(SOLVED) Convert LUA script into dzVents
costo
Domoticz version: 2025.1
Post by costo »
New to dzVents, made a LUA script a few years ago to extract cpm, temperatue and uptime
this script works fine but I'm trying to convert this script into dzVents.
The uRadmonitor sensor on '192.168.178.26/j' generates this json format line
{"data":{ "id":"12000059","type":"1","detector":"SI29BG","cpm":9,"temperature":29.31,"uptime": 1407157}}
My first try is to extract the cpm value , the sensorname is cpmCount
apparently the json decoding is not right becouse cpmCount is always zero
local IP = '192.168.178.26' -- uRadmonitor sensor IP
	active = true,
		timer = { 'every minute' },
		httpResponses = { 'cpmRetrieved' } -- matches callback string below
		if (item.isTimer) then
			domoticz.openURL({
				url = 'http://' .. IP .. '/j',
				method = 'GET',
				callback = 'cpmRetrieved',
    elseif (item.isHTTPResponse) then
			if (item.ok) then -- and item.isJSON) then -- statusCode == 2xx
            -- if (item.statusCode==0) then
			    local Count = item.data.cpm
			    domoticz.log('status = ',tonumber(Count))
			    domoticz.devices('cpmCount').updateCustomSensor(Count)
any suggestion can help me.
log output:
2025-05-11 21:57:00.216 dzVents: Handling httpResponse-events for: "cpmRetrieved"
2025-05-11 21:57:00.216 dzVents: ------ Start internal script: cpm_dzvents: HTTPResponse: "cpmRetrieved"
2025-05-11 21:57:00.216 dzVents: status =
2025-05-11 21:57:00.217 dzVents: ------ Finished cpm_dzvents
Re: Convert LUA script into dzVents
You can log the table item.data to see what is in it.
Also the log statement you are using is not correct, it should be
domoticz.log('status = ' .. Count)
costo
Post by costo »
If I write 'domoticz.log('status = ' .. Count) ' then i see this error
2025-05-11 23:29:00.346 Error: dzVents: An error occurred when calling event handler cpm_dzvents
2025-05-11 23:29:00.346 Error: dzVents: ...moticz/scripts/dzVents/generated_scripts/cpm_dzvents.lua:26: attempt to concatenate a nil value
I tried to log the table but i was not succesfull
You should be able to see the complete data with log statement.
domoticz.log(item.data,dz.LOG_FORCE)
It could be that you have to use data twice to get the count eg
local Count = item.data.data.cpm
costo
Post by costo »
negative, both lines give an Error : attempt to index a nil value (global 'dz') or (field 'data')
print (item.data) prints the line as seen in the browser,
print (item.data.id),
print (item.data.cpm),
print (item.data.temperature),
print (item.data.uptime),
all are nil values.
habahabahaba
Domoticz version: 2024.4
Post by habahabahaba »
costo wrote: Monday 12 May 2025 0:22 negative, both lines give an Error : attempt to index a nil value (global 'dz') or (field 'data')
all are nil values.
According to https://jsonparser.org/ you have some incorrect values. It should be
{"data":{ "id":"12000059","type":"1","detector":"SI29BG","cpm":"9","temperature":"29.31","uptime": "1407157"}}
Try to put to Dzvents script this:
if (item.isJSON) then...
to check if Dz understandig incoming Json or not.
The error in the log line is my fault
It should be
domoticz.log(item.data,domoticz.LOG_FORCE)
And if item.data shows data entry in the JSON I believe you should use data twice like
print (item.data.data.cpm)
costo
Post by costo »
Using this:
	if (item.ok  and item.isJSON) then -- statusCode == 2xx
			    print ('cpm = '..item.data.data.cpm)
which gives an error in the print() line so apparently the data is recognized as json .
In the link jparser.org I can put the data line and the parser makes this of it
data {6}
type : 1
detector : SI29BG
cpm : 9
temperature : 29.31
uptime : 1407157
that looks very usefull but upto now I only get nil value errors
in the log this line:
!Info: {"data":{ "id":"12000059","type":"1","detector":"SI29BG","cpm":9,"temperature":34.31,"uptime": 1462644}}
costo
Post by costo »
For completeness this is the LUA script that works fine for many years
-- Script to calculate average CPM
local idxUptime = 14                -- idx of Uptime
local idxCpm    = 15                -- idx of simpel cpm1
local idxWA     = 16                -- idx of wAverage30
local idxTemp   = 13                -- idx of Tempsensor
local cpm = " "				        -- counts in last minute
local uptime = " "			        -- in seconds
local temperature = " "
local cpmWalkAv = 'WAcpm'           -- WAcpm user variable
local IPcpm =   '192.168.178.26'    -- change IP here
-- NOTE: Fetch data from external servers without locking the event system!
