Update FW of RFX433E in Docker
wvries
Domoticz version: latest B
Post by wvries »
I am running DZ in docker for some time now and no problems.
I was looking at the FW of my receiver and wanted to update to the latest one.
Am I going crazy or is there no option to update the FW of the RFXCOM device in DZ Docker ?
Screenshot 2024-12-29 at 16.35.30.png (183.93 KiB) Viewed 4363 times
Screenshot 2024-12-29 at 16.35.21.png (163.41 KiB) Viewed 4363 times
gizmocuz
Re: Update FW of RFX433E in Docker
Post by gizmocuz »
Firmware update option has been removed on request as this was not working 100% and could cause some dangerous issues.
Therefor you just need to update via the RFXFlash application
wvries
Post by wvries »
Thanks for the quick answer...
will dig up an old rpi and just install a copy of DZ to do the upgrade there..
Domoticz version: 2026.3
wvries wrote: Sunday 29 December 2024 17:31 Thanks for the quick answer...
Seems you are drawing the wrong conclusion here.... Updating firmware by Domoticz can cause dangerous issues (brick?)!!
PieterS
Domoticz version: 2024.7
Post by PieterS »
As far as I know:
After downloading the manager to a computer, upgrading the firmware and configuring is possible if you connect the device to a laptop.
Saves time I guess😑
Synology with Domoticz build (V2024.7) in Docker
wvries
Post by wvries »
PieterS wrote: Sunday 29 December 2024 19:48 As far as I know:
Saves time I guess😑
Would be, but I have either Linux or MacOS, so no windows....
And windows emulator on Mac is not working for this (tried and failed)
So just install a quick DZ on an older RPI...
gizmocuz
Post by gizmocuz »
You should be able to use wine to run the RFXFlash utility.
You can also install a fresh windows copy and use it for free the first month(s)
For mac, you can use parallels
BartSr
Domoticz version: V2024.7
Post by BartSr »
interesting to know why to update.
can you inform?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
