/domoticz/domoticz: /lib/x86_64-linux-gnu/libcrypto.so.1.1: version `OPENSSL_1_1_1' not found (required by /home/domoticz)
come on...
Did a fresh install, latest debian (12) on proxmox VM NUC, but now you teling me domoticz needs older OS?
Installed OPENSSL 1.1, but still no good. [edit: apparently not]
Please update wiki and tell us which Ubuntu/Debian version to use
Domotiz not ready for latest Debian?!? Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2024.7
Re: Domotiz not ready for latest Debian?!?
It works but you need to install libssl1.1 as that is replaced by libssl3
There are other topics about this, a little search will find these. Or use the docker environment to get rid of software requirements.
Re: Domotiz not ready for latest Debian?!? -libssl1.1
no thank you, I'm just new in the proxmox matter, and there is not enough will to struglle through Docker USB matter. Or use the docker environment to get rid of software requirements.
attempts to install 1.1: no luck
wget http://security.debian.org/debian-security/pool/updates/main/o/openssl/libssl1.1_1.1.0l-1~deb9u3_amd64.deb
--2025-01-21 18:00:43-- http://security.debian.org/debian-security/pool/updates/main/o/openssl/libssl1.1_1.1.0l-1~deb9u3_amd64.deb
Resolving security.debian.org (security.debian.org)... 151.101.66.132, 151.101.194.132, 151.101.130.132, ...
Connecting to security.debian.org (security.debian.org)|151.101.66.132|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2025-01-21 18:00:43 ERROR 404: Not Found.
wget http://security.ubuntu.com/ubuntu/pool/main/o/openssl/libssl1.1_1.1.1l-1ubuntu1.2_amd64.deb
sudo dpkg -i libssl1.1_1.1.1l-1ubuntu1.2_amd64.deb
sudo apt-get install qtbase5-dev qtchooser qt5-qmake qtbase5-dev-tools
sudo dpkg -i synergy_1.14.3-stable.218fa800_ubuntu21_amd64.deb
--2025-01-21 18:03:11-- http://security.ubuntu.com/ubuntu/pool/main/o/openssl/libssl1.1_1.1.1l-1ubuntu1.2_amd64.deb
Resolving security.ubuntu.com (security.ubuntu.com)... 185.125.190.83, 91.189.91.83, 91.189.91.82, ...
Connecting to security.ubuntu.com (security.ubuntu.com)|185.125.190.83|:80... connected.
2025-01-21 18:03:11 ERROR 404: Not Found.
unfortunatly, beta version also needs the old openssl 1.1.1
Where can i find this old version libssl1.1.1? and openSSL_1_1_1?
I am quite “surprised” that the default Domoticz installation procedure is outdated and there is not a quick fix. Is docker the new default?
How many new users have already dropped out here?
I used this topic to install libssl1
https://stackoverflow.com/questions/721 ... 4#72633324
The package depends on your hardware architecture as explained in the answer. The latest version can be found here: http://nz2.archive.ubuntu.com/ubuntu/po ... l/?C=M;O=D
I used the amd64 version.
wget http://nz2.archive.ubuntu.com/ubuntu/pool/main/o/openssl/libssl1.1_1.1.1f-1ubuntu2.23_amd64.deb
sudo dpkg -i libssl1.1_1.1.1f-1ubuntu2.23_amd64.deb
yes!
thanks a lot Walter
thanks a lot Walter
