Spike in Enphase data
dbennik
- Domoticz version: 2024.7
Version: 2024.7
Platform: Raspberry Pi (Raspbian)
Plugin/Hardware: Enphase Envoy with LAN (HTTP) interface (Version: D7.6.175)
Description:
In the past i had some issues with the counter value (total) received from the Enphase Envoy was reset to 0 at some point. This would result in negative spikes (drops) in the collected data. Resolved this by deleting the spike values.
Now i have a new issue. A sudden jump in the counter value (total) received from the Enphase Envoy (so it seems). I could also remove the spike values to correct most graphs, but i still have a spike in the month compare graph which i cant seem to remove? Is this because it is in the current month and will it be corrected at the end of this month?
And does anyone have already encountered this behaviour with the Enphase Envoy. Sudden resets of the total counter to 0 as well as jumps up?
Description:
- gizmocuz
Re: Spike in Enphase data
The reset sometimes happens when you have a power outage or a firmware update.
For this reason, Domoticz keeps internally a counter offset, so when this happens, it should continue to count
There is a uservariable with the name 'EnphaseOffset_Production_xxxxxxx' with the offset
Did something happened? Power outage, firmware upgrade?
- gizmocuz
As a matter of fact, I have the same issue at 8 august.
I remember I have read that Enphase was forcing an update to all systems because some Dutch researchers have found a vulnerability in the system
https://www.divd.nl/newsroom/articles/d ... to-vendor/
dbennik
You might be right about the resets, I think I had the problem with my own scripts to update other meters I have (to calculate the direct used PV and real energy usage). These scripts did not handle the resets to 0.
And do you know about the month compare graph, were you able to fix that one? Other graphs I was able to fix by deleting the incorrect day values. But the month compare graph keeps showing the spike for the month total.
The report table shows the corrected value though, will the graph be fixed after the month ends? I don’t know how the value for the month total is calculated, by diff of the counter for start and end of month, or by summing all day values of the month.
The graph seems to be doing the first (at least for the current month) and the month report the last.
redhouse
I have the exact same issue and managed to resolve some of the erroneous values by manipulating the database using DB SQL Browser Lite. Mainly Meter, Meter_Calendar and Device_Status. I'm also interested on how the monthly value is being calculated. I have run some tests on a test system, and it looks like the counter counts "Current Value" - "Start of Month Value" and is updated every 5 minutes to show the actual production during the month. I have also tried changing values in between (both positive values and negative values to compensate for the sudden jump) but that doesn't change anything in the graph.
- FireWizard
Be aware that last year several vulnerabilities has been discovered, which has been patched rather recently by Enphase.
Since years I used firmware D5, which has been updated to D7 last Friday night.
This caused an interruption of the data stream, because of the authorization.
When this had been fixed, I noticed a spike as well.
Tonight I received another update from D7 to D8. I have received firmware version: D8.2.4264.
Also I noticed a spike again.
So, obviously, because the vulnerabilities has been fixed, they push now updates to the various systems.
This may cause the spikes.
microkid
Same here. I already manually modified the meter data (monthly), but the next day, the spike is back. Wondering how to solve this permanently.
microkid
Can you eleborate a little bit more please?
- gizmocuz
Well, I was going to write something, but I did some internal testing, and this is not going to work.
Sure, I could 'detect' the counter reset, but then again, I am having issues with the compare graph at the bottom
There is a user variable with the counter offset, this should be lowered to the correct value.
Then you need to patch the counter values in the database (meter_calendar) (and the huge usage spike at the specific day)
Would be nice if we could solve this internally somehow
The uservariable you can find by going to Setup->More Options->User Variables, and in the search, box enter 'enphase'
But I would suggest correcting that in your database backup as well, so when you restore your patched database, all should be ok
Now why this happend beats me at the moment, because I try to solve this by using a special internal counter (See EnphaseAPI.cpp, ~line 853)
When this counter is lower than the previous value, a reset has occurred, and the new counter offset (the user variable) should be the last corrected counter value
Seems like something is going wrong here:
CounterHelper::SendKwhMeter
As this is used on other places as well, hope someone can have a look at this.
