GarbageCalendar (new version) lua scripts
abc1000
Re: GarbageCalendar (new version) lua scripts
Post by abc1000 »
Oke, i'v updated and it's 100% again :D
jvdz
Domoticz version: 4.107
Post by jvdz »
Nice, just so other know too:
It seems they stopped using afvalwijzer.nl so I made a new m_rova_api to use their own api available.
This new module is available in github.
hoeby
Domoticz version: V2022.1
Post by hoeby »
The script isn't working anymore.
It works for 1 day after restart domoticz. The next day it reports an issue in the log "These records are missing in your garbagecalenderconfig.lua file, so no notifications will be send"
But what are "These records" because they are not written in the log?
Thin-client --> Docker Domoticz main environment
Pi3A+ --> Google home (GAssistPi)
Pi3B+ --> Docker (P1monitor, Domoticz test environment, Ubiquity controller)
jvdz
Post by jvdz »
The log should show the garbagetype records missing in the config right after that line.
Could you please send me your logs so I can have a look? You've got my email. ;-)
EDIT: Think I found your info again, so this is the outcome of my test run:
--> testing module m_opzet
+ 1.08 (1):Zipcode=6x0xEx  Housenr=2x  Street=  Hostname=rwm.nl  Woonplaats=Echt
  RunErr:0  RunWarn:0  WebErr:0  WebWarn:0  WTable:3  Found 16 data records, Schedule: vri 4 apr: gft afval ; din 8 apr: Grijze bak ; don 10 apr: pmd ; vri 11 apr: gft afval ; vri 18 apr: gft afval ;
Done...
.. and see this in the log:
15:37:18 gc_main: 624: -> Start looping through data to find the first 5 events to show:
15:37:18 gc_main: 671: > first type:gft afval Icon:"nil"
>> GarbageDate:2025-4-4 GarbageType:gft afval; Calc Days Diff=2; *** Notify skipped because active <> on ( ??) in garbagetype_cfg[]!
>> GarbageDate:2025-4-8 GarbageType:restafval; Notify: Active=on Time=15:59 DaysBefore=1 reminder=6 Calc Days Diff=6
>> GarbageDate:2025-4-10 GarbageType:pmd; Calc Days Diff=8; *** Notify skipped because active <> on ( ??) in garbagetype_cfg[]!
>> GarbageDate:2025-4-11 GarbageType:gft afval; Calc Days Diff=9; *** Notify skipped because active <> on ( ??) in garbagetype_cfg[]!
>> GarbageDate:2025-4-18 GarbageType:gft afval; Calc Days Diff=16; *** Notify skipped because active <> on ( ??) in garbagetype_cfg[]!
15:37:18 gc_main: 773: -< End data loop
15:37:18 gc_main: 775: #!# Warning: These records are missing in your garbagecalendarconfig.lua file, so no notifications will be send!
15:37:18 gc_main: 776: #!# Add these records into the garbagetype_cfg table and adapt the schedule, text and icon info to your needs:
["gft afval"] ={hour=19,min=02,daysbefore=1,reminder=0,text="gft afval", icon=nil},
["pmd"] ={hour=19,min=02,daysbefore=1,reminder=0,text="pmd", icon=nil},
["grof tuinafval"] ={hour=19,min=02,daysbefore=1,reminder=0,text="grof tuinafval", icon=nil},
15:37:18 gc_main: 778: #!# -- end ----------------------------
The explanation for the "#!# Warning: These records are missing in your garbagecalendarconfig.lua file, so no notifications will be send!" can be found here.
Send me your logs in a zip when you are seeing some other issue so I can have a look. :-)
eddieb
Post by eddieb »
I installed GarbageCalender inside my docker based testsetup and found that it was not updating...
some debugging showed that "lua" was not availiable inside the domoticz container ???
Anyone with similar experiances ?
I resolved it by manualy
apt update
apt install lua5.4
inside the container and now the "lua" command is found and it all works.
