Apache error 403 after fresh manual install OS and Dashticz
Afterburner
Post by Afterburner »
After running Dashticz V3 without problems for a couple of years on Ubuntu Server I decided to do a major upgrade of the OS as the old one is EOL.
I wanted to step over to Pi OS Bookworm.
https://dashticz.readthedocs.io/en/mast ... stall.html is my guide.
After the install I could get the Apache testpage on the IP adres of the Dashticz Pi. But... IP/dashticz/index.html delivered 403 Error. Forbidden You don't have permission to access this resource. The error.log says AH00037: Symbolic link not allowed or link target not accessible: /var/www/html/Dashticz. Whatever I tried, this error did not disappear.
As my 'old' system runs on Ubuntu server, I decided to return to that OS. I installed Ubuntu 24.04.2 LTS and repeated the manual install according the webpage above. Result: the same dammed error. After nearly two weeks of looking around for solutions I'am running out of options.
Anyone with a breakthrough idea?
Lokonli
Re: Apache error 403 after fresh manual install OS and Dashticz
Post by Lokonli »
It seems it's not allowed to follow symbolic links.
Check your apache config file:
/etc/apache2/apache2.conf
You probably need to add something like this:
<Directory /var/www/>
	Options Indexes FollowSymLinks
	AllowOverride None
	Require all granted
</Directory>
Lokonli
Post by Lokonli »
or, add something similar to:
/etc/apache2/sites-available/000-default.conf
Afterburner
Thanks for your support.
apache2.conf already has the setting you suggested above, by default.
Adding settings to 000-default.conf didn't solve the problem.
I agree on your suggestion that the symlink is probably the cause of my trouble. But testing the link with sudo realpath or sudo -u <IP> ls -l ..... or simply clicking on de symlink dir didn't show any issue. Owner and filerights are the same as on the 'old' Dashticz etc... so I decided to skip the symlink completely as the purpose of it is not clear anyway.
I installed Dashticz in the DocumentRoot var/www/html which appeared to be the solution.......
Something wrong with the Manual install of Dashticz Master as described in the Dashticz doc??