Best to create a github issue with all this information as I don't browse the forum that much
*** Wait ***
Something else is going on... the 'counter' received from Enphase has a big jump!!! It was not reset...
My current value is
"whLifetime": 7781778
my uservariable still has a value of
3578.851000
This because I has some resets in the past when I turned of the power.
I wonder what happens if I turned off the power from the Envoy gateway, will it reset to 0 again? And will this correct the counter again the next day?
Still some patching up to do in the database
(No time to test this, maybe someone else could)
We could use a minus value for the uservariable (in my case probably subtract 7182913)
rowid DeviceRowID Value Date Counter Price
107941 8023 26919 2024-08-06 00:00:00.000 3780803 5.2376
108002 8023 17667 2024-08-07 00:00:00.000 3798470 3.3184
108064 8023 7182913 2024-08-08 00:00:00.000 10981383 1454.4884
108126 8023 14854 2024-08-09 00:00:00.000 10996237 2.3638
My current value is
3578.851000
dbennik
I had the same thought about the jump.
I had several resets to 0 in the past as well and thus a offset user variable > 0 filled in.
It now seems that the envoy has made up for the resets in the past and started reporting the actual usage counter again (maybe Enphase fixed this?). My current lifetime production is 5,7Mwh at this point. The offset had 2,4Mwh and the counter is now at 8,1Mwh.
So when I reset the offset variable to 0 it seems that my envoy is reporting the correct counter again (which seems like a jump because it made up for the resets).
- gizmocuz
Found a way to fix it, but it involves some steps:
Steps performed to fix the jump (A huge jump up that is!!!, very rare occasion!!):
- press 'Edit' on the Enphase kWh delivery sensor and notice the IDX
- shutdown Domoticz, cleanly
- copy the database domoticz.db (if there are domoticz.db-wal and domoticz.db-shm files, also copy these!)
- make also a backup/zip, so you can always go back!!!
- open the database with an editor like (for example) SQLite Expert Personal edition
- go a sql query editor and execute
DELETE FROM Meter WHERE DeviceRowID = (above found IDX), for example
DELETE FROM Meter WHERE DeviceRowID = 8023
- open the Meter_Calendar table, filter all records where DeviceRowID = (above found IDX)
- find the moment where the big jump is, you will see the 'value' column have a HUGE value, copy/note this value, this is your 'offset' that you need to subtract from the 'counter' column from that point
For example my view:
7182913 is my 'offset' to subtract from that day onwards in the counter field, till today/yesterday, so all records from that day!
(I let excel help me with this)
The moment where this is happening and you have a huge 'value', set this value to 0, and also set the 'price' column to zero, when you have done this, it will look like:
(If you are unable to do this, or it is too complicate, too much work, you can also 'delete' all records from the moment where you have that 'huge' value), but do this at least for the last value, you will need this corrected counter value in the next step
- take a notice of the last corrected counter value, in my case '4204920'
- next, open the 'DeviceStatus' table, and make a filter/find your device (ID = (above id)
- change the 'sValue' so after the semicolon ( ; ) you change that value with the above value (4204920.000)
- next, open the 'UserVariables' table, and find your enphase offset (name should be something like 'EnphaseOffset_Production_xxxxxx')
- If your offset value above was 7182913, divide this by 1000, so you will get 7182.913
- subtract the uservariable with this, 3578.851000 - 7182.913 = -3604.062
- set the uservariable to this value (-3604.062)
- now close the editor, and copy the database back to your Domoticz folder (in the correct folder if you use a docker instance)
- start Domoticz again
I think we should be able to make a python script for this that detects the spike, and performs the above steps
But my python skills are limited
And I also should be able to detect the jump in the c++ code in the CounterHelper class.