There must be a cleaner way to do this, lua is availiable on the host
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / IndeVolt SF3000 / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
Feeding ADSB https://adsb.im/home
jvdz
Post by jvdz »
eddieb wrote: Saturday 14 June 2025 8:34 There must be a cleaner way to do this, lua is availiable on the host
The script should test for the version of LUA installed and in case it isn't, it will run it in the foreground instead of background.
LUA: => check LUA not found -> Run foreground to use internal LUA.
The preference is to run the Web-Update part in its own lua process, to avoid hanging the Domoticz event system.
So, what does your logs tell you?
ps: I've tested it in a clean docker/domoticz setup and is working for me.
jvdz
Post by jvdz »
While testing the above in a clean docker install, i notices that the ico uploades are failing since the defaut ico has a size of 0 and thats not supported any more since 2025.1 (?)
So, updated the ico generation php script and uploaded the changes required for the set of default iso's
eddieb
Post by eddieb »
WARNING, I might be running an older version !!! (ver="20200211-1430")
log told me following :
2025-06-14 08:16:00.377  Status: LUA: @GarbageCal(m_opzet_api): #### start garbagecalendar script v20200211-1430
2025-06-14 08:16:00.377  Status: LUA: @GarbageCal(m_opzet_api): #### Debuging with extra messages because "mydebug=true" in garbagecalendarconfig.lua
2025-06-14 08:16:00.377  Status: LUA: @GarbageCal(m_opzet_api): ####    please change it back to "mydebug=false" when done testing to avoid growing a big domoticz log.
2025-06-14 08:16:00.377  Status: LUA: @GarbageCal(m_opzet_api): domoticzjsonpath: /opt/domoticz/userdata/scripts/lua/
2025-06-14 08:16:00.377  Status: LUA: @GarbageCal(m_opzet_api): datafilepath: /var/tmp/
2025-06-14 08:16:00.377  Status: LUA: @GarbageCal(m_opzet_api): scriptpath: /opt/domoticz/userdata/scripts/lua/
2025-06-14 08:15:00.370  Status: LUA: @GarbageCal(m_opzet_api): ####    please change it back to "mydebug=false" when done testing to avoid growing a big domoticz log.
2025-06-14 08:15:00.370  Status: LUA: @GarbageCal(m_opzet_api): domoticzjsonpath: /opt/domoticz/userdata/scripts/lua/
2025-06-14 08:15:00.370  Status: LUA: @GarbageCal(m_opzet_api): datafilepath: /var/tmp/
2025-06-14 08:15:00.370  Status: LUA: @GarbageCal(m_opzet_api): scriptpath: /opt/domoticz/userdata/scripts/lua/
2025-06-14 08:15:00.371  Status: LUA: @GarbageCal(m_opzet_api): Loaded /opt/domoticz/userdata/scripts/lua/garbagecalendar/garbagecalendarconfig.lua.
2025-06-14 08:15:00.371  Status: LUA: @GarbageCal(m_opzet_api): Loaded /opt/domoticz/userdata/scripts/lua/garbagecalendar/tablefuncs.lua.
2025-06-14 08:15:00.371  Status: LUA: @GarbageCal(m_opzet_api): Start checking garbagetype_cfg table:
2025-06-14 08:15:00.371  Status: LUA: @GarbageCal(m_opzet_api): -> NotificationTime:16:22  Garbagetype:Plastic, blik en drinkpakken
2025-06-14 08:15:00.371  Status: LUA: @GarbageCal(m_opzet_api): -> NotificationTime:16:22  Garbagetype:Textiel
2025-06-14 08:15:00.371  Status: LUA: @GarbageCal(m_opzet_api): -> NotificationTime:16:22  Garbagetype:Restafval, minicontainers.