-- see https://www.domoticz.com/forum/viewtopic.php?t=19327
commandArray={}
	json = (loadfile "/home/co/domoticz/scripts/lua/JSON.lua")()			-- JSON library on user 'co'
	  local jsondata    = assert(io.popen('curl http://' .. IPcpm .. '/j'))	-- open URADmonitor
	  local jsondevices = jsondata:read('*all')								-- read 'data'
	jsondata:close()	                                                    -- close URADmonitor
      -- print ('devices =' .. jsondevices)
    local jsonCPM = json:decode(jsondevices)								-- decode json string
    if (jsonCPM ~= nil) then                                                -- jsonCPM is a table                  --
        cpm = jsonCPM.data.cpm													-- cpm
 	    uptime = jsonCPM.data.uptime
        temperature = math.floor(10*(jsonCPM.data.temperature + .05))/10        -- temp in tenth degrees
        wAverage30 = tonumber(uservariables[cpmWalkAv])							-- load old WAcpm_uservar
        wAverage30 = (29 * wAverage30 + cpm)/30									-- calculate new WAcpm_uservar
        wAverage30 = tonumber(string.format("%." .. 2 .. "f", wAverage30))		-- format 2 digits after dot
        commandArray['Variable:' .. cpmWalkAv] = tostring(wAverage30)			-- update new WAcpm_uservar every minute
        time = os.date("*t")
        if  (((time.min+1) % 1)==0)  then         -- update devices every 5 minutes. 1,6,11,16,21,26
            uptime = math.floor(uptime/60)
            commandArray[1] = {['UpdateDevice'] = idxUptime .. '|0|' .. uptime}		-- in minutes
            commandArray[2] = {['UpdateDevice'] = idxTemp .. '|0|' .. temperature}	-- T
            commandArray[4] = {['UpdateDevice'] = idxCpm .. '|0|' .. cpm}			-- send cpm cnt/min
            commandArray[5] = {['UpdateDevice'] = idxWA .. '|0|' .. wAverage30}		-- send wAverage30
habahabahaba
Fully working example with JSON:
-- TEST
		timer = {
			'every minute' -- just an example set as often as you need
		httpResponses = {
			'USGovWeathertrigger' -- must match with the callback passed to the openURL command
	logging = {
		level = domoticz.LOG_INFO,
		marker = 'USGovWeathertrigger',
	    local APIURL = 'https://api.weather.gov/points/39.7456,-97.0892'
			domoticz.openURL({
				url = APIURL,
				method = 'GET',
				callback = 'USGovWeathertrigger', -- see httpResponses above.
			}).afterSec(5)
			if (item.ok) then
                    --domoticz.utils.dumpTable(item.json)
                    local city = item.json.properties.relativeLocation.properties.city
                    local state = item.json.properties.relativeLocation.properties.state
                    local coord1 = item.json.properties.relativeLocation.geometry.coordinates[1] -- 1 because in JSON elements start from 0 and in table it starts from 1
                    local coord2 = item.json.properties.relativeLocation.geometry.coordinates[2]
                    domoticz.log('City='.. city.. '  State='.. state .. ';  Coordinates: '.. coord1..'; '.. coord2, domoticz.LOG_ERROR) -- los as ERROR just to mark it for easy find
				domoticz.log('LOG_ERROR', domoticz.LOG_ERROR)
Try
local Count = item.json.data.cpm
domoticz.log('status = ' .. Count, LOG_INFO)
costo
Post by costo »
YES !!!
That does the trick
thank you thank you thank you
costo
Post by costo »
So I got a basic working dzVents script
	active = true,
			domoticz.openURL({
				method = 'GET',
			    local Count = (item.json.data.cpm)
                local Up = (item.json.data.uptime/60)
                local Temp = (item.json.data.temperature)
			    print (item.data)
			    domoticz.devices('cpmUp').updateCustomSensor(Up)
			    domoticz.devices('cpmT').updateTemperature(Temp)
Now I need to do some math, dzVents documentation for math functions seems non-existent.
The Temperature is displayed with 2 decimals, I need only 1
The Uptime in minutes needs to be rounded , no decimals.
Then I need to engineer some way to make a Cumulative Average of the last 30 readings
in LUA that needed one uservariable. and a few lines of code
whatever I try in dzVents it ends in errors.
habahabahaba
local temp = domoticz.utils.round(temperature , 1)
local Uptime = domoticz.utils.round(Uptime, 0)
local wAverage30 = domoticz.variables('cpmWalkAv').value
costo
Post by costo »
thanks habahabahaba, your input is very helpfull.
Most of the things work.
I still use a uservariable, just as in the LUA script, maybe in dzVents there is a better way but for now the uservariable is ok.
reading from the uservariable is like this:
local wAverage30 = domoticz.variables('CAcpm').value -- uservariable
but writing a new value in the uservariables table is erronous.
I tried -- domoticz.variables.CAcpm.value = tostring(wAverage30)
and get this error 'attempt to index a function value (field 'variables')
this is part of my code:
	    print (item.data)
             local Uptime = math.floor((item.json.data.uptime+0.5)/60)
             local Temp   = domoticz.utils.round(item.json.data.temperature,1)
             wAverage30 = (29*wAverage30 + Count)/30
              domoticz.variables.CAcpm.value = tostring(wAverage30)  -- this line gives the error
              print (wAverage30)
	    domoticz.devices('cpmUp').updateCustomSensor(Uptime)
            domoticz.devices('cpmCount30').updateCustomSensor(wAverage30)
habahabahaba
costo wrote: Monday 12 May 2025 22:43
domoticz.variables('Heating_123_floors').set('On') - example
I think you have to learn this - https://wiki.domoticz.com/DzVents:_next ... _scripting
costo
Post by costo »
Hi habahabahaba,
your example brought me to the solution
yes you are right, I have to learn dzVents, but its not easy to teach an old horse a new trick.
More than 50 years ago I learned coding using punchcards.
each card was a line and had max 80 characters, so variables needed short names.
in the evening a batch of cards was sent by a modem to a mainframe and the next day I got the result or error warning.
from algol>pascal>basic to C++ and then I stopped, never had interest in java or script language.
Now I have to if i want to do nice things in domoticz
I still feel the need to keep variable names short and get dizzy if I see a script with names like ('broodroosterventilator') or (response.data.value) , than I don't see the code anymore :lol:
