Timer trigger rules
HvdW
Domoticz version: 2023.2
Timer trigger rules
Post by HvdW »
I'm struggling with timer trigger rules.
timer = { 'at 12:03 - 12:05'},
This one only executes at 12:03 , not at 12:04, not at 12:05
How can I make a script run at 2 separate time in a day.
I tried
timer = { 'at 12:03' and 'at 12:05'},
which executes only at 12:05
Bugs bug me.
GJKNL
Re: Timer trigger rules
Post by GJKNL »
Maybe: timer = { 'at 12:03', 'at 12:05'},
RonkA
Domoticz version: 2025.1
Post by RonkA »
In my understanding its:
timer = {'at 12:03', 'at 12:05'},
SolarEdge ModbusTCP - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20
Work in progress = Life in general..
HvdW
Post by HvdW »
Thanks, though these solutions don't do what is te be expected.
Meanwhile I went for a walk and the solution just came up by itself.
timer = { 'every 2 minutes between 12:03 and 12:05'},
Bugs bug me.
Domoticz version: 2024.7
I think you should not use a space between the times and - So something like:
timer = { 'at 12:03-12:05'},
RonkA
Post by RonkA »
Okay, you asked to trigger at those specific times so i don't see why the solutions given is not what you wanted.
But if it works.. Great; I was constricted by the written rule that is stated in the wiki:
https://www.domoticz.com/wiki/DzVents:_ ... gger_rules
Be mindful of the logic if using multiple types of timer triggers. It may not make sense to combine a trigger for a specific or instantaneous time with a trigger for a span or sequence of times (like ‘at sunset’ with ‘every 6 minutes’) in the same construct. Similarly, 'between aa and bb' only makes sense with instantaneous times for aa and bb.
But if it works, don't try to fix it, right?
HvdW
Post by HvdW »
@RonkA and @GJKNL you were right.
Didn't have the time to check my own solution and now I see that that executes every minute.
Thanks.
Bugs bug me.
