posting data
Re: posting data
Strange thing is that I’m losing all my parameters.
- habahabahaba
- Domoticz version: 2024.4
Re: posting data
So... may be its Docker problem?
Re: posting data
Don’t know. If I do this from the Docker/Domoticz bash, that does work:
curl -d "param1=value1¶m2=value2" -X POST http://localhost:3000/data- habahabahaba
Re: posting data
so you can use
domoticz.executeShellCommand('curl ...')
Re: posting data
But then I would still be where I don’t want to be. Think I’ll let this rest for now as I’m also looking into a Python option for me endgoal.
- Domoticz version: 2025.1
Re: posting data
There is also something like httplink datapush https://wiki.domoticz.com/HttpLink
HttpLink uses the a http(s) stream to push data from Domoticz devices to a server accepting http requests (GET, POST, PUT). The function can be accessed from the setup menu: setup > more options > data push > HTTP.
- habahabahaba
Re: posting data
You are testing curl on http://localhost:3000 and dzvents on https://domain.tld/script
https is 443 port.
Is it right?
Did you check the URLs and port numbers?
https is 443 port.
Is it right?
- habahabahaba
Re: posting data
Firewall on https?
Re: posting data
The values I’m posting here are only demo values as I don’t want to disclose the true urls of course. My goals was using POST as the variables are more clear in the code. I know, this is an OCD/first problem thing, but it should work but I can seem to find why it’s not.
Users browsing this forum: hemant5400z and 1 guest