2025-06-14 08:15:00.371  Status: LUA: @GarbageCal(m_opzet_api): -> NotificationTime:2:30  Garbagetype:reloaddata
2025-06-14 08:15:00.371  Status: LUA: @GarbageCal(m_opzet_api): -> NotificationTime:7:15  Garbagetype:dummy1
2025-06-14 08:15:00.371  Status: LUA: @GarbageCal(m_opzet_api): -> NotificationTime:16:22  Garbagetype:Groente-, fruit, tuinafval en etensresten
2025-06-14 08:15:00.371  Status: LUA: @GarbageCal(m_opzet_api): -> NotificationTime:16:22  Garbagetype:Papier en karton
2025-06-14 08:15:00.371  Status: LUA: @GarbageCal(m_opzet_api): -> NotificationTime:15:15  Garbagetype:dummy2
2025-06-14 08:15:00.371  Status: LUA: @GarbageCal(m_opzet_api): -> NotificationTime:16:22  Garbagetype:Kerstbomen
2025-06-14 08:15:00.371  Status: LUA: @GarbageCal(m_opzet_api): Start update for text device:
2025-06-14 08:15:00.371  Status: LUA: @GarbageCal(m_opzet_api): Warning: Datafile not found:/var/tmp/garbagecalendar_m_opzet_api.data . Start webupdate now.
2025-06-14 08:15:00.371  Status: LUA: @GarbageCal(m_opzet_api): start foreground webupdate for module m_opzet_api of file /var/tmp/garbagecalendar_m_opzet_api.data
2025-06-14 08:15:00.373  Status: LUA: @GarbageCal(m_opzet_api): lua /opt/domoticz/userdata/scripts/lua/garbagecalendar/m_opzet_api.lua "/opt/domoticz/userdata/scripts/lua/" "9999AA" "99" "" "/var/tmp/garbagecalendar_m_opzet_api.data" "/var/tmp/garbagecalendar_web_m_opzet_api.log" "inzamelkalender.gad.nl" ""
2025-06-14 08:15:00.374  Status: LUA: @GarbageCal(m_opzet_api):  Unable to load the data. please check your setup and runlogfile :/var/tmp/garbagecalendar_run_m_opzet_api.log
2025-06-14 08:15:00.374  Status: LUA: @GarbageCal(m_opzet_api): - End  -----------------
2025-06-14 08:15:00.374  Status: LUA: @GarbageCal(m_opzet_api): ==> found schedule:
2025-06-14 08:15:00.374  Status: LUA: @GarbageCal(m_opzet_api): Update device from:
0
 replace with:
As nothing happened I tried to manually execute
from the cli inside the container
that gave me the warning that "lua" was not found.
after I installed lua it worked
jvdz
Post by jvdz »
So you want me to look at the version thats 5 years old or would it be a logica idea to try to latest version? ;)
Answer to question 1:
guess you know it already :twisted:
In case you still have issues with the latest then zip up the logs and email them to me so I can check.
eddieb
Post by eddieb »
Of course not ...
It is just a sign of how good that old version is, it just does what is has to do on my prod domoticz...
I will try the new version on my doccker test system
eddieb
Post by eddieb »
latest version running,
how do I get this icon ?
I added the , icon = 'xxx' part according the example and checked that http://127.0.0.1:8080 is reachable but no icon (yet)
        ['Groente-, fruit, etensresten en  klein tuinafval'] ={hour=16,min=22,daysbefore=1,reminder=0,text='Groente-, fruit en tuinafval', icon = 'garbagecalendar_green'},
        ['Restafval']                        ={hour=16,min=22,daysbefore=1,reminder=0,text='Restafval', icon = 'garbagecalendar_grey'},
        ['Papier en karton']                 ={hour=16,min=22,daysbefore=1,reminder=0,text='Papier en karton', icon = 'garbagecalendar_blue'},
        ['Plastic, blik en drinkpakken']     ={hour=16,min=22,daysbefore=1,reminder=0,text='Plastic, blik en drinkpakken', icon = 'garbagecalendar_orange'},
        ['Textiel']                          ={hour=16,min=22,daysbefore=1,reminder=0,text='Textiel'},
        ['Kerstbomen']                       ={hour=16,min=22,daysbefore=1,reminder=0,text='Kerstbomen'},
jvdz
Post by jvdz »
Ah...you got it working...nice.
