alleen tonen als boven drempelwaarde (50)
            return adjustedValue >= 50 and string.rep(coloredSymbol, count) or ""
        -- Hoofdlogica
        if trigger.isTimer then
            domoticz.openURL({
                url = 'https://data.meteoserver.nl/api/solar.php?locatie=Utrech&key=abcd1234',
                method = 'GET',
                callback = 'solar_data'
        elseif trigger.isHTTPResponse then
            local data = trigger.json
            if not data then return end
            -- Bepaal datums die we willen tonen (van vandaag tot vandaag + daysToShow-1)
            local datesToDisplay = {}
            for i = 0, daysToShow-1 do
                table.insert(datesToDisplay, os.date('%d-%m-%Y', os.time() + 86400 * i))
            local outputLines = {}
            local totalDataLineCount = 0  -- Totaal teller voor dataregels
            for dayIndex, currentDate in ipairs(datesToDisplay) do
                -- Verzamel alle data voor deze datum
                local dateData = {}
                for _, hour in ipairs(data.forecast) do
                    if string.sub(hour.cet, 1, 10) == currentDate then
                        table.insert(dateData, hour)
                -- Voeg datumheader toe (alleen inspringen vanaf 2e dag)
                local dateHeader = "Verwachte zoninstraling ("..currentDate.."):"
                if dayIndex > 1 then dateHeader = spaces(15)..dateHeader end
                table.insert(outputLines, dateHeader)
                -- Voeg kolomheaders toe (zelfde inspringing als datumheader)
                local columnHeader = "Uur   Origineel    Gecorrigeerd"
                if dayIndex > 1 then columnHeader = spaces(15)..columnHeader end
                table.insert(outputLines, columnHeader)
                -- Voeg scheidingslijn toe (zelfde inspringing)
                local separator = "-----------------------------"
                if dayIndex > 1 then separator = spaces(15)..separator end
                table.insert(outputLines, separator)
                local dateDataLineCount = 0  -- Teller voor dataregels per datum
                for _, hour in ipairs(dateData) do
                    local time = string.sub(hour.cet, 12, 16)
                    local original = tonumber(hour.gr_w) or 0
                    local adjusted = calculateAdjustedIrradiance(hour)
                    if adjusted >= powerThreshold then
                        dateDataLineCount = dateDataLineCount + 1
                        totalDataLineCount = totalDataLineCount + 1
                        local lineContent = string.format(
                            "%s %03d W/m²   %03d W/m² %s",
                            time,
                            original,
                            adjusted,
                            generateBar(adjusted)
                        -- Alle regels inspringen vanaf 2e dag
                        if dayIndex > 1 then lineContent = spaces(15)..lineContent end
                        -- Voor de eerste dag: eerste 2 dataregels zonder extra inspringing, daarna met
                        if dayIndex == 1 and dateDataLineCount > 2 then
                        table.insert(outputLines, lineContent)
                -- Voeg melding toe als geen data beschikbaar is voor deze datum
                if dateDataLineCount == 0 then
                    local noDataMsg = "Geen significante zoninstraling verwacht"
                    if dayIndex > 1 then noDataMsg = spaces(15)..noDataMsg end
                    table.insert(outputLines, noDataMsg)
                -- Voeg lege regel toe tussen datums, behalve na laatste datum
                if currentDate ~= datesToDisplay[#datesToDisplay] then
                    table.insert(outputLines, "")
            domoticz.devices('Zonnestraling').updateText(table.concat(outputLines, "\n"))
It gives nice information for your local sun radiation expectations.
Sun radiation corrected for your local cloud coverage, high, medium and low clouds.
Bugs bug me.
RonkA
Domoticz version: 2025.1
Post by RonkA »
I like what i see from the fore last script, i am curious how correct the prediction will be, but it looks a lot easier than the daily lookup of the sun graph from Weeronline..
The thing i don't like from the 'mainstream' weather-models is the fact that the nearest weather-station is 28 kilometer away from my home resulting in incorrect values and predictions..
SolarEdge ModbusTCP - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20
Work in progress = Life in general..
Tukker
Post by Tukker »
RonkA wrote: Monday 09 June 2025 21:01 The thing i don't like from the 'mainstream' weather-models is the fact that the nearest weather-station is 28 kilometer away from my home resulting in incorrect values and predictions..
In my case it's 15 kilometers.
I adapted the script to catch the real values in the log.
            if debugMode then
            local debugLines = {
                "DEBUG VERGELIJKING (225Wp panelen, 15 jaar oud, 95% rendement):",
                "Tijd   Origineel  Geschat  Gecorrigeerd  Geschat  Werkelijk"
                    if string.sub(hour.cet, 1, 10) == os.date('%d-%m-%Y') then
                        if adjusted >= 50 or original >= 50 then
                            table.insert(debugLines, string.format(
                                "%s  %3dW/m² %5dW  %3dW/m² %5dW  %s",
                                string.sub(hour.cet, 12, 16),
                                original, schatVermogen(original),
                                adjusted, schatVermogen(adjusted),
                                "--"  -- Hier later je werkelijke meting invullen
                domoticz.log(table.concat(debugLines, "\n"), domoticz.LOG_INFO)
Because of the distance and the one hour prediction I'll have to wait for weather circumstance where there is a stable clear sky or stable cloud coverage during several hours and check where the log output can help me understand.
EDIT
Adapted the script again.
The script runs every 2 hours at daytime.
It compares sun radiation and cloud coverage at hour 0, hour 1 and hour2.
If these are equal we have stable circumstances (even at 15 km distance from the nearest weather station)
It collects WhToday from the inverter at hour 0 and hour 2.
These data (if equal) are stored in a file sun_radiation_impact.csv
The header of the file (the collected data) is this
Timestamp;StartUur;EindUur;Origineel (W/m²);Gecorrigeerd (W/m²);Bewolking (%);WhVerschil
In a few months time the data can be analyzed.
Bugs bug me.