Probably this addition will work, but maybe someone could test this offline
108187 8023 24588 2024-08-10 00:00:00.000 11020825 3.1892
108248 8023 28569 2024-08-11 00:00:00.000 11049394 3.8624
108309 8023 29174 2024-08-12 00:00:00.000 11078568 5.591
108370 8023 26394 2024-08-13 00:00:00.000 11104962 6.3272
108064 8023 0 2024-08-08 00:00:00.000 3798470 0
108126 8023 14854 2024-08-09 00:00:00.000 3813324 2.3638
108187 8023 24588 2024-08-10 00:00:00.000 3837912 3.1892
108248 8023 28569 2024-08-11 00:00:00.000 3866481 3.8624
108309 8023 29174 2024-08-12 00:00:00.000 3895655 5.591
108370 8023 26394 2024-08-13 00:00:00.000 3922049 6.3272
108431 8023 9123 2024-08-14 00:00:00.000 3931172 2.4712
109285 8023 27285 2024-08-28 00:00:00.000 4204920 6.0352
void CounterHelper::SendKwhMeter(const int NodeID, const int ChildID, const int BatteryLevel, const double musage, double mtotal, const std::string& defaultname, int RssiLevel)
if (mtotal != 0)
double rTotal = m_CounterOffset + mtotal;
bool bHaveCounterIssue = false;
if (
(rTotal < m_nLastCounterValue)
&& (m_nLastCounterValue != 0)
//Possible counter reset (newly received counter value is less then previous recieved!)
m_CounterOffset = m_nLastCounterValue;
bHaveCounterIssue = true;
else if (m_nLastCounterValue > 10 && rTotal > 10)
constexpr double m_allowed_cntr_jump_perc = 500; //We consider a 500% jump 'not' normal... what's a good value?
if (abs((100.0 / m_nLastCounterValue) * rTotal) > m_allowed_cntr_jump_perc)
//Possible counter jump up!?
m_CounterOffset = (m_nLastCounterValue - mtotal);
if (bHaveCounterIssue)
m_sql.safe_query("UPDATE UserVariables SET Value='%q', LastUpdate='%s' WHERE (Name=='%q')", std::to_string(m_CounterOffset).c_str(), TimeToString(nullptr, TF_DateTime).c_str(), m_szUservariableName.c_str());
m_pHardwareBase->SendKwhMeter(NodeID, ChildID, BatteryLevel, musage, static_cast<double>(rTotal), defaultname, RssiLevel);
m_nLastCounterValue = rTotal;
dbennik
Thanks for the information
Following your steps to correct the spike i managed to do so. I just have one strange thing i can not really explain.
The month total in the graph is still showing 24kwh above what it should be. The DB values all add up to the correct amount and when i click to the report, the table and the graph there also show the correct amount.
How is the month overview graph calculating the month values and how can it be that it is still too high?
Month graph too high: Report correct:
dbennik
That is what i thought it would be, but when i calculate it myself with the counter value, it still should be 424.32 and the year overview per month on the main meter page still shows 448.31
Below my Meter_Calendar data for the Enphase meter.
It should be 3319314 (2024-08-31) - 2894942 (2024-07-31) = 424372 (= 424,327). This is the correct value and is shown on the report page.
So i am a bit in the dark to why the main page month graph still shows 448.31 for august.
Edit: Even when i add up all the Value column values for august it results in 424372.