Could it be that there was no update for the text device since you added the icon bit?
Think it will do that part only when it has to do an actual update to it.
The log will tell you the info about the update.
eddieb
Post by eddieb »
Hi, today my "restafval" container was emptied ...
around 02:30 it fetched the next container and the container for today is not visible anymore ...
In an older version that switch took place the next night so on the current day it stayed visible.
Screenshot 2025-07-07 at 10.09.57.png (51.46 KiB) Viewed 17482 times
jvdz
Post by jvdz »
I think i found the issue as I was able to test myself.
Update pushed to github for opzet_api not showing today's garbage.
Let me know if that fixes it for you.
eddieb
Post by eddieb »
Jos,
I updated the code and wait for the next refresh ...
hjzwiers
Post by hjzwiers »
I can't get the script to work.
I deleted everything and started fresh. I think I've got my hostname wrong, it should be "https://www.mijnafvalwijzer.nl/nl/5624NM/17/" but i see that it is https://mijnafvalwijzer.nl/nl/5624NM/17
I have this loaded www.mijnafvalwijzer.nl en het m_mijnafvalwijzer en m_afvalwijzer_api geprobeerd maar de file in data
garbagecalendar_m_mijnafvalwijzer.data of garbagecalendar_m_mijnafvalwijzer_api.data are empty
-- Table: {1}
["Garbage_LastUpdate"]="Sun Jul 27 22:50:49 2025",
with www.mijnafvalwijzer.nl I get
EventSystem: Warning!, lua script /opt/domoticz/userdata/scripts/lua/script_time_garbagecalendar.lua has been running for more than 10 seconds
any clue?
jvdz
Post by jvdz »
Of course I can help: simply send me the config and log files in a zip file and I gladly have a look and test with your details.
EDIT: Using your postcode&housenr you listed in the url, I indeed see that the module "m_mijnafvalwijzer" has an issue with the data returned, which I will have a look at, but the module "m_mijnafvalwijzer_api" works nicely:
--> testing module m_mijnafvalwijzer_api
+ 1.30 (1):Zipcode=5624NM  Housenr=17  Street=  Hostname=
  RunErr:0  RunWarn:0  WebErr:0  WebWarn:0  WTable:2  Found 10 data records, Schedule: maa 4 aug: gft ; din 5 aug: Grijze bak ; don 14 aug: papier ; maa 18 aug: gft ; din 19 aug: Grijze bak ;
Done...
So, to see why the "m_mijnafvalwijzer_api" doesn't work for you, I will need the above files to review.
Follow the instructions ads defined in the Wiki: https://github.com/jvanderzande/Garbage ... ki/Testing
hjzwiers
Post by hjzwiers »
Deleted file
hjzwiers
Post by hjzwiers »
I changed the files:
Hostname = 'www.mijnafvalwijzer.nl'
and
websitemodule = 'm_mijnafvalwijzer_api'
the file from the logging is in the attachment
File from domoticz logging.txt
(11.18 KiB) Downloaded 332 times
Marathon2010
Domoticz version: 2026.4
Post by Marathon2010 »
Had the same issue. What solved it for me is to modify garbagecalendarconfig.lua
  • Emptied Hostname = ''
  • Deactivated websitemodule = "m_deafvalapp"
  • Activated websitemodule = 'm_mijnafvalwijzer_api'
Synology DS920+ DSM7 (Docker) | Integrations: Audio, Heating, Gas, Electricity, Water, Alarm, Car, Camera, Doorbell, Garage, Garbage, Washer | SW: Tasmota, DzVents, Pushbullet, Telegram | Plugins: UPS, GPSLogger, BatteryLevel, Hyundai KIA, Rhasspy
