Getting setting info to script
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
I like to read out the LAT and LAT from the settings menu in to a Dzvents script
Is this possible and how can i do this ?
local lat = tostring(domoticz.settings.latitude)
local lon = tostring(domoticz.settings.longitude)
SOemthing like this, but that doesn't work
jvdz
Domoticz version: 4.107
Re: Getting setting info to script
Post by jvdz »
According the docs in the Wiki: domoticz.settings.location.latitude
madpatrick
Thanks. I must have overlooked that one
Barberousse
Post by Barberousse »
domoticz.log(tostring(domoticz.settings.location.latitude)) and domoticz.log(tostring(domoticz.settings.location.longitude)) send back "0" instead of configured values in Domoticz (Domoticz 2025.1, french locale, same if I switch to English), anyone seeing this too?
Thank you.
gizmocuz
Post by gizmocuz »
I created a dzVents script based on a dummy switch, when pressed it will log the latitude:
		devices = {
			'MyDummy'
	logging = {
		level = domoticz.LOG_DEBUG,
		marker = 'test_template',
		domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
		domoticz.log('latitude:  ' .. domoticz.settings.location.longitude, domoticz.LOG_INFO)
The script output is:
2025-08-23 08:17:36.520  dzVents: test_template: ------ Start internal script: Script #1: Device: "MyDummy (Dummy)", Index: 10640
2025-08-23 08:17:36.520  dzVents: test_template: Device MyDummy was changed
2025-08-23 08:17:36.521  dzVents: test_template: latitude:  5.1368
2025-08-23 08:17:36.521  dzVents: test_template: ------ Finished Script #1
