zigbee2mqtt problem appearance 'XYZ movement sensor'
Subforum for general discussions. Do not dump your questions/problems here, but try to find the subforum where it belongs!
BartSr
Domoticz version: V2024.7
Post by BartSr »
Hi.
I am having a Zigbee Tuya movement sensor with reacts as expected. But once for a longer time there has been no movement the 'x,y and z' sensor in 'utilities' tab shows up in domoticz red colored. Same sensor has 'vibration and tilt'measureing which shows and stays normal in 'switches' tab.
Movement of sensor makes them sow correct value in correct color.
Is there a solution for this to keep them 'normal colored'?
TIA
Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
gizmocuz
Re: zigbee2mqtt problem appearance 'XYZ movement sensor'
Post by gizmocuz »
That's just a sensor timeout and you don't have to worry about it
BartSr
Post by BartSr »
Thanks, also happens with a zwave device. But can I prevent this in a way?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
Domoticz version: 2024.7
Change the timeout setting in menu setup - settings
BartSr
Post by BartSr »
thanks.
with knowledge as is now I understand meaning of that setting.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
BartSr
Post by BartSr »
investigating more setting options:
I tried timer plans but clicking on the pulldown has no effect.
Not longer in use?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
gizmocuz
Post by gizmocuz »
Please don't mix topics, and sure timer plans are still working
