Device Notification on/off setting just like timers (active) Topic is solved
- Domoticz version: 3.4834
I have the following usecase;
When i leave home i activate the "away" switch.
When "away" i want to receive notifications of motion- and doorsensors for example.
My request is:
What i would like to do is to toggle notification settings for specific devices to 'ON' (or active) just like i can with timers for each device.
When i am home, i don't need to be notified when there is movement in the house, especially not over and over again, day or night, so i'd like to turn OFF notification settings then and/or activate a second setting that would send notifications with different settings. (low priority)
I don't see this option in the JSON/API, this is where/how i would like to control the notification setting.
My request is:
- waaren
Re: Device Notification on/off setting just like timers (active)
There is no active = true or active = false type of setting for notifications.marmachine wrote: ↑Thursday 18 March 2021 12:11 When "away" i want to receive notifications of motion- and doorsensors for example.
One way to workaround this would be to set the target notification system to one you do not use. In my case that would be kodi.
The 'deactivate' call would then look look like
http://<domoticz ip:domoticz:port>/json.htm?devidx=54&idx=17¶m=updatenotification&tmsg=&tpriority=1&tsendalways=false&tsystems=kodi&ttype=7&tvalue=0&twhen=0&type=command
The 'reactivate' call would then look look like
http://<domoticz ip:domoticz:port>/json.htm?devidx=54&idx=17¶m=updatenotification&tmsg=&tpriority=1&tsendalways=false&tsystems=email;fcm;http&ttype=7&tvalue=0&twhen=0&type=command
Excellent, thank you Waaren!
- Domoticz version: 2024.7
Hello everyone,
I am French and sorry in advance if the translation is not quite correct.
I allow myself to raise this subject because despite several tests on two different machines under raspberry the workaround to disable a notification given by "waaren" does not work or no longer works.
Here is the Domoticz version:
Version: 2024.7
dzVents Version: 3.1.8
Python Version: 3.9.2
If you have an idea I am a taker.
Thank you and have a good day.
Version: 2024.7
So what is not working? You do not see the notification system on the selected device switch to for example only Kodi?furtifc wrote: ↑Wednesday 20 November 2024 16:27 Hello everyone,
See also the wiki for all the know notification API calls: https://wiki.domoticz.com/Domoticz_API/ ... ifications
Thank you for your answer, Yes that's exactly it, the notification on the selected device does not only go to kodi.
If I run the command line below via my browser on my PC here is the answer:
http://laudouard.hd.free.fr:25041/share ... pture1.JPG
I have the same error message with the function: Add device notification, while the order : Get device notifications it's ok.
https://192.168.1.14:443/json.htm?devidx=820&idx=30¶m=updatenotification&tmsg=&tpriority=1&tsendalways=false&tsystems=kodi&ttype=7&tvalue=0&twhen=0&type=command
A less complex API call like below is working (change deviceIDX)?
IP:Port/json.htm?idx=<deviceIDX>¶m=getnotificationtypes&type=command
Yes it works. Screenshot on the link below
http://laudouard.hd.free.fr:25041/share ... pture2.JPG
Can you reproduce this malfunction at your level, am I the only one?
Thank you.
Thank you.
Last edited by furtifc on Wednesday 20 November 2024 18:24, edited 1 time in total.
Yes, I have the same issue with the documented API call.
But the good news is that the API has changed and now also is able to really enable and disable the notification with parameter tactive=false|true
The API you can use is for example to switch off and set only http as notification system.
/json.htm?devidx=<devID>&idx=<ID>¶m=updatenotification&taction=&tactive=false&tmsg=&tpriority=0&tsendalways=false&tsystems=http&ttype=7&tvalue=0&twhen=0&type=command
I changed the wiki so it now is documented correctly:
Added is
taction=<action command>
tactive=<true/false>
/json.htm?devidx=<DeviceID>&idx=<notificationID>¶m=updatenotification&taction=<action command>&tactive=<true/false>&tmsg=<msgText>&tpriority=<pri>&tsendalways=<true/false>&tsystems=<list of notification subsystems>&ttype=<notificationType>&tvalue=0&twhen=0&type=command
Too strong! It's perfect! It works very well and it's a feature that was missing.
Thank you very much for your responsiveness and availability.
I add a clarification, this command line does not support spaces in the message section: &tmsg=<msgText>
Via the pc browser it's ok, but not from the command of a domoticz switch it's no. If we replace the spaces with a _ it works.
example:
&tmsg=Opening balcony door& = error
&tmsg=Opening_balcony_door& = OK
example:
You probably have to urlencode the message as indicated in the wiki.
Will be
&tmsg=Opening%20balcony%20door%26%20%3D%20error
Will be
Thanks for your feedback, it works well with the %20 on the spaces.
On the other hand, the disadvantage of the true or false of the notification via an Update device notifications is that the idx of the notification changes, strangely it is not systematically but sometimes the idx changes while the only modification of the command is the true or false. In script mode it poses a problem.
The workaround by adding and removing the notification doesn't seem to work for me.
Same error message as at the beginning of the upgrade command.
Here is the tested command:
http://<domoticz ip:domoticz:port>/json.htm?idx=93¶m=addnotification&tmsg=test&tpriority=0&tsendalways=true&tsystems=fcm;http&ttype=7&tvalue=0&twhen=0&type=command
Same issue here. Add device notification doesn't work. My goal is to disable notifications temporarily for a few switches. As mentioned by user furtifc the notification idx changes once updated which is kinda awkward having to query the device each time to get the new notification idx.
I was able to work around simply because I use Custom HTTP/Action notiffication to send xmpp as described on Wiki. I updated the script to query a switch in order to toggle alarming.
I'm running Version: 2024.7
Build Hash: b317cfab1
Compile Date: 2024-07-13 16:59:31
# Add device notification
pi@domoticz:~ $ curl -sk 'https://admin:passwd@localhost:443/json.htm?idx=2¶m=addnotification&tmsg=test&tpriority=0&tsendalways=true&tsystems=fcm;http&ttype=7&tvalue=0&twhen=0&type=command'
"status" : "ERR"
# Update device notifications
pi@domoticz:~ $ curl -sk 'https://admin:passwd@localhost:443/json.htm?devidx=2&idx=1¶m=updatenotification&tactive=true&tmsg=test&tpriority=0&tsendalways=true&tsystems=kodi;email&ttype=7&tvalue=0&twhen=0&type=command'
"status" : "OK",
"title" : "UpdateNotification"
pi@domoticz:~ $ curl -sk 'https://admin:passwd@localhost:443/json.htm?type=command¶m=getnotifications&idx=2'|grep idx
"idx" : 3
#!/bin/sh
ALARM=`curl -sk 'https://admin:passwd@localhost:443/json.htm?type=command¶m=getdevices&rid=4'|grep Status|cut -d'"' -f4`
if [ "$ALARM" = "On" ];then
echo "$4" | sudo /usr/bin/sendxmpp -t -u $1 -o $2 $3
fi