rowid DeviceRowID Value Counter Date Price
11415 172 13707 3349757 2024-09-02 00:00:00.000 0
11398 172 16736 3336050 2024-09-01 00:00:00.000 0
11381 172 16974 3319314 2024-08-31 00:00:00.000 0
11364 172 16114 3302340 2024-08-30 00:00:00.000 0
11347 172 13243 3286226 2024-08-29 00:00:00.000 0
11330 172 18113 3272983 2024-08-28 00:00:00.000 0
11313 172 18766 3254870 2024-08-27 00:00:00.000 0
11296 172 12407 3236104 2024-08-26 00:00:00.000 0
11279 172 13345 3223697 2024-08-25 00:00:00.000 0
11262 172 6226 3210352 2024-08-24 00:00:00.000 0
11245 172 9954 3204126 2024-08-23 00:00:00.000 0
11228 172 11117 3194172 2024-08-22 00:00:00.000 0
11211 172 14538 3183055 2024-08-21 00:00:00.000 0
11194 172 6120 3168517 2024-08-20 00:00:00.000 0
11177 172 16407 3162397 2024-08-19 00:00:00.000 0
11160 172 13379 3145990 2024-08-18 00:00:00.000 0
11431 172 19300 3132611 2024-08-17 00:00:00.000 0
11126 172 4642 3113311 2024-08-16 00:00:00.000 0
11109 172 14240 3132611 2024-08-15 00:00:00.000 0
11092 172 5791 3094429 2024-08-14 00:00:00.000 0
11075 172 11926 3088638 2024-08-13 00:00:00.000 0
11058 172 19116 3076712 2024-08-12 00:00:00.000 0
11041 172 19504 3057596 2024-08-11 00:00:00.000 0
11024 172 16944 3038092 2024-08-10 00:00:00.000 0
11007 172 11178 3021148 2024-08-09 00:00:00.000 0
10990 172 18398 3009970 2024-08-08 00:00:00.000 0
10973 172 15623 2991572 2024-08-07 00:00:00.000 0
10956 172 17981 2975949 2024-08-06 00:00:00.000 0
10939 172 19259 2957968 2024-08-05 00:00:00.000 0
10922 172 10924 2938709 2024-08-04 00:00:00.000 0
10905 172 10550 2927785 2024-08-03 00:00:00.000 0
10888 172 15550 2917235 2024-08-02 00:00:00.000 0
10871 172 6743 2901685 2024-08-01 00:00:00.000 0
10854 172 12173 2894942 2024-07-31 00:00:00.000 0
10837 172 19071 2882769 2024-07-30 00:00:00.000 0
Hansbit
Thanks! That procedure solved it for me. My firmware was updated to D8, that caused the counter-jump.
(I'm happy with D8 because it solves the Enphase problem https://support.enphase.com/s/question/ ... 5712522212 when switching production off and on again, the panels won't start producing until the next morning. I have to test that next week).
Thanks, Hans
Thanks, Hans
- gizmocuz
Strange, as I do this via Domoticz (Domoticz has a switch for this, so there is no need to perform this action in the web interface), and this works like a charm.
Made a script that does this automatically... (a few times a year)
Hansbit
Problem existed for more than a year. Didn't matter if I switched via Domoticz or via web-interface, the panels won't startup again until next morning. Only restarted when I temporarily disconnected the panel (DC) from the micro inverter, but too much work on the roofgizmocuz wrote: Monday 09 September 2024 7:22 Strange, as I do this via Domoticz (Domoticz has a switch for this, so there is no need to perform this action in the web interface), and this works like a charm.
Hansbit
That's weird! This morning (edited all counters yesterday) the spike is back!
What to do now?
What to do now?
freekdk
- Domoticz version: V2025.1
I did have the same type of problem. Because I started collecting data from Enphase right after the installation, the begin value of the Counter in Meter_Calendar starts at 1 (made it so). I made the data in Value and Counter consistent, so the counter is value+previous-counter. The last counter (of today) is consistent with the reported value of the total produced kWh on the webpage.
In another script I changed the values in table Meter items Value to be equal at midnight with the last counter in table Meter_Calendar and keep the difference of these values the same as before. I also changed item sValue in table DeviceStatus to the last value in table Meter_calendar. This was done between stopping Domoticz and starting it.
After that I saw new values in Meter with the right value in Value, in fact the total Wh produced. However at 05:20 suddenly a much higher value appeared, producing again a spike in the graphics. Reading in this subject I got the idea it is caused by the value in UserVariables, but when I calculate the difference they do not match. The totalWh should be 5256837, but is 7666212, difference 2409375. The value in UserVariables of EnphaseOffset_Production_12 is 2386.086000.
Question: what to put in UserVariables as offset and does that solve my problem?
