Netatmo authentication changes Oct 2022
Re: Netatmo authentication changes Oct 2022
You can follow my post above to check your access_token and access to the Netatmo server.
DomoFlits
- Domoticz version: Bld16583
You have another error than most of us here have. We have:jcb2 wrote: Monday 24 March 2025 12:01 always one other error : "No access granted, forcing login again (Refresh tokens): invalid_client"
Invalid/no data received (refresh tokens)... HTTP/2 403
You should check your client ID, Client secret and tick the scope(s) you own in Domoticz.
chrominator
- Domoticz version: 2024.7
Log with new PR #6281:
... Waiting for 45 mn.... Keep you posted.
phil35
- Domoticz version: 2023.1
@jpaul : I am this owner of netatmo_manage_tokens.php , and it works like a a charm. I tested every day with the other script netatmo-floodlight Public , by these days
The archictecture is:
sonoff button -> domoticz via zigbee -> a script handles (one click, double click and long click) and uses the access_token, stored and managed by netatmo_manage_tokens.php to perform the action on the camera.
[https://www.domadoo.fr/fr/peripheriques ... ee-30.html]
What is the build number 16583? and where to find it?
on the domoticz download page there is only stable 2024.7.16140 or beta 2024.7.16586
Thank you.
Phil
Thank you.
Phil
Production platform uses domoticz v2023.1
Production platform (for Netatmo and Zigbee) uses domoticz v2024.7
chrominator
No time to wait.chrominator wrote: Monday 24 March 2025 16:36 Log with new PR #6281:
Added some debug lines to the source: compile and restart:
Got a good reply from the Netatmo server then, it worked directly, no relation with my changes in the source. Still working randomly, I'm saved probably until the next restart.
jcb2
With last beta, after one renew of ID and password and one restart I have always one error :
2025-03-24 17:52:28.197 Status: Domoticz V2025.1 (build 16586) (c)2012-2025 GizMoCuz
2025-03-24 17:52:37.668 Error: Météo: Invalid/no data received (refresh tokens)... HTTP/2 403
When I try to use the button connexion into hardware I have this error :
jpaul
Hello @phil35,
That's why I suspect Netatmo of banning or blacklisting some Apps when they generate with too many errors.
I know your module netatmo_manage_tokens.php works. But I had to create a new App on dev.netmatmo website. With my historical App, used by Domoticz for a while, I'm unable to refresh the token with netatmo_manage_tokens.php (even when Netmatmo plugin is disabled in Domoticz).phil35 wrote: Monday 24 March 2025 16:43 I am this owner of netatmo_manage_tokens.php , and it works like a a charm.
jpaul
Hi dev team,
Could it be an issue with the HTTPClient lib ?
I added debug in httpclient/HTTPClient.cpp , this line
and it seems the headers are not exactly the same between Domotiz and netatmo_manage_tokens.php
in HTTPClient::POSTBinary and HTTPClient::GETBinary methods,curl_easy_setopt(curl, CURLOPT_VERBOSE, 1L);
homeJLB
With this Error You are having a issue with your ClientID or ClientSecret, maybe you have a space in front or in back.jcb2 wrote: Monday 24 March 2025 12:01 Hello,
One new PR is available into new beta about issue of Netatmo.
For me this is always not good. I have wait 20 minutes but always one other error : "No access granted, forcing login again (Refresh tokens): invalid_client"
I have check and check again, make a new app but nothing ...
homeJLB
As a user off Domoticz myself I invested time in the New-API from Netatmojpaul wrote: Monday 24 March 2025 19:32 Hi dev team,
I added debug in httpclient/HTTPClient.cpp , this linein HTTPClient::POSTBinary and HTTPClient::GETBinary methods,curl_easy_setopt(curl, CURLOPT_VERBOSE, 1L);
The authentication and the HTTPClient library I have less experience with but I'm willing to test and find a solution.
