Error 403 by installing domoticz
hansdeh
I ran into this problem
Last login: Fri Jan 3 23:01:18 2025 from 192.168.1.107
pi@domo-spion:~ $ sudo bash -c "$(curl -sSfL https://install.domoticz.com)"
curl: (22) The requested URL returned error: 403
pi@domo-spion:~ $
Earlier on that evening i succeed an installaties. I noticed that domoticz.com received a new ssl cetrificate in between my succesfull installaties and my failure.
pi@domo-spion:~ $
- gizmocuz
Re: Error 403 by installing domoticz
Thanks for reporting. Should work again
Daans
I ran into a similair problem at ~10.50.
From my browser on my laptop i can access: domoticz_linux_aarch64.tgz
It seems that by access from the rpi there is no reponse.
pi@domoticz:~ $ sudo bash -c "$(curl -sSfL https://install.domoticz.com)"
::: You are root.
::: Verifying free disk space...
::: Checking apt-get for upgraded packages.... done!
::: Your system is up to date! Continuing with Domoticz installation...
::: Checking for apt-utils... installed!
::: Checking for whiptail... installed!
::: Checking for git... installed!
::: Checking for curl... installed!
::: Checking for unzip... installed!
::: Checking for wget... installed!
::: Checking for sudo... installed!
::: Checking for cron... installed!
::: Checking for libudev-dev... installed!
::: Checking for libssl1.1... installed!
::: Checking for libcurl4... installed!
::: Checking for libusb-0.1... installed!
::: Downloading Domoticz
::: Current User: pi
HTTP Port:
::: Destination folder=/home/pi/domoticz
URL transformed to HTTPS due to an HSTS policy
Connecting to www.domoticz.com (www.domoticz.com)|2606:4700
:6815:2001|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://releases.domoticz.com/release/d ... arch64.tgz [following]
Resolving releases.domoticz.com (...)... 2606:4700
:6815:3001, 2606:4700
:6815:6001, 2606:4700
:6815:7001, ...
Connecting to releases.domoticz.com (...)|2606:4700
:6815:3001|:443... connected.
HTTP request sent, awaiting response... 403 Forbidden
2025-01-04 10:02:18 ERROR 403: Forbidden.
::: You are root.
HTTP Port:
- MaffeMuis
- Domoticz version: 3.9483
I have the same problem
--2025-01-04 13:48:46-- https://www.domoticz.com/download.php?channel=release&type=release&system=linux&machine=armv7l
Resolving www.domoticz.com (www.domoticz.com)... 104.21.64.1, 104.21.48.1, 104.21.80.1, ...
Connecting to www.domoticz.com (www.domoticz.com)|104.21.64.1|:443... connected.
Location: https://releases.domoticz.com/release/domoticz_linux_armv7l.tgz [following]
--2025-01-04 13:48:46-- https://releases.domoticz.com/release/domoticz_linux_armv7l.tgz
Resolving releases.domoticz.com (releases.domoticz.com)... 104.21.32.1, 104.21.96.1, 104.21.48.1, ...
Connecting to releases.domoticz.com (releases.domoticz.com)|104.21.32.1|:443... connected.
2025-01-04 13:48:46 ERROR 403: Forbidden.Ik ben en blijf een brabander!
|Node-Red|Mqtt|ESPboards|tasmota|NAS|
I have the san=me error at 17:00
ErikvdB
Unfortunately i get the same error message during a new install.
wpsabek
- Domoticz version: 2024.7
I confirm that I have the same error during installation on the Linux x86_64 platform.
danjardmathieu
Same here '-(
--2025-01-05 09:38:01-- https://releases.domoticz.com/release/d ... arch64.tgz
Resolving releases.domoticz.com (releases.domoticz.com)... 104.21.80.1, 104.21.64.1, 104.21.48.1, ...
Connecting to releases.domoticz.com (releases.domoticz.com)|104.21.80.1|:443... connected.
2025-01-05 09:38:01 ERROR 403: Forbidden.
Any idea how to go through ?
wpsabek
Only @gizmocuz help us...
geezer
I am getting the same error (Pi 5; OS Bookwurm 64 bit).
geezer
It works again now
- Domoticz version: 2025.1
Gizmocuz did a change around 12 today so it should work again hopefully...
roman
I'm getting the same error (PI3B, Bullseye 64).
I undertsand that the problem is not from me ?
@Gizmocuz can you help me ?
roman
Cloudflare recaptcha was switched on yesterday due to website attacks. So this probably also affected the install script.
It is reported to @gizmocuz and hopefully fixed soon...
Ric68
The problem is still there
PHIL63
Confirmed, the problem is still there when trying to update Domoticz
Install/update should be working now, ddos protection is switched off for the download section of Domoticz.com
PHIL63
Yes all is comebackwaltervl wrote: Thursday 04 September 2025 17:17 Install/update should be working now, ddos protection is switched off for the download section of Domoticz.com
