Docker -> customstart.sh -> install python requests -> i got lost
RNEE
Domoticz version: 2025.1
Post by RNEE »
I moved Domoticz to Docker.
Before i had everything running in " userland" and also now (after migration) all hardware works : deCONZ, P1, garbagedata, Tuya, Goodwe, RFXCOM, Milight)
Problem is the Domoticz-deCONZ plugin (by : Smanar) keeps asking for Python Requests package :
2024-10-11 13:40:23.061 deCONZ: Acquiring GIL for 'onHeartbeatCallback'
2024-10-11 13:40:23.062 deCONZ: Calling message handler 'onHeartbeat' on 'module' type object.
2024-10-11 13:40:23.062 deCONZ: onHeartbeat called
2024-10-11 13:40:23.062 deCONZ: ### Initialisation > config
2024-10-11 13:40:23.062 deCONZ: ### Request config
2024-10-11 13:40:23.062 deCONZ: Send Command /api/8********B3/config/ with None (0 in buffer)
2024-10-11 13:40:23.062 deCONZ: Making Request: http://192.168.2.48:81/api/8**********B3/config/ with params None
2024-10-11 13:40:23.062 Error: deCONZ: Your python version is missing the requests library
2024-10-11 13:40:23.062 Error: deCONZ: To install it, type : sudo -H pip3 install requests | sudo -H pip install requests
2024-10-11 13:40:23.062 deCONZ: Acquiring GIL for 'onHeartbeatCallback'
I tried everything in adding to customstart.sh in "/opt/domoticz/config : userland" :
(customstart.sh already existed)
I added to the existing script and used the base script and added (all !) :
sudo apt install python3-requests
sudo apt-get -y install python3-requests
Restart container with :
Rene@rasp5:/opt/domoticz $ sudo docker compose up -d
[+] Running 1/1
 ✔ Container domoticz  Started
It seems requests is not installed in the docker container.
Could use some help in getting Python request into Docker...
(maybe in future releases op Domoticz Docker container incorporate already ?)
Thank you in advance !
Domoticz on Docker on Raspberry PI 5 with 500 Gb NVMe|Milight|KaKu + RFXCOM|Goodwe|Smartstuff P1 meter|Buienradar|Afval kalender|Tuya-wifi|Zigbee + deCONZ Conbee II|Marstek Homebattery 5,12Kwh via Modbus on Pusr-dr134|MQTTMapper|Quatt v2|
RNEE
Re: Docker -> customstart.sh -> install python requests -> i got lost
Post by RNEE »
This question is still open.
requests > 2.4 is needed.
It seems that in the container requests 2.32.3 is installed and cannot be updated (by me ?):
rene@rasp5:/opt/domoticz $ sudo docker compose exec domoticz sh
# pip install requests
Requirement already satisfied: requests in /usr/local/lib/python3.9/dist-packages (2.32.3)
Requirement already satisfied: urllib3<3,>=1.21.1 in /usr/local/lib/python3.9/dist-packages (from requests) (2.2.2)
Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.9/dist-packages (from requests) (3.7)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.9/dist-packages (from requests) (2024.7.4)
Requirement already satisfied: charset-normalizer<4,>=2 in /usr/local/lib/python3.9/dist-packages (from requests) (3.3.2)
2.32 is bigger than 2.4 (from 2014!) so the install is working correctly. Or you have mixed up the versions in your post.
https://pypi.org/project/requests/#history
RNEE
Post by RNEE »
It has noting to do with customstart.sh, that was based on some error messages.
I found out that the errormessage isn't related to the real error. The plugin does something then breaks, and starts again when callled etc .
In the docker container are already different library's installed alongside Python 3.9, as far as i know the are sufficient for the task.
This plugin is complicated because it does a lot of things that others don't :
- make extra custom menu, showing actual recent communication output.
- connects to another Dockercontainer running deCONZ
I started to resolve upcoming errors and I got the plug-in now running to the point where it installs the custom menu and communicates well with deCONZ, values are received every minute in custom menu.
Some things have to be done before the plugin works in docker.
So this title can be closed.
