I'm setting up a raspberry pi 4 with SSD and Z-Pi 7 board from Aeotec. I did install docker compose as recommended. I followed the instructions on domoticz WIKI. For using Z-Pi7 I switched of the bluetooth as described on help desk from Aeotec with
dtoverlay=disable-bt
enable_uart=1
I checked if Z-Pi7 is on ttyAMA0 and I found /dev/ttyAMA0.
I did installed zwave-js-ui as recommended with docker compose like described in domoticz WIKI. The same with MQTT.
After setting up zwave-js-ui within the browser I got a Driver error.
- Bildschirmfoto vom 2024-08-09 17-56-53.png (238.56 KiB) Viewed 5147 times
Any ideas, maybe somebody already run with Z-Pi 7. I'm not able to take the right conclusions from the log.
My docker compose.yml
- Spoiler: show
services:
zwave-js-ui:
container_name: zwave-js-ui
image: zwavejs/zwave-js-ui:latest
restart: always
tty: true
stop_signal: SIGINT
environment:
#- SESSION_SECRET=mysupersecretkey
- ZWAVEJS_EXTERNAL_CONFIG=/usr/src/app/store/.config-db
# Uncomment if you want log times and dates to match your timezone instead of UTC
# Available at https://en.wikipedia.org/wiki/List_of_tz_database_time_zones
- TZ=Europe/Berlin
networks:
- zwave
devices:
# Do not use /dev/ttyUSBX serial devices, as those mappings can change over time.
# Instead, use the /dev/serial/by-id/X serial device for your Z-Wave stick. I have to use /dev/ttyAMA0 by design of Z-Pi 7.
- '/dev/ttyAMA0:/dev/zwave'
volumes:
- zwave-config:/usr/src/app/store
# - /home/michael/docker/zwavejs/:/usr/src/app/store
# Or by using local folder
# - ./store:/usr/src/app/store
ports:
- "8091:8091" # port for web interface
- "3000:3000" # port for Z-Wave JS websocket server
networks:
zwave:
volumes:
zwave-config:
Thanks for any hints or helping in advance
