only once set text in text-device
BartSr
Domoticz version: V2024.7
Post by BartSr »
I intend to use text devices on floorplan as 'labels'
What is best way to set text in textdevice only once?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Chinese sensors temp (Dallas),movement
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
solarboy
Domoticz version: 2024.6
Re: only once set text in text-device
Post by solarboy »
In dzvents
domoticz.devices('My Text Device').updateText('The Text I want to show')
Domoticz version: 2026.3
Or with a API call:
/json.htm?type=command&param=udevice&idx=IDX&nvalue=0&svalue=TEXT
IDX = id of your device (This number can be found in the devices tab in the column "IDX")
TEXT = Text you want to display
https://www.domoticz.com/wiki/Domoticz_ ... ext_sensor
BartSr
Post by BartSr »
thanks Walter. But how to run this code only once dz starts?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
BartSr wrote: Monday 04 November 2024 8:18 thanks Walter. But how to run this code only once dz starts?
If you mean the dzvents line, that was not mine proposal. If you want to use dzvents just make a script that runs every minute. Run that line or multiple lines for multiple text devices and stop the script after a few minutes (disable it).
Once the text is in the database there is no need to update the text devices, even after a restart of Domoticz.
