How to get daily used and delivered energy value
jpmd
Does anyone know how to get the total used (electric) energy of a specific dag in the past.
The energy is saved in a utility device: I like to get the used- an return energy value of a specific day of this figure: Thanks in advance
manjh
- Domoticz version: 2025.2
Re: How to get daily used and delivered energy value
I keep all meter readings on a daily basis. Every day at 23:59 I pick up all readings of electricity, gas, and PV, and append the values to a file.
Over time I have collected a lot of data, useful for further processing.
For example: I wrote a flow in Node Red which "predicts" annual usage, based on a sliding year.
I select the end-date, and the flow calculates what my usage would be if the energy provider were to calculate it on that day.
This is very useful to see the effects of energy saving: in my case I installed an airconditioning unit in October last year, also capable of heating. This is much more cost effective than gas heating.
With the Node Red flow, I can see the progress day-by-day.
Hans
- jvdz
- Domoticz version: 4.107
This is a lua script that can retrieve the info for an specified date.
Save the below code to getp1dayinfo.lua and you can use is as:
getp1dayinfo.lua :
Usage:
getp1dayinfo.lua :
-- LUA to get P1 usage a specified day
-- Change to your enviroment -----------
local P1MeterIDX = 375 -- IDX of P1 meter device
local DomoUrl = "http://127.0.0.1:8080" -- URL of domoticz.
local json = (loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()
local iDatum = arg[1] or os.date('%Y-%m-%d')
local iJaar = iDatum:sub(1,4)
-- Get data from Domoticz with Curl
local function GetDomData(url)
local sQuery = 'curl -s "' .. url .. '"'
-- print("sQuery="..sQuery)
local handle = assert(io.popen(sQuery))
local Web_Data = handle:read('*all')
handle:close()
if (Web_Data == '') then
print('P1 get data Error: Empty result from curl command')
return ''
return Web_Data
-- Get P1 information for a whole year. Data starts with today lastyear.
local url = DomoUrl .. '/json.htm?type=command¶m=graph&sensor=counter&idx=' .. tostring(P1MeterIDX) .. '&range=year&actyear=' .. iJaar
local jresponse = GetDomData(url)
local decoded_response = json:decode(jresponse)
local p1result = decoded_response['result']
-- List all data
local P1_Usage = '?'
local P1_Return = '?'
for i = 1, #p1result do
local p1record = p1result[i]
if type(p1record) == 'table' then
-- Get the info when date is found
if (iDatum == p1record['d']) then
P1_Usage = tostring(((p1record['v1'] or 0) + (p1record['v2'] or 0)))
P1_Return = tostring(((p1record['r1'] or 0) + (p1record['r2'] or 0)))
break
print('P1 verbruik voor ' .. iDatum .. ' is ' .. P1_Usage .. 'kWh')
print('P1 teruglevering voor ' .. iDatum .. ' is ' .. P1_Return .. 'kWh')
~/domoticz $ lua getp1dayinfo.lua
P1 verbruik voor 2025-03-27 is 2.885kWh
P1 teruglevering voor 2025-03-27 is 1.257kWh
~/domoticz $ lua getp1dayinfo.lua 2025-02-28
P1 verbruik voor 2025-02-28 is 7.999kWh
P1 teruglevering voor 2025-02-28 is 16kWh
/domoticz $ lua getp1dayinfo.lua 2023-02-28
P1 verbruik voor 2023-02-28 is 8.308kWh
P1 teruglevering voor 2023-02-28 is 15.843kWh
jpmd
Wow thats great. Thanks.
But unfortunately Two issues still:
1/ I removed one slash in "local DomoUrl = "http://raspberrypi-1:/8080" -- URL of domoticz." Witch results in: "local DomoUrl = "http://raspberrypi-1:8080" -- URL of domoticz."
2/ The "local url" becomes "http://raspberrypi-1:8080/json.htm?type ... tyear=2025"
If I use that in the chroom-browser, it results in an nice json-response
BUT: The LUA-line "local jresponse = GetDomData(url)" gives a value for jresponse "<html><head><title>Unauthorized</title></head><body><h1>401 Unauthorized</h1></body></html".
Any idea why GetDomData(url) gets a 401 Unauthorized response?
- jvdz
Don't understand what you mean. The posted script has: "http : //127.0.0.1:8080", which assumes the script runs on the server itself.jpmd wrote: Thursday 27 March 2025 11:45 But unfortunately Two issues still:
1/ I removed one slash in "local DomoUrl = "http : //raspberrypi-1:/8080" -- URL of domoticz." Witch results in: "local DomoUrl = "http://raspberrypi-1:8080" -- URL of domoticz."
So just change that to what is required.
Sure, This is a security issue and described in the Wiki: https://wiki.domoticz.com/Security#API_Protectionjpmd wrote: Thursday 27 March 2025 11:45 2/ The "local url" becomes "http : //raspberrypi-1:8080/json.htm?type=command¶m=graph&sensor=counter&idx=210&range=year&actyear=2025"
If I use that in the chroom-browser, it results in an nice json-response![]()
I would simply add the local LAN ip-range to the trusted networks so no UserId/Password is required: https://wiki.domoticz.com/Security#Trusted_Networks
jpmd
Tanks,
I used a value for Domourl "http://raspberrypi-1:8080" and the value for "Trusted Networks" was "localhost".
I had to change Domourl to '192.168.2.11'
and changed "Trusted Networks" to "localhost;192.168.*"
After those changes the jresponse contains a proper JSON output.
Thanks for helping me
- jvdz
Just stepping through your last reply:
... but nice when the script works for you.
That means it won't be working indeed as locahost = 127.0.0.1jpmd wrote: Thursday 27 March 2025 15:33 I used a value for Domourl "http://raspberrypi-1:8080" and the value for "Trusted Networks" was "localhost".
The Domoticz url shouldn't have to be changed when raspberrypi-1 resolves to 192.168.2.11 on the system you run this script on. so this is an DNS thing.
Make sense, and all it needs is the addition of an /24 ip range like: localhost;192.168.2.*" assuming the client running the script is also in the 192.168.2.x network.
- Domoticz version: 2026.3
If it is just to know you can hover over the specific day and see the value:
You can also download the excel or csv data from the graph from the hamburger menu, top right.
You can also go to the report page (device widget Log button - Report button on top right) and see the values per month per day per year.
DateTime Totaal verbruik Totaal Levering Kosten
2025-02-27 00:00:00 20,826 -7,037 4,3118
2025-02-28 00:00:00 20,704 -8,693 3,7558
2025-03-01 00:00:00 31,6 -0,051 9,8654
2025-03-02 00:00:00 17,333 -15,863 0,4597
2025-03-03 00:00:00 17,075 -7,782 2,9059
2025-03-04 00:00:00 14,58 -9,834 1,4841
2025-03-05 00:00:00 10,948 -19,884 -2,7943Domoticz running on Udoo X86 (on Ubuntu)
