.afterSec(xx) not working? :(
BarryT
Domoticz version: 2024.3
Post by BarryT »
hi all,
can somebody help me out why my delay does not work?
i'm trying to make a heating script with zones, a buffertank with pump and an weather temperature based heatpump with an on/off input.
the rest of the scripts works (with thermostats, heatcommand to heatpump and opening the valves,
but i want to have my tankpump to have a delay of 3 minutes before it goes ON due opening of the valves that takes some minutes before they are open...
This code
local heating if hp.heater ~= nil then heating = dz.devices(hp.heater) end
works correctly but does not have any delay. when one of the valves has turned ON the pump is also going ON directly.
The next code does NOT work :(
local Delay = 30
local heating if hp.heater ~= nil then heating = dz.devices(t.heater).afterSec(Delay) end
I was hoping this would do the trick, but then i'm getting an error:
 attempt to call a nil value (field 'afterSec')
Why does this delay not work?
Many thanks!
Fredom
Domoticz version: 2026.3
Re: .afterSec(xx) not working? :(
Post by Fredom »
BarryT wrote: Friday 22 November 2024 21:35 hi all,
This code
local Delay = 30
Many thanks!
I use
local Delay = 30
local heating if hp.heater ~= nil then heating = dz.devices(t.heater).switchOff().afterSec(Delay) end
Yours sincerely,
Fred
Rasberry Pi 3B+ - Debian Trixie - Domoticz 2026.3
RFLink - RFXCom - Z4D 9.1 (CC2652rb)
P1 Smart Meter - KaKu
AfterSec() is a command option so should be used in combination with a supported command like .switchOn() .switchOff() etc
In the wiki there is a general availability table https://wiki.domoticz.com/DzVents:_next ... ailability
Also per device command it is noted in the wiki if it supports by command options.
BarryT
Post by BarryT »
waltervl wrote: Friday 22 November 2024 22:43 AfterSec() is a command option so should be used in combination with a supported command like .switchOn() .switchOff() etc
Ahh i see, so thats why it doesnt work..
Any idea to get it working?
Use something like
domoticz.devices('tankpump').switchOn().afterMin(3)
