New to Domoticz, searching for hardware to replace Qbus
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
mark172
Post by mark172 »
I am very new to Domoticz so my apologies if my questions seem stupid.
At my parents house, there is a Qbus installation with 8 dimmable light circuits en 8 normal relay light circuits.
The 4-button switches are bus connected (EIB cable).
Since we've installed LED's, the dim modules don't work as they should, the resistance of the LED's is too low.
Replacing the modules is +€1200 and since the installation is almost 20 years old, I'm looking to replace it with Domoticz/Home Assistant.
Can anybody point me in the direction of hardware to replace the multi channel relay and dimmer modules?
Are there any switches that can be installed on a bus system, compatible with Domoticz? If so, which one? Or is my only option to use Zigbee switches?
Thank you for your time and reply!
Regards,
Mark
Domoticz version: 2024.7
Re: New to Domoticz, searching for hardware to replace Qbus
Not knowing about QBus but with zigbee this will cost only a fraction of 1200 euro...
If you have wires then perhaps Creasol Dombus is an option https://wiki.domoticz.com/Creasol_Dombus
