install.domoticz.com certificate expired on the 1st of September
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
docnl
Post by docnl »
Installation is no longer possible unless you use the --insecure parameter. You then get the default start screen but i'm not able to start installation. But this could be another problem.
gizmocuz
Re: install.domoticz.com certificate expired on the 1st of September
Post by gizmocuz »
Should be solved now, thanks for reporting.
Server was under attack some days ago and some drastic changes have been made
FlyingDomotic
Post by FlyingDomotic »
gizmocuz wrote: Tuesday 03 September 2024 8:24 Server was under attack some days ago and some drastic changes have been made
"Drastic" seems to be the right word, as I'm now forced to tell I'm human every few minutes, with around 20% failure leading to a loop ;-) Retrying some time later fixed the issue up to now.
