SmartEvse support
rron
Re: SmartEvse support
Ok that is clear, The rest off the topics are working good. Again thanks for the effort.
Tukker
- Domoticz version: 2023.2
Simplified SmartEVSE switch
I wrote a script and created a switch to switch the SmartEVSE module.
The switch is a selector switch in which you add values Off, 6A, 8A, 10A, 13A, 16A
The script:
Whilst I was at it I wrote another script to display the SmartEVSE data in a text device:
Comment the dumptable out when ready as well as change LOG_DEBUG to LOG_ERROR
To complete it here's the automatic charging on sunpower part.
This work leans heavily on the work done by akamming for the Volvo plugin.
The script:
devices = {'EV Charging',},
data = {},
logging = {
-- Level can be domoticz.LOG_INFO, domoicz.LOG_MODULE_EXEC_INFO, domoticz.LOG_DEBUG, domoticz.LOG_ERROR or domoticz.LOG_FORCE
--level = domoticz.LOG_INFO,
level = domoticz.LOG_DEBUG,
marker = '----EV Charging-----',
execute = function(domoticz, triggerObject)
-- domoticz.devices(EV Charging).dump()
local EVSwitch = domoticz.devices('EV Charging')
if EVSwitch.state == 'Off' then
domoticz.log('4 EVSwitch set to off :' .. EVSwitch.state,domoticz.LOG_DEBUG)
domoticz.executeShellCommand('mosquitto_pub -h 192.168.2.XXX -t "SmartEVSE-5678/Set/CurrentOverride" -m 0')
elseif EVSwitch.state == '6A' then
domoticz.log('5 EVSwitch set to 6A :' .. EVSwitch.state,domoticz.LOG_DEBUG)
domoticz.executeShellCommand('mosquitto_pub -h 192.168.2.XXX -t "SmartEVSE-5678/Set/CurrentOverride" -m 60')
elseif EVSwitch.state == '8A' then
domoticz.log('6 EVSwitch set to 8A :' .. EVSwitch.state,domoticz.LOG_DEBUG)
domoticz.executeShellCommand('mosquitto_pub -h 192.168.2.XXX -t "SmartEVSE-5678/Set/CurrentOverride" -m 80')
elseif EVSwitch.state == '10A' then
domoticz.log('7 EVSwitch set to 10A :' .. EVSwitch.state,domoticz.LOG_DEBUG)
domoticz.executeShellCommand('mosquitto_pub -h 192.168.2.XXX -t "SmartEVSE-5678/Set/CurrentOverride" -m 100')
elseif EVSwitch.state == '13A' then
domoticz.log('8 EVSwitch set to 13A :' .. EVSwitch.state,domoticz.LOG_DEBUG)
domoticz.executeShellCommand('mosquitto_pub -h 192.168.2.XXX -t "SmartEVSE-5678/Set/CurrentOverride" -m 130')
elseif EVSwitch.state == '16A' then
domoticz.log('9 EVSwitch set to 16A :' .. EVSwitch.state,domoticz.LOG_DEBUG)
domoticz.executeShellCommand('mosquitto_pub -h 192.168.2.XXX -t "SmartEVSE-5678/Set/CurrentOverride" -m 160')
}Code: Select all
--SmartEVSE state
-- Howto at Luftdaten https://www.domoticz.com/forum/viewtopic.php?f=72&t=23406&hilit=luftdaten
-- Call SmartEVSE with http://192.168.2.xxx/settings
active = true,
timer = { 'every 1 minutes' },
httpResponses = { 'SmartEVSEStateRetrieved' }, -- matches callback string below
logging = {
marker = '----SmartEVSE state-----',
if (item.isTimer) then
local EVSE_Connected = ' '
domoticz.openURL({
url = 'http://192.168.2.xxx/settings',
method = 'GET',
callback = 'SmartEVSEStateRetrieved'
elseif (item.isHTTPResponse) then
if (item.ok and item.isJSON) then
domoticz.utils.dumpTable(item.json) -- dumpTable laat alle waarden zien, mooi voor debugging
domoticz.log('#1 override current :' .. item.json.settings.override_current,domoticz.LOG_DEBUG)
--domoticz.log('#2 Plug connected state :' .. item.json.evse.connected,domoticz.LOG_DEBUG)
if item.json.evse.connected == 1 then
EVSE_Connected = 'Connected'
EVSE_Connected = 'Not Connected'
domoticz.devices('SmartEVSE state').setIcon(107)
domoticz.devices('SmartEVSE state').updateText('Current charging level set    ' .. math.floor(item.json.settings.override_current/10) ..' A'..
