Hi, quick question: are there others not receiving data anymore via the Buienradar plugin? The plugin seems to run fine, no errors, but no renewal of the data since February, 4th, noon-ish.
Is it me, or is it Buienradar?
Buienradar data problem
- Domoticz version: 2026.3
Re: Buienradar data problem
I have the same, no new buienradar data from feb 4 around 13:30 hrs
Buienradar is having an issue. The feed on https://data.buienradar.nl/2.0/feed/json is showing timestamp":"2025-02-04T13:00:00"
WouterO
Thanks for confirming, now I know it’s not my set-up. Might try the KNMI plugin if the Buienradar issue persists. The problem is loosing my old data, when switching to the KNMI.
I just checked: It started working for me again on 14:15
WouterO
Exactly, here too, at 14:15 new data arrived. Hopefully it stays that way
