Trunkated data on python plugin
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Thorgal789
Post by Thorgal789 »
Hello, I m trying to make a python webserver, based on this one https://github.com/domoticz/domoticz/bl ... istener.py
And I have problem, sometime it work, sometime data are missing, here a sample log with data missing
2024-12-29 17:41:36.230 Climatisation: Calling message handler 'onConnect' on 'module' type object.
2024-12-29 17:41:36.230 Climatisation: Connected successfully to: 192.168.1.105:54962
2024-12-29 17:41:36.231 Climatisation: Name: '192.168.1.105:54962', Transport: 'TCP/IP', Protocol: 'HTTP', Address: '192.168.1.105', Port: '54962', Baud: -1, Timeout: 0, Bytes: 198, Connected: True, Last Seen: 2024-12-29 17:41:36, Parent: 'Server Connection'
2024-12-29 17:41:36.231 Climatisation: Acquiring GIL for 'onConnectCallback'
2024-12-29 17:41:36.231 Climatisation: Processing 'ReadEvent' message
2024-12-29 17:41:36.231 Climatisation: Acquiring GIL for 'ReadEvent'
2024-12-29 17:41:36.231 Climatisation: Received 198 bytes of data
2024-12-29 17:41:36.231 Climatisation: 50 4f 53 54 20 2f 20 48 54 54 50 2f 31 2e 31 0d 0a 48 6f 73 POST./.HTTP/1.1..Hos
2024-12-29 17:41:36.231 Climatisation: 74 3a 20 31 39 32 2e 31 36 38 2e 31 2e 31 3a 38 31 0d 0a 55 t:.192.168.1.1:81..U
2024-12-29 17:41:36.231 Climatisation: 73 65 72 2d 41 67 65 6e 74 3a 20 45 53 50 33 32 48 54 54 50 ser-Agent:.ESP32HTTP
2024-12-29 17:41:36.231 Climatisation: 43 6c 69 65 6e 74 0d 0a 43 6f 6e 6e 65 63 74 69 6f 6e 3a 20 Client..Connection:.
2024-12-29 17:41:36.231 Climatisation: 6b 65 65 70 2d 61 6c 69 76 65 0d 0a 41 63 63 65 70 74 2d 45 keep-alive..Accept-E
2024-12-29 17:41:36.231 Climatisation: 6e 63 6f 64 69 6e 67 3a 20 69 64 65 6e 74 69 74 79 3b 71 3d ncoding:.identity;q=
2024-12-29 17:41:36.231 Climatisation: 31 2c 63 68 75 6e 6b 65 64 3b 71 3d 30 2e 31 2c 2a 3b 71 3d 1,chunked;q=0.1,*;q=
2024-12-29 17:41:36.231 Climatisation: 30 0d 0a 43 6f 6e 74 65 6e 74 2d 54 79 70 65 3a 20 61 70 70 0..Content-Type:.app
2024-12-29 17:41:36.232 Climatisation: 6c 69 63 61 74 69 6f 6e 2f 6a 73 6f 6e 0d 0a 43 6f 6e 74 65 lication/json..Conte
2024-12-29 17:41:36.232 Climatisation: 6e 74 2d 4c 65 6e 67 74 68 3a 20 31 34 34 0d 0a 0d 0a .. .. nt-Length:.144....
2024-12-29 17:41:36.232 Climatisation: Acquiring GIL for 'ReadEvent'
2024-12-29 17:41:36.232 Climatisation: Connection '192.168.1.105:54962' released by Python, reference count is 1.
2024-12-29 17:41:36.232 Climatisation: Pushing 'DisconnectDirective' on to queue
2024-12-29 17:41:36.232 Climatisation: Acquiring GIL for 'CPluginTransportTCP::handleRead'
2024-12-29 17:41:36.232 Climatisation: Pushing 'ReadEvent' on to queue
2024-12-29 17:41:36.282 Climatisation: Processing 'DisconnectDirective' message
2024-12-29 17:41:36.282 Climatisation: Acquiring GIL for 'DisconnectDirective'
2024-12-29 17:41:36.282 Climatisation: Pushing 'onMessageCallback' on to queue
2024-12-29 17:41:36.282 Climatisation: Disconnect directive received for '192.168.1.105:54962'.
2024-12-29 17:41:36.282 Climatisation: Handling TCP disconnect, socket (192.168.1.105:54962) is connected
2024-12-29 17:41:36.283 Climatisation: Acquiring GIL for 'CPluginTransportTCP::handleRead'
2024-12-29 17:41:36.283 Climatisation: Acquiring GIL for 'DisconnectDirective'
2024-12-29 17:41:36.283 Queued asynchronous read aborted (192.168.1.105:54962), [125] Operation canceled.
