I've added a couple of Zigbee nodes with the ZigBeeforDomoticZ plug-in. Now I need to delete some nodes in the ZigBeeforDomoticZ Admin Interface (V7.1.018, Dutch). However, I don't understand how to do this. I cannot select a node and whatever I do, no garbage bin icon shows up.
Any tips?
How delete
- Domoticz version: 2024.7
Re: How delete
You first have to delete all the node related devices from Domoticz and then mostly the zigbee node will also be removed from Z4D. If not then you have the possibility to remove the node in Z4D
- Domoticz version: V2024.7
Re: How delete
I would advice to consider zigbee2mqtt. That's having a dashboard from which deleting is quit easy.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
- Target OS: -
Re: How delete
@BartSr you have tried the Z4D dashboard before saying that ?
It's the second post from you I m seing today, just for saying zigbee2mqtt is better, but without helping and just propose something that can have exactly the same issue.
Re: How delete
Z4D also has a dashboard..... Only deleting is mainly managed from Domoticz....
