install.domoticz.com certificate expired on the 1st of September
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
Installation is no longer possible unless you use the --insecure parameter. You then get the default start screen but i'm not able to start installation. But this could be another problem.
- gizmocuz
Re: install.domoticz.com certificate expired on the 1st of September
Should be solved now, thanks for reporting.
Server was under attack some days ago and some drastic changes have been made
- Domoticz version: 2020.2
"Drastic" seems to be the right word, as I'm now forced to tell I'm human every few minutes, with around 20% failure leading to a loop