'\n Charging cable position  ' .. EVSE_Connected ..
'\n ')
-- oops
domoticz.log('Error fetching SmartEVSE', domoticz.LOG_DEBUG)
-- Volvo XC40 solar power charging
-- Auto laden is Dutch for car charging
-- Volvo aangesloten is Dutch for Volvo is plugged in
Charging speed
16A - 3500 W
15A - 3450 W
14A - 3200 W
13A - 3000 W
12A - 2730 W
11A - 2500 W
10A - 2300 W
9A - 2000 W
8A - 1850 W
7A - 1650 W
6A - 1440 W
local switchOnValue = 1400 -- Watt sunpower level is minimum charching level for SmartEVSE
local switchOffValue = 500 -- = energy used, >0 to prevent too often switchoff
timer = {'every 2 minutes at daytime'},
devices = {'Volvo-aangesloten'},
logging = {
-- change LOG_DEBUG to LOG_ERROR to stop logging in the log
marker = 'XC40 laden op zonnestroom',
execute = function(domoticz, triggeredItem)
-- domoticz.log(domoticz.devices('XC40 battery charge set').dump(),domoticz.LOG_DEBUG)
-- domoticz.log(domoticz.devices('XC40-ChargeLevel').dump(),domoticz.LOG_DEBUG)
-- domoticz.log(domoticz.devices('Volvo-aangesloten').dump(),domoticz.LOG_DEBUG)
-- domoticz.log(domoticz.devices('Volvo-Distance2Home').dump,domoticz.LOG_DEBUG)
-- domoticz.devices('Volvo-Distance2Home').dump()
-- domoticz.devices('Power').dump()
-- domoticz.devices('Auto laden').dump()
local current_time = os.date("%c")
local chargeLevelSet = domoticz.devices('XC40 battery charge set').level
local chargeLevelActual = domoticz.devices('XC40-ChargeLevel').nValue -- is een int en niet iets met een komma XC40-ChargeLevel
local DistanceFromHome = domoticz.devices('Volvo-Distance2Home').sensorValue
local isConnected = domoticz.devices('Volvo-aangesloten').state
local SunnyPower = tonumber(domoticz.devices('Power').rawData[6]) -- opbrengst zonnepanelen
local PowerConsumption = tonumber(domoticz.devices('Power').rawData[5]) -- power consumption @home
local VolvoOpladen = domoticz.devices('Volvo-Opladen').state
domoticz.log('Volvo charging cable connected :' .. domoticz.devices('Volvo-aangesloten').state,domoticz.LOG_DEBUG)
domoticz.log('Volvo distance from home is :'.. DistanceFromHome ,domoticz.LOG_DEBUG)
domoticz.log('Volvo opladen is :'.. VolvoOpladen ,domoticz.LOG_DEBUG)
domoticz.log('Energy usage from the network :'.. PowerConsumption ,domoticz.LOG_DEBUG)
domoticz.log('Energy return to the network :'.. SunnyPower ,domoticz.LOG_DEBUG)
-- DistanceFromHome is used to prevent switching when the car is connected to a charger elsewhere
-- charging on sunpower only if charging is NOT switched on manually
if DistanceFromHome < 0.35 and isConnected ~= 'Disconnected' and chargeLevelActual < chargeLevelSet and domoticz.globalData.chargingSwitchedManual == 0 then
-- gaan we laden op zonnestroom
-- local PowerConsumption = tonumber(domoticz.devices('Power').rawData[5]) -- power consumption @home
-- local SunnyPower = tonumber(domoticz.devices('Power').rawData[6]) -- opbrengst zonnepanelen
