Version: 2024.7 (build 16267)
Build Hash: 83c3c5310
Compile Date: 2024-09-30 09:17:12
dzVents Version: 3.1.8
Python Version: 3.9.2 (default, Feb 28 2021, 17:03:44) [GCC 10.2.1 20210110]
timer function works strangely
The problem occurs with 2 of my Zigbee Ikea lights GU 10 RGBWW
No problems with other brand lamps
If the timer of a switch is set to 4:00 PM, it will turn off after 10 seconds.
If you turn it on manually, it will stay on.
It worked correctly on older versions
Timer function works strangely
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
- Domoticz version: 2024.7
Re: Timer function works strangely
How are your zigbee devices controlled? By Zigbee2MQTT with Domoticz MQTT AD? Or a plugin?
By plugin
ZigBeeforDomoticZ plug-in Admin Interface
Versie 7.1.007
Versie 7.1.007
You do not have off delay enabled in edit device?
Perhaps you have device attributes configured in zigbeefordomoticz plugin?
What does the log say? Who is switching off the device?
Be aware that for testing timers you should set the timer minimum 2 minutes ahead of current time to get Domoticz properly configured.
I have update Zigbee for Domoticz
Pair all devices
En have new testing the lamp
Same problem.
Where the off command is coming from?
Pair all devices
Same problem.
- probleem Zigbee.JPG (68.6 KiB) Viewed 1037 times
- probleem Zigbee 2.JPG (98.06 KiB) Viewed 1037 times
- probleem Zigbee 1.JPG (161.25 KiB) Viewed 1037 times
It seems to come from the Zigbee plugin. So check the device settings in the plugin user interface (website on port 9440).
Else send a Private Message to user pipiche as he is the plugin author.
I send a mail
Private Message not yet responding
how can i downgrade Domoticz for Zigbee?
I think that version 7.1.001 works wel for me in the past
I will try that.
Now i on 7.1.012
I will try that.
Now i on 7.1.012
you can simply do:
git checkout stable7-7.1.001
Wiki is available here.
Zigbee for Domoticz FAQ
