Syntax dates in scripts
HennyN
Domoticz version: 2024.7
Post by HennyN »
I hope someone can and will help me.
I have a script I use to calculate my energy costs. That works. But.....
Energy costs change annually, so to compare costs per year, I actually need to add a date line to that.
I see in that script: if (domoticz.time == ‘Between 23:00 and 07:00’), but does that work the same way with a date?
So something like: if (domoticz.date == ‘Between 01-01-2023 and 01-01-2024’) etc....
Is that the right syntax, or does that work differently. It is not yet clear to me from the wiki how to do that.
Ultimately, I want to adjust the rates annually so that I can do clean comparisons over years.
Thanks in advance for answers.
Regards, Henny
Tukker
Domoticz version: 2023.2
Re: Syntax dates in scripts
Post by Tukker »
local startDate = '2023-01-01'
local endDate = '2024-01-01'
local currentDate = domoticz.time.rawDate
if currentDate >= startDate and currentDate < endDate then
    print("Date is between 01-01-2023 and 01-01-2024")
    print("Date is outside the range")
Bugs bug me.
HennyN
Post by HennyN »
Oké, Thanks (Bedankt! HvdW)
I'll work on it and see if I can get it working.