kind regards
homeJLB
If you enable Debug on Domoticz then you can see the httpUrl and httpData without any changeschrominator wrote: Monday 24 March 2025 16:56No time to wait.chrominator wrote: Monday 24 March 2025 16:36 Log with new PR #6281:
Debug(DEBUG_HARDWARE, "Netatmo URL %s with %s", httpUrl.c_str(), httpData.c_str());Code: Select all
ExecStart=/domoticz/domoticz -www 8080 -sslwww 443 -log "/var/log/domoticz-1.log" -loglevel all -debuglevel normal,hardware
# ExecStart=/domoticz/domoticz -www 8080 -sslwww 443 -log "/var/log/domoticz-1.log" -loglevel allkind regards
jcb2
OK I have found one error into my config : I have now cleared the field redirect URI. OK I have the page for accepting the scope.
Now I have these errors :
2025-03-25 11:42:57.920 Error: Météo: Error connecting to Server (refresh tokens): HTTP/1.1 28 Timeout was reached
2025-03-25 11:42:57.920 Status: Météo: Login 0
2025-03-25 11:43:00.279 Status: [web:8080] Incoming connection from: 127.0.0.1
2025-03-25 11:43:27.927 Status: Météo: Use refresh token from database...
2025-03-25 11:43:27.933 Status: Météo: Requesting refreshed tokens
2025-03-25 11:43:28.190 Error: Météo: Invalid/no data received (refresh tokens)... HTTP/2 403
2025-03-25 11:43:28.191 Status: Météo: Retry LOGIN within 45 min.
2025-03-25 11:43:28.192 Status: Météo: Login 0
- Domoticz version: 2026.3
The wiki https://wiki.domoticz.com/Netatmo has been updated to show hopefully the correct way of adding/modifying the software.
This implementation of adding Netatmo in Domoticz is very different from any other plugin/gateway.
jcb2
After many try I have one connexion.
But no update of my devices. I have deleted all devices and hope one automatic new creation (with params for allow new device) but nothing !
One idea ?
Thanks,
Jean-Charles
Log :
2025-03-25 21:14:01.982 Status: Météo: Use refresh token from database...
2025-03-25 21:14:01.982 Status: Météo: Requesting refreshed tokens
2025-03-25 21:14:02.423 Status: Météo: We refresh our token ...
2025-03-25 21:14:02.423 Status: Météo: Login 1
2025-03-25 21:14:02.639 Status: Météo: Station Data parsed Buanderie
2025-03-25 21:14:02.640 Status: Météo: Station Data parsed Météo abri
2025-03-25 21:14:02.640 Status: Météo: Weather 1
2025-03-25 21:14:02.640 Status: Météo: Get HomesData Details
2025-03-25 21:14:02.902 Status: Météo: Home id METEO updated.
2025-03-25 21:14:02.902 Status: Météo: Home id Buanderie et cave updated.
2025-03-25 21:14:02.902 Status: Météo: Home id Abri et serre updated.
2025-03-25 21:14:02.902 Status: Météo: Home Status Details, size (number of homes) is 3
2025-03-25 21:14:03.829 Status: Météo: Parse Persons
2025-03-25 21:14:03.829 Status: Météo: HomeStatus parsed
2025-03-25 21:14:04.106 Status: Météo: Scenarios Data Recieved
2025-03-25 21:14:04.284 Status: Météo: Parse Persons
2025-03-25 21:14:04.285 Status: Météo: HomeStatus parsed
2025-03-25 21:14:04.513 Status: Météo: Scenarios Data Recieved
2025-03-25 21:14:04.514 Status: Météo: Status 1
One idea ?
Thanks,
Jean-Charles
Log :
homeJLB
For answering this you need to enable debug to see which devices are received?jcb2 wrote: Tuesday 25 March 2025 21:21 Hello,
One idea ?
Thanks,
Jean-Charles
Log :
Did you use 16586 ?
jcb2
Yes it is with version 16586.
But the connection up durring the night and is down this morning.
