ON for x minutes in Scenes
Hansbit
Post by Hansbit »
Is it possible to add a 'ON for x minutes' in Scenes?
I use it often in DzVents, but unfortunately not available in the scenes.
Scherm­afbeelding 2025-06-01 om 21.24.36.png (209.65 KiB) Viewed 3633 times
Hansbit
Re: ON for x minutes in Scenes
Post by Hansbit »
Hmm... meanwhile found out that it is already possible in Scenes!
Switch on and fill out the number of seconds at 'Off delay'.
Scherm­afbeelding 2025-06-01 om 21.43.38.png (86.4 KiB) Viewed 3625 times
Then it switches on, and off after x seconds. Thanks.
Domoticz version: 2026.3
Scenes cannot be switched Off, only On. With scenes you can set several devices in different states (Both On, Off or at a level) so there is no Off state for scene. You have to create another scene to set the devices in another state.