-- 6A is 1400 Watt
-- 8A is 1750 Watt
-- 10A is 2200 Watt
-- 13A is 2800 Watt
-- 16A is 3200 Watt
-- mosquitto_pub -h 192.168.2.xxx -t "SmartEVSE-5678/Set/CurrentOverride" -m 111
if SunnyPower >= switchOnValue then
if SunnyPower >= switchOnValue and SunnyPower < 1750 then
domoticz.executeShellCommand('mosquitto_pub -h 192.168.2.xxx -t "SmartEVSE-5678/Set/CurrentOverride" -m 60')
elseif SunnyPower >= 1750 and SunnyPower < 2200 then
domoticz.executeShellCommand('mosquitto_pub -h 192.168.2.xxx -t "SmartEVSE-5678/Set/CurrentOverride" -m 80')
elseif SunnyPower >= 2200 and SunnyPower < 2800 then
domoticz.executeShellCommand('mosquitto_pub -h 192.168.2.xxx -t "SmartEVSE-5678/Set/CurrentOverride" -m 100')
elseif SunnyPower >= 2800 and SunnyPower < 3200 then
domoticz.executeShellCommand('mosquitto_pub -h 192.168.2.xxx -t "SmartEVSE-5678/Set/CurrentOverride" -m 130')
elseif SunnyPower >= 3200 then
domoticz.executeShellCommand('mosquitto_pub -h 192.168.2.xxx -t "SmartEVSE-5678/Set/CurrentOverride" -m 160')
domoticz.data.chargingUsingSunPower = 1
domoticz.log('# 1 We laden nu op zonnestroom :' ,domoticz.LOG_DEBUG)
domoticz.log('#2 Teruglevering aan het net is :'.. SunnyPower ,domoticz.LOG_DEBUG)
local subject = '#1 We laden nu op zonnestroom !'
local message =
' ' .. current_time .. '\n'..
'Volvo current battery level is : ' .. chargeLevelActual .. '\n'
domoticz.notify(subject, message, domoticz.PRIORITY_NORMAL)
if PowerConsumtion >= switchOffValue then
domoticz.executeShellCommand('mosquitto_pub -h 192.168.2.xxx -t "SmartEVSE-5678/Set/CurrentOverride" -m 0')
domoticz.log('Stroom van het net is :'.. PowerConsumption ,domoticz.LOG_DEBUG)
local subject = '#3 We laden niet langer op zonnestroom !'
local message =
if chargeLevelActual >= chargeLevelSet then
local subject = '#3 Zonnestroomladen uit wegens bereiken max. '
local message =
'Volvo battery level setting : ' .. chargeLevelSet .. '\n' ..
'Volvo battery level state : ' .. chargeLevelActual .. '\n'
domoticz.log('#8 Laden zonnestroom aan het eind van het script status :',domoticz.LOG_DEBUG)
Bugs bug me.
rron
Thank you, I will try this on my test system
rron
I have a small problem which I cannot solve. If you look at the device screen you can see that "EVEnergyCharged"and "EVTotalEnergyCharged"has a 11 in front of the value 10.649.
If you look at the mqtt explorer you see the right value. I tried to change this in de mapper.json with the multiplier 0.001 but that didn´t solve the problem.
- Schermafdruk van 2024-11-17 13-59-15.png (204.54 KiB) Viewed 6358 times
- Schermafdruk van 2024-11-17 13-52-43.png (173.04 KiB) Viewed 6358 times
- Schermafdruk van 2024-11-17 13-52-09.png (192.27 KiB) Viewed 6358 times
rron
I´have changed the type to 248 and the subtype to 1. Now the value is good but the instead of kWh it shows Watt.