Very strange. Below I provide the log about this error and hope it is an help.
Thanks,
Jean-Charles
Log this night and morning :
2025-03-26 02:29:31.744 Status: Météo: Use refresh token from database...
2025-03-26 02:29:31.744 Status: Météo: Requesting refreshed tokens
2025-03-26 02:29:31.928 Status: Météo: Retry LOGIN within 45 min.
2025-03-26 02:29:31.928 Status: Météo: Login 0
2025-03-26 03:14:32.306 Status: Météo: Use refresh token from database...
2025-03-26 03:14:32.306 Status: Météo: Requesting refreshed tokens
2025-03-26 03:14:32.505 Status: Météo: Retry LOGIN within 45 min.
2025-03-26 03:14:32.505 Status: Météo: Login 0
2025-03-26 03:59:32.876 Status: Météo: Use refresh token from database...
2025-03-26 03:59:32.876 Status: Météo: Requesting refreshed tokens
2025-03-26 03:59:33.052 Status: Météo: Retry LOGIN within 45 min.
2025-03-26 03:59:33.052 Status: Météo: Login 0
2025-03-26 04:44:33.447 Status: Météo: Use refresh token from database...
2025-03-26 04:44:33.447 Status: Météo: Requesting refreshed tokens
2025-03-26 04:44:33.606 Status: Météo: Retry LOGIN within 45 min.
2025-03-26 04:44:33.607 Status: Météo: Login 0
2025-03-26 05:29:34.000 Status: Météo: Use refresh token from database...
2025-03-26 05:29:34.000 Status: Météo: Requesting refreshed tokens
2025-03-26 05:29:34.174 Status: Météo: Retry LOGIN within 45 min.
2025-03-26 05:29:34.175 Status: Météo: Login 0
2025-03-26 06:14:34.546 Status: Météo: Use refresh token from database...
2025-03-26 06:14:34.546 Status: Météo: Requesting refreshed tokens
2025-03-26 06:14:34.712 Status: Météo: Retry LOGIN within 45 min.
2025-03-26 06:14:34.712 Status: Météo: Login 0
2025-03-26 06:59:35.079 Status: Météo: Use refresh token from database...
2025-03-26 06:59:35.079 Status: Météo: Requesting refreshed tokens
2025-03-26 06:59:35.252 Error: Météo: Invalid/no data received (refresh tokens)... HTTP/2 403
2025-03-26 06:59:35.252 Status: Météo: Retry LOGIN within 45 min.
2025-03-26 06:59:35.252 Status: Météo: Login 0
2025-03-26 07:44:35.614 Status: Météo: Use refresh token from database...
2025-03-26 07:44:35.614 Status: Météo: Requesting refreshed tokens
2025-03-26 07:44:35.786 Error: Météo: Invalid/no data received (refresh tokens)... HTTP/2 403
2025-03-26 07:44:35.786 Status: Météo: Retry LOGIN within 45 min.
2025-03-26 07:44:35.786 Status: Météo: Login 0
2025-03-26 07:46:45.118 Status: Météo: Worker stopped...
