Low cost window/door sensor
Re: Low cost window/door sensor
How did you add them to the system (more than one?) View if they are visible unther unused devices and click the arrow to add it, or learn mode? One of my switches has a 10 sec off-delay. Should be good right?
- Domoticz version: V3.8650
I bought set of these: http://www.ebay.co.uk/itm/W/181629193062.
Not bad price for sensor sendig both on and off correct way. The same sensor with nexa branding is three times more expensive here.
LXC(x64 Ubuntu Xenial), RFXtrx433E, MySensors
I have only doorcontact. I added it with the 'Learn' mode. Be sure to have 'Lighting4' enabled at the RFXCOM settings (Hardware > find RFXCOM in list, click 'Set mode'). ARC can't be enabled at the same time, so it can be you have to deselect that one.Dountill wrote:How did you add them to the system (more than one?) View if they are visible unther unused devices and click the arrow to add it, or learn mode? One of my switches has a 10 sec off-delay. Should be good right?
And be sure to have the 'Accept new hardware' setting enabled under 'Application settings'.
Nice, but seller is only shipping inside UKpj-r wrote:I bought set of these: http://www.ebay.co.uk/itm/W/181629193062.
I dont live in UKThinkPad wrote:Nice, but seller is only shipping inside UKpj-r wrote:I bought set of these: http://www.ebay.co.uk/itm/W/181629193062.
Just ask for price of shipping. For me it was bit over 18£ for 2kilos to finland.
Hmmm that is quite expensive compared to alternatives here in NL. I see the HE852 costs €9,99 here. Or the KlikAanKlikUit AMST-606 for €15. But i am not sure the AMST-606 can be used, i thought i read somehwere that they send a burst signal, and thus block the 433Mhz band temporarily.
It's correct that AC sensors (HomeEasy,Chacon,KlikAanKlikUit,NEXA...) send a burst signal so it's not recommended to use as door/window and motion sensors: http://www.domoticaforum.eu/viewtopic.php?f=27&t=7337ThinkPad wrote:But i am not sure the AMST-606 can be used, i thought i read somehwere that they send a burst signal, and thus block the 433Mhz band temporarily.
BTW, my battery just died today after using this low cost sensor as my front door contact. I think the battery need to be replaced in 3-4 months
Raspberry Pi Type B
Raspberry Pi Type B2
RFXCOMtrx433e
RFXCOMtrx433e
As a last resort i tried to clean them with some cleaning alcohol. Guess what. Got them working!Dountill wrote:I tried to add another door contact (next to my excisting one). I have to set an other code right? My first one got jumper set on H1, second one on H3. They both showed up in Domoticz. The first one doesn't work all the time, the second one doesnt work at all. I added a 10s off-delay (both sending out "on" signal) tried new batterys etc. Any ideas?
What did you clean? The jumper pins?
Everything. Just took an old toothbrush and cleared the whole print. Chip not included.ThinkPad wrote:What did you clean? The jumper pins?
Hi nmaster,
What are the jumper settings for this cheap smoke detector http://nl.aliexpress.com/item/433MHz-31 ... dVersion=2
There is jumper to set 1.5 / 3.3 / 4.7 M you said but I cannot find it, do you a picture of the jumper settings?
Last edited by ThinkPad on Saturday 24 January 2015 10:29, edited 1 time in total.
Reason: Edited right link
Did you get the 433Mhz version? The 315Mhz version is useless with the RFXCOM, as the RFXCOM works at 433Mhz.brommetje wrote:Hi nmaster,
Please post a picture of the inside of the smoke detector. You can upload images at www.imgur.com
Is the X10 DS90 with a on/off suitable for outdoor use ?
rfxcom usb rfxtrx433 E
14 x somfy RFY Blinds
3 x Eurodomest (Action BE) 972080 3x sockets
Selectplus (Action BE) chime
5 x TFA Weather Sensor
Home Easy HE872 (60W dimmer)
Nexus Weather Station
Nope, don't think so, but it isn't low cost even.p e t e r wrote:Is the X10 DS90 with a on/off suitable for outdoor use ?
But it has a connection for a extra wired contact. Place DS90 indoor and extra contact outdoor?
Cheap smoke detector chipset SC2262 433mhz version
http://imgur.com/urcYSGH
http://imgur.com/31xjWbD
How to set the jumpers to get it work with the rfxtrx433?
brommetje wrote:Cheap smoke detector chipset SC2262 433mhz version
The PCB doesn't have those jumper pins. Solder middle pads together should work.
I'm looking for a outdoor sensor to monitor when the outside entrence gate is openend or closed.Raspberry Piet wrote:Nope, don't think so, but it isn't low cost even.p e t e r wrote:Is the X10 DS90 with a on/off suitable for outdoor use ?
Does anyone know how i can use one of these cheap doorcontacts from Banggood to do this: http://td-er.nl/2014/05/12/bestaande-en-kaku-deurbel/
I opened the doorcontact, and mine uses a PT2264 chip. I looked up the [url=http://www.princeton.com.tw/Portals/0/P ... 2264_1.pdf]datasheet[/], and if pin 5 (TE, "Tranmission Enable") is connected to GND, it should transmit.
But nothing is happening....
The reedswitch is normally closed (NC). It breaks the circuit when the magnet is removed. Would be better if it would be normally open (NO), it would be easier to tap in with an optocoupler.
Edit: I think i will leave the doorcontact for now, and solve it by using one of these: http://www.ebay.com/itm/Electric-Clonin ... 1468459963
I already read that someone was using a remote like that with Domoticz (counting the flushes of a toilet, by connecting reedswitches to the buttons).
By the way, if i look at this: http://www.ebay.com/itm/Wireless-Ceilin ... 1365891287 there could be a chance that it would work. Components inside look the same as the PIR i already have. It also has 3M3 jumper, and code jumpers. 360 degree would be better to mount to the ceiling in my hallway or something. Only the price is a downside. Maybe someone else can find a cheaper one? Maybe i am not using the best search words.....
Edit2: Found a cheaper one: http://www.aliexpress.com/item/9V-batte ... 52701.html
That one will certainly work, i see the PT2264 chip, which is also in the PIR i now have, and that works with Domoticz
- Domoticz version: stable
I have receive my PIR and door contact . I have already lighting4 device (TCR02-2) so they are detected in lighting4 and send only ON command.
PIR works fine but door contact not send command every time, I check this.
RPi2 + RFLink, Domoticz
Chacon - micromodule 200w, remote 3b, 2x module 1000w, remote 16b, smoke detector, door contact, 2x 3500w plug
Oregon - 3x Thgr122Nx / OWL - CM180 / TRC02_2 RGB / Cheap - PiR, door contact, Temp Hum / 4x REVOLT NC5461
any idea why I my RFXCom registers the contact twice?
jumpers are set the same as the topic starter mentioned
I have problem with door contact, I can add to domoticz it was recognized and works fine but some hour or days later, it doesn't work no command received.
I have the same config what http://www.domoticz.com/forum/viewtopic ... =20#p14352.
Users browsing this forum: Google [Bot] and 0 guests
