Domoticz Memory leak in 2024 beta build 15910
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Kedi
Re: Domoticz Memory leak in 2024 beta build 15910
Post by Kedi »
Reinstall with curl gives you the exact same files as I have now.
Just delete the database and start Domoticz will give you an empty database too.
I don't want to import an older version of my database, because I want to keep my history intact.
Still I don't understand how that will create a memory leak. If so, everybody will experience the memory leak.
Eventually you will too, because sqlite3 did not change.
Last report about sqlite3 memory leak is from 2021.
Domoticz version: 2024.7
I also dont see why importing a database will create a memory leak.
All that can happen is that due to the number of devices the database will grow and also updating the devices will grow the database. Especially when text devices are used. So it looks like a memory leak but in fact is just a result of growing database.
@JanVlieteland what are your log settings (menu Setup- Settings, tab Log History).
JanVlietland
Post by JanVlietland »
Light/Switches = 30 days
Short logs: 1 day
Check box not checked
@Walter, does that answer your question?
Memory issue over here is still solved. However all history is gone. It's a real bummer as my plan is to use OpenAI to see if I can optimize the energy usage, based on sun position, sunpower, temp, Tau-time etc etc. I'm currently digging if I can extract the data from the old database.
FrancescoS
Post by FrancescoS »
i have the same issue.
could someone explain what it the fix to this ?
thank you
Francesco
Dave21w
Domoticz version: Stable
Post by Dave21w »
I have 2 systems running, one in my home and a test system at work with not many devices, both display a very similar graph to each other, something defintely changed in Dec 23 as can be seen here and it's never got back to where it was.
2024-08-15 09_30_00-Domoticz.jpg (104.08 KiB) Viewed 671 times
Can you also check the Process usage device? As you are now showing the total memory consumption of your server and some other process could influence this. I once had my file explorer process kill the memory....
Users browsing this forum: trakers and 1 guest