Into debug mode I have these informations :
Error :
2025-03-26 08:16:46.736 [7fd1ce7fc6c0] Error: Météo: Invalid/no data received (refresh tokens)... HTTP/2 403
Log info :
2025-03-26 08:16:46.568 [7fd1ce7fc6c0] Debug: Météo: Netatmo URL https://api.netatmo.com/oauth2/token? with grant_type=refresh_token&refresh_token=5f4d36d****************&client_id=67e2ee72e3***********&client_secret=CVGzSpWbyw*********************
2025-03-26 08:16:46.730 [7fd1ce7fc6c0] Debug: Météo: Netatmo Invalid ... <!DOCTYPE html PUBLIC '-//W3C//DTD XHTML 1.0 Transitional//EN' 'http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd'>
2025-03-26 08:16:46.730 <html xmlns='http://www.w3.org/1999/xhtml'>
2025-03-26 08:16:46.730 <head>
2025-03-26 08:16:46.730 <meta content='text/html; charset=utf-8' http-equiv='content-type' />
2025-03-26 08:16:46.730 <style type='text/css'>
2025-03-26 08:16:46.730 body {
2025-03-26 08:16:46.730 font-family: Arial;
2025-03-26 08:16:46.730 margin-left: 40px;
2025-03-26 08:16:46.730 }
2025-03-26 08:16:46.730 img {
2025-03-26 08:16:46.730 border: 0 none;
2025-03-26 08:16:46.730 #content {
2025-03-26 08:16:46.730 margin-left: auto;
2025-03-26 08:16:46.730 margin-right: auto
2025-03-26 08:16:46.730 #message h1 {
2025-03-26 08:16:46.730 font-size: 24px;
2025-03-26 08:16:46.730 font-weight: normal;
2025-03-26 08:16:46.730 color: #000000;
2025-03-26 08:16:46.730 margin: 34px 0px 0px 0px
2025-03-26 08:16:46.730 #message h2 {
2025-03-26 08:16:46.730 font-size: 20px;
2025-03-26 08:16:46.730 #message p {
2025-03-26 08:16:46.730 font-size: 16px;
2025-03-26 08:16:46.730 margin: 8px 0px 0px 0px
2025-03-26 08:16:46.730 #message hr {
2025-03-26 08:16:46.730 margin: 15px 0px
2025-03-26 08:16:46.730 #errorref {
2025-03-26 08:16:46.730 font-size: 11px;
2025-03-26 08:16:46.730 color: #737373;
2025-03-26 08:16:46.730 margin-top: 41px
2025-03-26 08:16:46.730 </style>
2025-03-26 08:16:46.730 <title>Service unavailable</title>
2025-03-26 08:16:46.730 </head>
2025-03-26 08:16:46.730 <body>
2025-03-26 08:16:46.730 <div id='content'>
2025-03-26 08:16:46.730 <div id='message'>
2025-03-26 08:16:46.730 <h2>The request is blocked.</h2>
2025-03-26 08:16:46.730 </div>
2025-03-26 08:16:46.730 <div id='errorref'>
2025-03-26 08:16:46.730 <span>20250326T071646Z-185fd8ffd9fqklwzhC1BRUcv2400000004p0000000006t6y </span>
2025-03-26 08:16:46.730 </body>
2025-03-26 08:16:46.730 </html>
2025-03-26 08:16:46.737 [7fd1ce7fc6c0] Debug: Météo: Refresh Token Flag 1 ...
Thanks,
Jean-Charles
Error :
Log info :
homeJLB
My test system did also have a block after the 20 min wait.
so I stopped that system and restart today.
So sometimes the wait is needed and longer or you can make a new App on dev.netatmo.com
Kind regards
2025-03-25 19:38:10.509 Error: Netatmo: Invalid/no data received (refresh tokens)... HTTP/2 403
2025-03-25 19:38:10.513 Status: Netatmo: Retry LOGIN within 45 min.
2025-03-25 19:38:10.513 Debug: Netatmo: Refresh Token Flag 1 ...
2025-03-25 19:38:10.513 Status: Netatmo: Login 0
2025-03-25 19:38:21.784 Status: Mainworker Stopped...
2025-03-26 20:09:34.060 Status: Netatmo: Status 1Kind regards
ninicob93
i have the same problem. Have you found a solution?
Abidos
As far as I'm concerned, I had exactly the same problem.
After seeing "Retry LOGIN within 45 min." several times, I decided to reauthenticate. With no success. Then I rebooted my RPI: that did the trick! After reboot, it worked.
It's worth giving it a try...
ninicob93
Thanks. For my part I found the solution by allowing the addition of equipment. Another NETATMO device was added and everything was in order. ThanksAbidos wrote: Thursday 27 March 2025 15:26 Hi,
It's worth giving it a try...![]()
