"Return" values disappeared From "comparing Usage (kWh) graph
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
RoelofS
Post by RoelofS »
Hi, I am experiencing the same troubles as others are reporting after updating Domoticz to the latest version a few weeks ago(2024.7) - random freeze of everything. The only solution I know is pull the power plug on the RPI , wait a minute, and connect again. The random freeze is unacceptable , of course... Today, I experienced another issue after such restart... the values (&button to choose) "Returned Energy" have disappeared.
These were, if I remember correctly, new features in the latest update.
On the "Electric power" Page ( with 5 graphs of power vs time) the first four ( usage last 24 hrs, Usage / hour, Usage last month, Usage last year ) are all functioning correctly; the 5th only shows "Comparing Usage" and the "Comparing Return" option you could click on has disappeared.
?? Am I the only one experiencing this ? How did this happen? Solution? ( also to the freeze problem ??)
Any thoughts sappreciated.
I am running domotics 2024.7 on RPI, watching the webpage on my Windows11 PC.
Roelof Salters
Domoticz running on RaspberryPi; Synology-NAS, Windows, Xiaomi Gateway, Hue, slimme meter,SolarEdge,Intergas Xtreme heater & heatpump
willemd
Domoticz version: 2024.1
Re: "Return" values disappeared From "comparing Usage (kWh) graph
Post by willemd »
It is certainly not a generic problem. I am running similar setup and version and have no problem.
Maybe restore an older dbase version (save your current version first so you can go back).
Anything in the log when the freeze occurs?
gizmocuz
Post by gizmocuz »
Do you have issues with the latest beta as well?
eisenj01
Post by eisenj01 »
I have the same problem. I believe at first after the update they were there but now they are gone. Is there any solution for this or do we have to live with untill the next update