2024-12-29 17:41:36.283 Climatisation: Pushing 'DisconnectedEvent' on to queue
2024-12-29 17:41:36.283 Climatisation: Processing 'ReadEvent' message
2024-12-29 17:41:36.283 Climatisation: Acquiring GIL for 'ReadEvent'
2024-12-29 17:41:36.283 Climatisation: Received 144 bytes of data
2024-12-29 17:41:36.283 Climatisation: 7b 22 74 65 6d 70 65 72 61 74 75 72 65 22 3a 31 37 2c 22 66 {"temperature":17,"f
2024-12-29 17:41:36.283 Climatisation: 61 6e 22 3a 22 51 55 49 45 54 22 2c 22 76 61 6e 65 22 3a 22 an":"QUIET","vane":"
2024-12-29 17:41:36.283 Climatisation: 34 22 2c 22 77 69 64 65 76 61 6e 65 22 3a 22 7c 22 2c 22 6d 4","widevane":"|","m
2024-12-29 17:41:36.283 Climatisation: 6f 64 65 22 3a 22 48 45 41 54 22 2c 22 70 6f 77 65 72 22 3a ode":"HEAT","power":
2024-12-29 17:41:36.283 Climatisation: 22 4f 4e 22 2c 22 72 6f 6f 6d 54 65 6d 70 65 72 61 74 75 72 "ON","roomTemperatur
2024-12-29 17:41:36.283 Climatisation: 65 22 3a 31 38 2c 22 63 6f 6d 70 72 65 73 73 6f 72 46 72 65 e":18,"compressorFre
2024-12-29 17:41:36.283 Climatisation: 71 75 65 6e 63 79 22 3a 30 2c 22 61 63 74 69 6f 6e 22 3a 74 quency":0,"action":t
2024-12-29 17:41:36.283 Climatisation: 72 75 65 7d .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. rue}
2024-12-29 17:41:36.284 Climatisation: Processing 'onMessageCallback' message
2024-12-29 17:41:36.284 Climatisation: Acquiring GIL for 'onMessageCallback'
2024-12-29 17:41:36.284 Climatisation: Calling message handler 'onMessage' on 'module' type object.
2024-12-29 17:41:36.284 Climatisation: onMessage called for connection: 192.168.1.105:54962
2024-12-29 17:41:36.284 Status: Climatisation: New mitubishi device detected: 192.168.1.105
2024-12-29 17:41:36.284 Status: Climatisation: POST request received.{'Verb': 'POST', 'URL': '/', 'Headers': {'Host': '192.168.1.1:81', 'User-Agent': 'ESP32HTTPClient', 'Connection': 'keep-alive', 'Accept-Encoding': 'identity;q=1,chunked;q=0.1,*;q=0', 'Content-Type': 'application/json', 'Content-Length': '144'}}
2024-12-29 17:41:36.284 Climatisation: Processing 'DisconnectedEvent' message
2024-12-29 17:41:36.284 Climatisation: Acquiring GIL for 'DisconnectedEvent'
2024-12-29 17:41:36.284 Climatisation: Disconnect event received for '192.168.1.105:54962'.
2024-12-29 17:41:36.284 Climatisation: Pushing 'onDisconnectCallback' on to queue
2024-12-29 17:41:36.284 Climatisation: Processing 'onDisconnectCallback' message
2024-12-29 17:41:36.284 Climatisation: Acquiring GIL for 'onDisconnectCallback'
2024-12-29 17:41:36.285 Climatisation: Calling message handler 'onDisconnect' on 'module' type object.
2024-12-29 17:41:36.285 Climatisation: onDisconnect called for connection '192.168.1.105:54962'.
There is something that abord the procedure, but I don't see what I m doing bad
   def onMessage(self, Connection, Data):
        Domoticz.Debug("onMessage called for connection: "+Connection.Address+":"+Connection.Port)
        #All the message is done ?
        Domoticz.Log("Byte needed : " + str(Connection.BytesTransferred()) +  "ATM : " + str(len(Data)))
        # Incoming Requests
        if "Verb" in Data:
            strVerb = Data["Verb"]
            #strData = Data["Data"].decode("utf-8", "ignore")
            Domoticz.Status(strVerb + " request received." + str(Data))
            #Answer to client
            if Connection.Connected()
                Connection.Send({"Status":"200 OK", "Headers": {"Connection": "keep-alive", "Accept": "Content-Type: text/html; charset=UTF-8"}})
And BTW
What is this port "54962", the webserver is listening on port 80 ......
Last edited by Thorgal789 on Monday 30 December 2024 18:38, edited 1 time in total.
Thorgal789
Re: Trunkated data on python plugin
Something different on a working request
Not working
The "Bytes" is only the header, but in the working request, there is the total request, so there is problem at start already .
2024-12-29 17:44:00.327 Climatisation: Name: '192.168.1.105:54963', Transport: 'TCP/IP', Protocol: 'HTTP', Address: '192.168.1.105', Port: '54963', Baud: -1, Timeout: 0, Bytes: 342, Connected: True, Last Seen: 2024-12-29 17:44:00, Parent: 'Server Connection'
And about
Thorgal789
BTW an admin can move this topic in "bugs and problems" ?
For me this issue have nothing to see with python, but directly with the domoticz framework.
Thorgal789
Hello, I think there is enought information on logs to see a problem in the python framework ? It's a pity it's not able to work with a simple request as a webserver.
If someone have a possible workaround to test ? I have access to both server and client.
