Timer 5 minute past the hour every 4 hours
FredZ
Post by FredZ »
Hello all
I have a script that triggers (turns on a pump) every 4 hours. and it works fine. however, I would like it to trigger 5 minutes past the hour instead of on the hour. No real reason why except for ease of viewing/scanning log as I have several events running at the same time.
        timer = {
            'every 4 hours', -- Adjust this if necessary
EG: 0005 0405 0805 1205 1605 2005
Can this be done simply?
FYI: Since I changed all my scripts to dzVents I haven't had any fail to run.
Fred
gizmocuz
Re: Timer 5 minute past the hour every 4 hours
Post by gizmocuz »
You could do something like this:
		timer = {
			'at *:05',					-- called every 5th minute in the hour
	logging = {
		level = domoticz.LOG_INFO,
		marker = 'template',
	execute = function(domoticz, timer)
		local act_hour = tonumber(os.date('%H'))
		if  ((act_hour % 4) ~= 0) then
			do return end -- we don't want to be calle yet
		domoticz.log('This IS called every forth hour!', domoticz.LOG_INFO)
HvdW
Domoticz version: 2023.2
Post by HvdW »
What about this?
light.switchOn().checkFirst().afterMin(5)
From the wiki.
Your pump could maybe use this one as well:
light.switchOff().afterMin(15)
I asked AI as well
        timer = {'every hour'}  -- Checks every hour, but only triggers at 4-hour intervals
    execute = function(domoticz)
        local time = domoticz.time
        local currentHour = time.hour
        local currentMinute = time.min
        -- Check if it's 5 minutes past the hour AND hour % 4 == 0 (every 4 hours)
        if (currentMinute == 5) and (currentHour % 4 == 0) then
            domoticz.log("Triggering pump at " .. time.rawTime, domoticz.LOG_INFO)
            domoticz.devices("Your Pump Name").switchOn()  -- Replace with your pump's name
It uses domoticz.time which is elegant.
Another solution
        timer = {
            'at 00:05', 'at 04:05', 'at 08:05',
            'at 12:05', 'at 16:05', 'at 20:05'
Bugs bug me.
gizmocuz
Post by gizmocuz »
Your AI solution won't work as it is only triggered every hour, not 5 minutes past.
Your second solution works perfect...
HvdW
Post by HvdW »
gizmocuz wrote: Wednesday 26 March 2025 15:23 Your AI solution won't work as it is only triggered every hour, not 5 minutes past.
The second is human. 🥳
Bugs bug me.
